Nouveau firmware Prime + logiciel ordinateur, révision 10077
Unread postby Lionel Debroux » 21 Apr 2016, 09:27
HP a publié cette nuit une mise à jour du firmware de la Prime. Ils l'annoncent comme une mise à jour majeure, tant du logiciel calculatrice que du logiciel ordinateur :)
La réduction de la consommation de RAM de l'OS sera beaucoup appréciée des utilisateurs de mViewer GX.
(plus de commentaires à venir)
Voici les détails dans les release notes:
HP Prime – Release Notes
Date Released: 2016/04/14
Internal Versions
Firmware Version: 2016 04 14 (10077)
Virtual Calculator Version: 2016 04 14 (10077)
Connectivity Kit: 2016 04 14 (10077)
This release of the Prime Calculator firmware and associated PC software delivers significant new features and fixes outstanding issues. This document is not a complete list of all changes, but highlights specific items. All users of the HP Prime calculator are encouraged to upgrade for the best possible experience.
Please back up your calculator before the update. Any existing data on the device will be wiped during the update process.
New Functionality (Connectivity Kit)
1. Progress bars on each calculator in tree to show transfer status
2. Calculator and content pane now dockable windows. Connkit will remember and restore position/state of all windows
3. Network mapped working directories supported
4. Ability to add plot backgrounds to graphing applications
5. Proctor mode to automatically start exam mode on connection
6. Improved polling and sending of response data back to classroom
7. Invalid .hpprgm files will be attempted to load as plain text if possible. Will attempt to determine text encoding format
8. Turned on IP networking for future usage
New Functionality (Virtual Calculator)
1. Added confirmation on emulator reset menu press
New Functionality (Calculator Software)
1. Ability to manipulate functions in the Function app
a. Change expressions into other forms
b. Reposition and modify existing expressions
c. Cubics now also recognized in sketch and manipulation
2. Use a picture for graph background
a. Choose from a built in image library, or add your own
b. Fit image to screen, or position at a specific Cartesian location
3. Sketch a function directly in the Statistics 2Var App
4. Recovered ~8MB of RAM for user use
5. Improved interaction between CAS functions and HPPPL program. CAS functions can now access directly HPPPL local variables as expected
6. Sequence app now allows N..N+1..N+2 form
7. Gradian support for angle mode
8. EQ function for exact equality test of list. EQ({1,2,3},{1,2,3}) -> 1
9. =CHOOSE(...) now makes a drop down selector in the spreadsheet
10. LNAME function to extract variable names from home functions
11. Added UNION function
12. Support for jpg read/write. AFiles("file.jpg",[1-100]):=G0
13. Direct access to images stored as files. G1:=AFiles("myfile.jpg")
14. Plot scatterplot/ode wizard in geometry app
15. Added alpha blend to BLIT commands
16. Added IFERR feature to enable access of the error value from the Ans variable on error
17. Added support for alpha channel in PIXON commands
18. Enhances PLOT-TABLE of Function, Polar, Parametric, and Sequence apps to bring up new G1,...,G9,TableSelection chooser for choosing what to copy where
19. Option for split stems in stem leaf plot
20. New backup manager. You can now create, archive and restore backups on your calculator directly from memory manager
21. VERSION() can take an argument to return that part of version info
22. TEXTOUT functions now return pixel coordinate of the end of the printed text.
1. Resolved issue with excess power drain while in exam mode and calculator was "off"
2. Resolved issue with use of complex arguments for some drawing commands
3. Resolved issue with certain RPN programs causing issues when called from stack
4. Resolved issue where quadratic explorer SOLVE function will now return complex results
5. Resolved issue with "Cannot find solution" with negative seed values
7. Resolved issue in printing of complex with negative second component
8. Resolved issue with color chooser in note screen
9. Resolved issue with AVars accessing files from another application sometimes causing issues
10. Resolved issue with "CAS." being appended in spreadsheet
11. Resolved issue with declaring a LOCAL in home screen
12. Resolved issue with calling ΠLIST with vector
13. Resolved issues with SWAPROW/SWAPCOL
14. Resolved issue with REPLACE on lists behaving inconsistently
15. Resolved issue with INPUT choose lists and >9 items
16. Resolved issues with SORT
17. Resolved issue with summation rejecting non-integer values. Allows smooth plotting
18. Resolved issue with small plot previews in home/CAS not using current app plot window
19. Resolved issue with GETKEY working after third screen tap
20. Resolved issue with lists and comparison operators
21. Resolved issue with calling function such as DATEADD when named spreadsheet cell exists as "DATE"
22. Resolved issue with DIFFERENCE and calling multiple lists as arguments
23. Resolved issue with user app vars not showing in VARS menu
24. Resolved issue with long hold on grid chooser not selecting item
25. Resolved issue with exact() and approx() via [a b/c] key not setting Ans in CAS
26. Resolved issue with fraction^power not displaying (fraction)^power for clarity
27. Resolved issue with complex numbers and units needing ( ) for clarity
28. Improved ITERATE command to allow up to 2^16 iterations
29. Resolved issue where two parameter NORMALCDF behaving different in home/CAS. Now two params will give you the area for a standard normal between L/R ends
30. Resolved issue where copying something like 1.5e-25/2 into command line in CAS from history did not do division template properly
31. Resolved issue where stat 1var calculation with frequency when frequency sum was identical to 1 was throwing an error
32. Resolved issue so that LOG(81,3) returns 4 and not 3.9999...
33. Resolved issue with REPLACE expanding with strings, but not vectors
34. Resolved issue with integration in programs not able to use local variables
35. Resolved issue with Σ failing with local variables
36. Pressing Esc from List/Matrix did not return to List/Matrix screen like Program/Notes behavior
37. Resolved issue where [sto] was allowed as first character in home var name
38. Resolved issue that prevented assigning a user variable a complex form polar in a program source
39. Resolved issue where Linear Explorer SolveForSlope function did not have the order of arguments working as expected
40. Resolved issue with Resid() and PredY() throwing an error if Med-Med was fit type
41. Resolved issue where shift-copy would not allow copying of system help text
42. Resolved issue where change of display format did not invalidate 2D expression cache resulting in stale number display
43. Resolved issue where F1(X)=STUDENT(N,X) reports Signed Area as NaN. Fisher, and Chi will also now work as expected
44. Resolved issue where program editor could misbehave and cause memory issues
45. Resolved issue with memory leak when application had embedded PNG images
46. Renamed "Rect" variable in Triangle Solver app to "TriType"
47. Removed error check on proportion z interval to allow a negative confidence interval. - can be negative vs error
48. Resolved issues with WAIT/GETKEY not responding as expected after 3rd screen touch.
1. Improved results for tan(pi/24)
2. Resolved issue with display of int(sqrt(1/x-1),x,1/2,1) (sqrt(1/4) getting converted to sqrt(1)/4 on copy
3. Improved printing of (e^2)^3
4. Fix for desolve([y'=[[1,2],[2,1]]*y+[x,x+1],y(0)=[1,2]])
5. Fix for fsolve(x^3-3*x^2+4,x,-3..5)
6. Support for gradians.
7. Fix for solve(3 NTHROOT (2^(4*x-1))>=(2^(x-5))/(4 NTHROOT (16^x)))
8. Fix for polynomial_regression(8)
9. Resolved issue with "break" being parsed differently than "BREAK"
10. Improved student_cdf for dof>=100
11. Fix for limit((3*e^(2x)-12)/(e^(2x)-7*e^x+10),x,ln(2))
12. Fix for forms like (sqrt(sqrt())
13. Behavior change so that fsolve without guess now tries 0 if default bisection returns [ ]
14. Fix for laplace([0,0],x,x) and a:=[[1,2,3],[4,5,6],[7,8,9]];[y0]:=desolve(y'=a*y and y(0)=[1,0,0]);
15. Fix for solve(x^3=1.2e-15,x)
16. Fix for ∂(∂(x^2*y^3,y),x)
17. Enabled mod in parser as a synonym for irem (prefixed, MOD is infixed)
18. Fix parsing of "return"
19. Fix for int(abs(sin(2*pi*x)),x=0..1)
20. Fix for sum(sum(1/(j+k),k,1,m),j,1,n))
21. Make circle() work like circumcircle() when called with 3 args
22. Modified implicitplot to returns a list instead of a sequence for hyperbola
23. Fixes for ker and finite field factorization
24. Fix for cfactor(2*x^3+x^2+x+1/2)
25. Fix for solve((3*ABS(6-x)+2*ABS(3/2*x-5))=8,x)
26. Fix for csolve(-256*p^5-128*p^4-16*p^3+2000*p^2+900*p+3233=0,p)
27. Implicit multiplication warnings replaced by errors
28. Fix in DELROW/DELCOL to eval second parameter
29. Fix for int(1/(4+sin(3*x)),x,0,2)
30. Add warning for (1+2)(3+4)
31. Extend areas to support ellipse. e.g. area(ellipse(-1,1,2))
32. Fix so simplify(sin(x-sin(x))') leaves unchanged
33. Fix SVL for sym. matrices
34. Fix for sum(legendre(j),j,0,3)
35. Fixes for nested sqrt like normal(sqrt((1)-((5)*(sqrt(2)))))
36. Fixes sum bug (-1)^(n+1) / n^2 and sum((-1)^(n+1)/n^4,n,1,inf)
37. Modified geometric_cdf to be inclusive of lower bound
38. Fix for assume(z>1000); sum(3^n*z^(-n),n,0,inf)
39. Added Dirac support in ztrans
Level up: 11.3%
Nouveau firmware Prime : 10077
Unread postby hpfx » 21 Apr 2016, 14:41
citons parmi les points important :
* les suites pouvant enfin être définies en U(n) ou U(n+1)
* correction de la consommation d'énergie en mode exam! (elle restait allumé en fait)
* la mémoire est sauvegardée puis restaurée en mode exam (on récupère tout à la fin de l'exam)
* la possibilité de faire un backup complet depuis la machine (sans être connecté)
et surtout a mon sens : on a bien gagné en stabilité.
Il me semble que les transferts d'app fonctionnent bien mieux qu'en 8151.
une super bonne mise à jour.
hpfxPremium
Level up: 48%
Re: Nouveau firmware Prime + logiciel ordinateur, révision 1
Unread postby critor » 21 Apr 2016, 14:45
Bonjour.
hpfx wrote:* les suites pouvant enfin être définies en U(n) ou U(n+1)
Il y a bien une nouvelle interface facilitant la saisie de suites récurrentes d'ordre 2.
Mais j'ai beau chercher, je ne trouve pas comment définir ailleurs qu'au rang N. Rien de tel à l'écran de configuration.
Image Image
Pouvez-vous m'éclairer là-dessus ?
Level up: 45.9%
Images: 15363
Re: Nouveau firmware Prime : 10077
Unread postby critor » 21 Apr 2016, 19:35
hpfx wrote:et surtout a mon sens : on a bien gagné en stabilité.
J'aurais bien aimé adhérer à cette conclusion optimiste, mais hélas non.
Des choses autour des 8Mo de RAM supplémentaires n'ont pas dû être testées/codées correctement.
Les fuites de mémoire sont toujours là. Alors certes, avoir 8Mo de RAM supplémentaires retarde les problèmes.
Mais à terme, lorsque l'on a terminé d'épuiser la RAM, c'est pire qu'avant : il y a de graves problèmes de corruption+perte de données.
Exemple 1 :
  1. Chargeons des pages de document dans la calculatrice.
  2. Effectuons un 'reset' pour libérer la RAM des fuites mémoire.
  3. Ouvrons la 1ère page du document, passons à la page 2, 3, 4, 5...
  4. A la page 6, on obtient une erreur de syntaxe, car la RAM est épuisée.
  5. Faisons 'reset' pour libérer la RAM.
  6. Et là, horreur, toutes les pages utilisées ont été tronqués à 0.23Ko et donc détruites ! :mj:
Exemple 2 :
  1. Rechargerons les mêmes pages de document dans la calculatrice.
  3. Allons dans le menu mémoire, ce qui prend du temps, plusieurs secondes alors que c'était instantané avec l'ancien firmware - visiblement le nouveau fait quelque chose.
  4. Demandons la RAM libre, et horreur, plus que 2,42Mo alors que nous venons de faire 'reset'... En calculant la RAM libre, ce menu épuise la RAM - un comble...
  5. Retournons maintenant lister les programmes, sans rien lancer.
  6. Et là double horreur, plusieurs pages ont été aléatoirement détruites, pire sans même les utiliser ici ! :mj:
Malgré ma bonne volonté je suis incapable de reproduire ces graves problèmes avec l'ancien firmware 8151.
Bref, on a davantage de RAM, mais quand la RAM s'épuise c'est pire qu'avant.
Je vais continuer mes tests comparatifs entre les deux firmwares, mais je regrette, en cette période d'examens critique pour nombre de candidats, je vais devoir très rapidement communiquer contre l'installation de ce nouveau firmware dans l'intérêt de ces derniers.
Level up: 45.9%
Images: 15363
Unread postby hpfx » 21 Apr 2016, 20:09
critor wrote:Bonjour.
Image Image
Oui bien sur,
C'est pourtant dans l'écran, où vous êtes : il y a une case a cocher à droite ;)
Ha oui... et ça marche aussi avec des définition en U(n+2),
il suffit de saisir un U(0) ET un U(1), ca me semblait évident, mais bon je préfère le préciser :P
voilà.
hpfxPremium
Level up: 48%
Unread postby critor » 21 Apr 2016, 20:18
Merci @hpfx.
Pas très intuitif je trouve et un peu discret, mais une fois qu'on le sait c'est bon.
C'est une très belle avancée. :)
Level up: 45.9%
Images: 15363
Unread postby hpfx » 21 Apr 2016, 20:18
Des choses autour des 8Mo de RAM supplémentaires nont pas dû être testées/codées correctement.
Les fuites de mémoire sont toujours là. Alors certes, avoir 8Mo de RAM supplémantaires retarde les problèmes.
Oui enfin, j'ai juste dit que c'est plus stable.
autant j'avais pas mal de plantage sur la 8151, autant je trouve la nouvelle version vraiment plus stable, d'une part c'est certes subjectif, et d'autre par ça dépend de ce que l'on teste.
En effet, je parle d'utilisation normale, je fais planter facilement la 8151 (sur l'application géometrie par exemple), je n'ai plus ces plantages là.
ensuite je n'ai pas fait des tests "aux limites", oui c'est vrai. on ne teste donc pas les mêmes choses. et je n'ai pas la prétention de tout tester en aussi peu de temps. mais en quelques heures j'ai vu une nette difference... enfin c'est subjectif, c'est vrai.
hpfxPremium
Level up: 48%
Unread postby parisse » 21 Apr 2016, 20:52
Personnellement, si j'avais un concours ou examen la semaine prochaine par exemple, je ne mettrai pas a jour le firmware tout de suite. Il vaut mieux attendre deux ou trois semaines que des milliers d'utilisateurs aient mis a jour et que les bugs qui n'ont pas ete detectes par les tests de regression et beta-testeurs aient ete debusques. Ensuite a chacun de se faire son opinion, en fonction de ce qu'il utilise. Pour un usage normal de calculatrice graphique CAS (n'incluant pas de multiples transferts et consultation de gros documents), je suis assez optimiste sur le fait que ce nouveau firmware sera considere comme plus stable que le precedent, en tout cas pour le CAS (meme si malheureusement il reste encore des bugs, dont certains ont ete corriges mais trop tard pour cette release).
Level up: 84%
Unread postby hpfx » 22 Apr 2016, 13:30
Bonjour critor,
Tu as piqué ma curiosité avec ces problèmes de fuites memoire... du coups j'ai essayé
critor wrote:Exemple 1 :
Et il ya des trucs que je comprends pas en fait.
Dans ta capture écran tu as des programmes, plein semble t-il. ok j'ai donc téléchargé plein de programmes.
j'ai aussi mis quelques "applications", j'ai ajouté des matrices 100x100 dans l'historique, puis j'ai fais des backup pour prendre encore plus de mémoire... plein de backup, bref...
Et en fait je n'ai pas eut de problèmes, alors quand je relis ton process, il y a un truc que je ne comprends pas, tu parles de documents, mais il s'agit de "programmes" ou de "notes" (shift-1 ou shift-0) dans mon test je n'ai pas de notes. mais c'est quoi que t’appelles "documents", c'est un abus de langage ??? car j'ai pas vu ce terme ni en FR ni en EN dans la calculatrice ?
hpfxPremium
Level up: 48%
Unread postby Lionel Debroux » 22 Apr 2016, 15:18
Les programmes en question sont générés avec le mViewer GX Creator de TI-Planet. S'il y a "beaucoup" de tels programmes, c'est pour contourner une autre limitation de fiabilité de la machine, dont critor a déjà parlé à plusieurs reprises (y compris aux devs de HP, avec vidéo et tout): en gros, les programmes mViewer GX Creator de plus de 1.5 MB font rapidement planter la machine, pendant le transfert, un peu après, ou à l'exécution du programme.
Level up: 11.3%
Return to Actualités
815 utilisateurs:
>793 invités
>14 membres
