Concours de rentrée 2020 - défi Python de Quetzalcóatl
Re: Concours de rentrée 2020 - défi Python de Quetzalcóatl
Unread postby cent20 » 20 Oct 2020, 08:54
TIny_Hacker wrote:I'm not sure if this is the challenge of this part of the contest, but I am having trouble getting the balloon to go in the direction I want. I don't exactly even know what each argument for vol_modifier() does, so an explanation of that would be welcome as well. I initially started out kind of guessing my arguments, and I eventually got the line to go where I want. but when I added in a new vol_modifier(), it entirely messed up my first line. After that, I tried Pavel's GUI, but I couldn't get the line to even go where I wanted in the first place. Any help with either of my two problems would be welcome. Thanks!
Understanding the function of the three parameters is indeed part of the challenge, which is why they are not given, well I think. By dint of trying, starting over, analyzing, we end up understanding.Your progress will not be linear.
From 14,000 to 5,000jump (...) 4000 to 800 (...) 800 to 400 and final jump ...
Good luck.
cent20VIP++
Level up: 51.3%
Images: 67
Twitter: nsi_xyz
Unread postby Lephe » 22 Oct 2020, 17:29
The post on Planète Casio is a bit more helpful about the role of the parameters, so I think it is only fair that I translate it here.
The balloon has 2 controls. The first one regulates the amount of gas being burned, which influences vertical speed in the cave. The second seems to change the gas composition, which warps the balloon. Once the controls are input on the command board, the balloon flies itself.
Here is my hint: try different values of the first parameter with a long time (third parameter). ^^
LephePartenaire
Level up: 16.9%
Images: 42
Unread postby critor » 24 Oct 2020, 18:44
Quelques trucs et astuces pour vous aider sur PC : ;)
https://www.planet-casio.com/Fr/forums/ ... coatl.html
Level up: 53.6%
Images: 17124
Unread postby cent20 » 24 Oct 2020, 18:56
critor wrote:Quelques trucs et astuces pour vous aider sur PC : ;)
Je confirme que c'est des sacrées aides là !
RIP ma NumWorks :troll:
cent20VIP++
Level up: 51.3%
Images: 67
Twitter: nsi_xyz
Unread postby critor » 24 Oct 2020, 19:00
Ben si ça peut aider tes élèves... vous vous débrouillez après sur qui garde quoi. :p
Level up: 53.6%
Images: 17124
Unread postby TIny_Hacker » 25 Oct 2020, 13:03
cent20 wrote:I confirm that these are sacred help there!
RIP my NumWorks :troll:
No worries, at least I don't want a NumWorks... hoping that there still will be an nSpire left if I make it into the top 13 this time. :p
-- TIny_Hacker
You thought there was something else? Nope, just a boring signature 😉
TIny_HackerPremium
Level up: 0.2%
YouTube: TIny_Hacker
GitHub: TIny-Hacker
Unread postby critor » 27 Oct 2020, 11:24
Voici plus en détails le film de protection Wyngs pour ta TI-83 Premium CE (lots Gémeaux et Verseau), avec même un tuto pour réussir son installation optimale du premier coup : :bj:
viewtopic.php?f=41&t=24361&p=257009#p257009
Level up: 53.6%
Images: 17124
Unread postby critor » 30 Oct 2020, 16:10
Petite question pour les participants et lecteurs.
Je vous avais dit que l'on vous tiendrait au courant pour les lots, et désolé pas d'avancée du côté de HP.
Par contre, après plusieurs échanges Jarrety serait pour sa part prêt à faire un geste conséquent dans une certaine autre marque que vous aimez bien. ;)
Donc la question, préférez-vous :
  • Que l'on rajoute 1 lot supplémentaire avec calculatrice à ce défi ?
    Sachant que comme c'est une modification conséquente de dotation il me semblerait normal de la porter au règlement et de retarder la date limite d'au moins 1 semaine, afin que tout-le-monde ait des chances d'en prendre connaissance et d'agit en conséquence.
  • Ou bien que l'on cloture ce 2ème défi ce dimanche soir comme prévu, mais donc sans la calculatrice supplémentaire de Jarrety ?
Level up: 53.6%
Images: 17124
Unread postby NeOtuX » 30 Oct 2020, 16:40
C'est très généreux de leur part !
La solution qui consiste à ajouter le nouveau lot au troisième défi, qui n'a pas encore débuté me semble-t-il, n'est pas envisageable ? C'est une façon de contourner les problèmes respectifs des deux solutions précédentes, en laissant tout le monde au courant des mêmes infos tout en faisant honneur à ce nouveau lot ?
Sauf si bien sûr la marque en question est Symbolibre, auquel cas il faut d'urgence l'ajouter au défi en cours. :E
NeOtuXMembre UPECS
Level up: 60.2%
Unread postby TIny_Hacker » 30 Oct 2020, 16:42
I think that we should save it for the next contest, since this one already has more prizes than the other. Please don't delay the results :(
-- TIny_Hacker
TIny_HackerPremium
Level up: 0.2%
GitHub: TIny-Hacker
Users browsing this forum: ClaudeBot [spider] and 43 guests
1035 utilisateurs:
>1016 invités
>13 membres
