critor wrote:I think it's been reported to work perfectly up to hardware revision AC.
Not sure about AD (manufacturing did start around January 2018), and no news since then.
It works.
Shirotaku wrote:Hello,
I've tried to compile nLoader myself, but I'm not really into this. When I try running the make_for_nMaker.sh script (no files modified, just downloaded from github), I get the following errors:Show/Hide spoilerAfficher/Masquer le spoiler
sh .\make_for_nMaker.sh
CAS_OS
rm -f *.o *.elf
rm -f ../ndless_loader.bin
arm-none-eabi-gcc -Os -Wall -W -marm -mcpu=arm926ej-s -nostdlib -nostartfiles -s -fPIE -ffreestanding -std=c11 -o ndless_loader.o -c ndless_loader.c
ndless_loader.c: In function 'ndless_loader':
ndless_loader.c:79:14: warning: this statement may fall through [-Wimplicit-fallthrough=]
os_misc++;
ndless_loader.c:80:6: note: here
case CX450_1180:
ndless_loader.c:82:14: warning: this statement may fall through [-Wimplicit-fallthrough=]
os_misc++;
ndless_loader.c:83:6: note: here
case CXC440_532:
ndless_loader.c:85:14: warning: this statement may fall through [-Wimplicit-fallthrough=]
os_misc++;
ndless_loader.c:86:6: note: here
case CX440_532:
ndless_loader.c:89:9: warning: this statement may fall through [-Wimplicit-fallthrough=]
if(cas == 1 && asicflags != 1) {
ndless_loader.c:98:6: note: here
case CXC360_546_550:
ndless_loader.c:100:14: warning: this statement may fall through [-Wimplicit-fallthrough=]
os_misc++;
ndless_loader.c:101:6: note: here
case CX360_5XX:
ndless_loader.c:149:14: warning: this statement may fall through [-Wimplicit-fallthrough=]
os_misc++;
ndless_loader.c:150:6: note: here
case CX450_1180:
ndless_loader.c:151:14: warning: this statement may fall through [-Wimplicit-fallthrough=]
os_misc++;
ndless_loader.c:152:6: note: here
case CXC440_532:
ndless_loader.c:153:14: warning: this statement may fall through [-Wimplicit-fallthrough=]
os_misc++;
ndless_loader.c:154:6: note: here
case CX440_532:
ndless_loader.c:155:14: warning: this statement may fall through [-Wimplicit-fallthrough=]
os_misc++;
ndless_loader.c:156:6: note: here
ndless_loader.c:157:14: warning: this statement may fall through [-Wimplicit-fallthrough=]
os_misc++;
ndless_loader.c:158:6: note: here
case CX360_5XX:
arm-none-eabi-ld -nostdlib -nostartfiles -e ndless_loader -PIE -T ldscript ndless_loader.o -o ndless_loader.elf
arm-none-eabi-objcopy -O binary ndless_loader.elf ../ndless_loader.bin
find: paths must precede expression
Usage: find [path...] [expression]
rm -f loader.bin loader.elf
arm-none-eabi-ld -nostdlib -nostartfiles -T ldscript -PIE -flto libgcc/*.o -o loader.elf
C:/SH/sh.exe: D:\Program Files (x86)\GNU Tools Arm Embedded\7 2018-q2-update\bin/arm-none-eabi-ld.exe: cannot execute binary file
C:\SH\make.exe: *** [loader.elf] Error 126
C:\SH\mv.exe: loader.bin: No such file or directory
CAS_OS_no_patches
rm -f *.o *.elf
os_misc++;
case CX450_1180:
os_misc++;
case CXC440_532:
os_misc++;
case CX440_532:
os_misc++;
case CX360_5XX:
os_misc++;
case CX450_1180:
os_misc++;
case CXC440_532:
os_misc++;
case CX440_532:
os_misc++;
os_misc++;
case CX360_5XX:
NONCAS_OS
rm -f *.o *.elf
os_misc++;
case CX450_1180:
os_misc++;
case CXC440_532:
os_misc++;
case CX440_532:
os_misc++;
case CX360_5XX:
os_misc++;
case CX450_1180:
os_misc++;
case CXC440_532:
os_misc++;
case CX440_532:
os_misc++;
os_misc++;
case CX360_5XX:
Maybe you can help me out a little bit?
dfgdysd wrote:Has anyone successfully generated their own nLoader images with source? The images I generated were much smaller than the ones provided.
The one's I generated (nLoader_CAS_OS.bin.tns) are 57KB and do not work in emulator.
The pre-generated images (nLoader_CAS_OS.bin.tns) provided are 224KB and they DO work in emulator.
parrotgeek1 wrote:You can't use Cygwin (or whatever you are using that has backslashes in paths), either use Linux, Mac or Ubuntu for Windows/WSL
