HP Prime doesn't read my pdf
I converted pdf files with your program, I uploaded these files on the calculator but when I open the application I see a chart with a parabola.
I tried to make several reset, even by pressing the button on the back but I have not solved the problem.
What do I have to do?
Earnweald
Niveau 9: IC (Compteur Infatigable)- Messages: 1
- Genre:
Re: HP Prime doesn't read my pdf
Hi,
I've tested your latest converted document and it seems to work here :
archives_cat.php?auteur=115182&generator=-1
Be sure to install the most recent HP Prime firmware, 10637 to date :
archives_voir.php?id=658248
Niveau 19: CU (Créateur Universel)- Messages: 41593
- Images: 15121
- Genre:
- Twitter/X: critor2000
Olá Critor, I´m having the same problem.... I just can´t send apps to Kit Conectivit. It doesn´t appear a option to send my files.
Could you help?
Could you help?
geandc
Niveau 4: MC (Membre Confirmé)- Messages: 2
- Genre:
- Classe: classe
Please someone could make a tutorial about how send files to hp prime. tks a lot
geandc
- Genre:
- Classe: classe
@geanc You're not having the same problem if you're telling me that you can't send the apps.
The problem about was when opening the apps.
Tell me how you're processing to send things to the HP Prime, then.
As far as I know there is nothing special with generated files.
You just need to drag them on the Connectivity Kit calculator entry, like any other HP Prime file.
- Images: 15121
- Genre:
Hi Critor,
I have a problem, I create a program with your site from a pdf and it works in the virtual calculator, but when I try to run it on the phisical one a sintax error appears, what can I do?
Thanks for your help
javigb96
Niveau 5: MO (Membre Overclocké)- Messages: 1
- Genre:
Press the 'reset' button on the back and retry.
It should work.
But my advise would be :
Don't use the program format anymore.
Use the new default App format.
Default is by far the best choice.
It should work.
- Images: 15121
- Genre:
I am like the same problem reported in this topic. I can send the apps normally to the calculator, but when I try to execute them from the applications menu it shows a parabola. Even programs do not work, either. I'll be grateful if anyone has anything that might help.
globrother
Niveau 4: MC (Membre Confirmé)- Messages: 3
- Genre:
- Images: 15121
- Genre:
I updated to the new. I'm sorry I forgot to inform you ... The applications worked correctly with the previous version. As soon as I made the upgrade to firmware 10637, they no longer work. The version of the connectivity kit is 2016/12/08. 11226. In the virtual calculator the apps work normally.
Going by the "shift program" key and selecting the app displays the following error: program syntax error 17: "LOCAL str:=STRING (num);" as the image below:
globrother
- Genre:
12 messages
• Page 1 sur 2 • 1, 2
Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 3 invités
