transferencia de arquivo pdf HP PRIME
Re: transferencia de arquivo pdf HP PRIME
Unread postby Adriweb » 09 Jun 2016, 15:54
1) Please be polite by talking in English when/where it's the only common language... You see critor is already making efforts to translate.
2) Your image upload didn't finish when you sent the message, you should edit it and try again
Level up: 82.1%
Unread postby gadelha87 » 11 Jun 2016, 05:32
Também estou tendo o mesmo problema. Não consigo acessar os arquivos depois de enviar para a calculadora!
gadelha87
Level up: 56%
Unread postby arthurmorgado » 14 Jun 2016, 00:10
I'm having the same problem. The application I down is not performed in the calculator.
arthurmorgado
Niveau 3: MH (Membre Habitué)
Level up: 44%
Unread postby rcoterle » 14 Jun 2016, 11:49
pra quem não esta conseguindo converter....., quando converter, escolher o modelo da calculadora em cima, depois tem que selecionar se quer formato HPPRGN ou APP, ele fica selecionado em APP, tem que mudar para HPPRGN, espero que ajude...
rcoterle
Level up: 60%
Class: calculators
Unread postby critor » 14 Jun 2016, 12:03
You may check that you have the latest 10077 Connectivity Kit.
Old versions of the Connectivity Kit don't support applications.
Level up: 54.4%
Images: 17331
Unread postby guiaugustoreis » 01 Jul 2016, 18:23
Também estou com problemas para transferir os arquivos. liguei no suporte da Hp e me informaram que com essa atualização não será mais possível abrir os PDF's dessa forma ;(
guiaugustoreis
Niveau 6: SM (Super Membre)
Level up: 92.9%
Class: Student
Unread postby critor » 01 Jul 2016, 18:30
And which transfer way are you referring to ?
There are many ways to transfer programs or apps to an HP Prime calculator.
Level up: 54.4%
Images: 17331
Unread postby critor » 05 Jul 2016, 13:11
I am still waiting for a reply (if possible accurate and comprehensive).
Without a reply, there is no way I can help you.
And you transfer converted PDF files exactly like normal HP Prime applications or programs - it's the official way.
So your local HP support service just lied to you, probably in order to get rid of a technical question too difficult for them.
Level up: 54.4%
Images: 17331
Unread postby Alexsandre » 05 Oct 2016, 15:41
Para a galera que esta tendo dificuldades.
Para mim só resolveu quando eu fiz o downgrade da firmware da calculadora.
Url para download das firmwares antigas: ftp://ftp.hp.com/pub/calculators/Prime/Archive/
tutorial para realizar o downgrade: viewtopic.php?t=18292&p=200433
apos realizar o downgrade você terá que baixar o HP Connectivity Kit correspondente a firmware para a calculadora ser reconhecida.
For me only solved when I downgraded the calculator firmware.
Url to download the old firmwares: ftp://ftp.hp.com/pub/calculators/Prime/Archive/
tutorial to perform the downgrade: viewtopic.php?t=18292&p=200433
after performing the downgrade you will have to download the HP Connectivity Kit corresponding firmware for the calculator to be recognized.
AlexsandrePremium
Level up: 96%
Unread postby gustamais » 19 Oct 2016, 11:14
Pessoal resolvi aqui, é simplesmente como citado acima mudar para PROG, por default vem a opção APP marcada, já tava ficando louco.
gustamais
2111 utilisateurs:
>2084 invités
>20 membres
