Features:
- Pick study sets from the file system
- Star flashcards to study just a few flashcards within a set, and they are saved between launches
- Uses freetype with Roboto, so it's easy to read, unlike the default font that nSDL has
- Use the touchpad to quickly scroll through cards
- Is probably the only thing that uses the little flag key on the keyboard (seriously, what is it there for?)
Screenshots
![Image](https://raw.githubusercontent.com/lights0123/n-flashcards/master/screenshots/File%20chooser.png)
![Image](https://raw.githubusercontent.com/lights0123/n-flashcards/master/screenshots/Config.png)
![Image](https://raw.githubusercontent.com/lights0123/n-flashcards/master/screenshots/Card.png)
The source is here, and you can pick up a tns file here. Note that you'll need ndless installed to use it. See the repository for detailed instructions involving csv files, and exporting from Quizlet.
This is the first app that uses Rust and ndless! The Rust toolchain almost ready for release, and I'll make a separate post when it is. However, if you'd like to jump right in to development, you can always fork this and get started.
