Third-party firmware PoC...
Unread postby Lionel Debroux » 05 Jul 2014, 22:10
After recently buying a Prime, I've now spent several hours making my own armfir.elf. The result is attached.
The code fills one third of the screen with red, one third with green, and the last third with blue (with some glitches), then enters an infinite loop. Yeah, this PoC sucks, I know - it sucks just as much as my Nspire DummyOS did, more than three years ago.
Usage: copy the armfir.elf file into APPSDISK.DAT. Firmware transfer, enter recovery mode by pressing the Reset button in the hole on the back, pressing the Symb key, releasing the Reset button, and holding Symb until the Recovery mode screen appears. Then, use usbtool (Windows only).
As usual: works for me, but use at your own risk ;)
Good night.
Re: Third-party firmware PoC...
Unread postby Neo » 05 Jul 2014, 22:37
c'est parce que je me connecte en Angleterre, ou le post est uniquement en anglais?
Neo
Level up: 98.4%
Images: 311
Class: --
Unread postby Adriweb » 05 Jul 2014, 22:48
(Post uniquement en anglais pour le moment, oui (edit : cf news de critor en FR+EN :P))
Bravo en tout cas :D
PoC qui ne fait rien d'utile, mais, pas grave : c'est le fait d'avoir réussi qui est remarquable :)
Unread postby Ti64CLi++ » 03 Aug 2015, 21:29
Je ne comprends pas, qu'est-ce que c'est que le fichier APPSDISK.DAT?
Unread postby Lionel Debroux » 04 Aug 2015, 05:39
APPSDISK.DAT contient le filesystem qui contient notamment l'OS. Voir https://tiplanet.org/hpwiki/index.php?t ... ware_files
Return to Actualités
Users browsing this forum: No registered users and 13 guests
3627 utilisateurs:
>3610 invités
>10 membres
