En tout cas j'aii informé Vogtinator des derniers posts en date de ce topic.
import linalg
import math
class array:
def __init__(self, a):
self.a = a
def __add__(self, other):
return array(linalg.add(self.a , other.a))
def __sub__(self, other):
return array(linalg.sub(self.a , other.a))
def __mul__(self, other):
if type(self)==array:
if type(other)==array:
return array(linalg.mul(self.a , other.a))
return array(linalg.mul(self.a,other))
return array(linalg.mul(self,other.a))
def __rmul__(self, other):
def __matmul__(self, other):
return __mul(self,other)
def __getitem__(self,key):
r=(self.a)[key]
if type(r)==list or type(r)==tuple:
return array(r)
return r
def __setitem__(self, key, value):
if (type(value)==array):
(self.a)[key]=value.a
else:
(self.a)[key]=value
return None
def __len__(self):
return len(self.a)
def __str__(self):
return "array("+str(self.a)+")"
def __neg__(self):
return array(-self.a)
def __pos__(self):
return self
def __abs__(self):
return array(linalg.abs(self.a))
def __round__(self):
return array(linalg.apply(round,self.a,linalg.matrix))
def __trunc__(self):
return array(linalg.apply(trunc,self.a,linalg.matrix))
def __floor__(self):
return array(linalg.apply(floor,self.a,linalg.matrix))
def __ceil__(self):
return array(linalg.apply(ceil,self.a,linalg.matrix))
def T(self):
return array(linalg.transpose(self.a))
def real(x):
if type(x)==array:
return array(linalg.re(x.a))
return x.real
def imag(x):
if type(x)==array:
return array(linalg.im(x.a))
return x.imag
def conj(x):
if type(x)==array:
return array(linalg.conj(x.a))
return linalg.conj(x)
def sin(x):
if type(x)==array:
return array(linalg.apply(math.sin,x.a,linalg.matrix))
return math.sin(x)
def cos(x):
if type(x)==array:
return array(linalg.apply(math.cos,x.a,linalg.matrix))
return math.cos(x)
def tan(x):
if type(x)==array:
return array(linalg.apply(math.tan,x.a,linalg.matrix))
return math.tan(x)
def asin(x):
if type(x)==array:
return array(linalg.apply(math.asin,x.a,linalg.matrix))
return math.asin(x)
def acos(x):
if type(x)==array:
return array(linalg.apply(math.acos,x.a,linalg.matrix))
return math.acos(x)
def atan(x):
if type(x)==array:
return array(linalg.apply(math.atan,x.a,linalg.matrix))
return math.atan(x)
def sinh(x):
if type(x)==array:
return array(linalg.apply(math.sinh,x.a,linalg.matrix))
return math.sinh(x)
def cosh(x):
if type(x)==array:
return array(linalg.apply(math.cosh,x.a,linalg.matrix))
return math.cosh(x)
def tanh(x):
if type(x)==array:
return array(linalg.apply(math.tanh,x.a,linalg.matrix))
return math.tanh(x)
def exp(x):
if type(x)==array:
return array(linalg.apply(math.exp,x.a,linalg.matrix))
return math.exp(x)
def log(x):
if type(x)==array:
return array(linalg.apply(math.log,x.a,linalg.matrix))
return math.log(x)
def size(x):
if type(x)==array:
return linalg.size(x.a)
return linalg.size(x)
def shape(x):
if type(x)==array:
return linalg.shape(x.a)
def dot(a,b):
return a*b
def transpose(a):
if type(x)==array:
return array(linalg.transpose(x.a))
def trn(a):
if type(x)==array:
return array(linalg.conj(linalg.transpose(x.a)))
return linalg.conj(linalg.transpose(x.a))
def zeros(n,m=0):
return array(linalg.zeros(n,m))
def ones(n,m=0):
return array(linalg.ones(n,m))
def eye(n):
return array(linalg.eye(n))
def det(x):
if type(x)==array:
return linalg.det(x.a)
return linalg.det(x)
def inv(x):
if type(x)==array:
return linalg.inv(x.a)
return linalg.inv(x)
def solve(a,b):
if type(a)==array:
if type(b)==array:
return array(linalg.solve(a.a,b.a))
return array(linalg.solve(a.a,b))
if type(b)==array:
return array(linalg.solve(a,b.a))
return linalg.solve(a,b)
def eig(a):
if type(a)==array:
r=linalg.eig(a.a)
return array(r[0]),array(r[1])
return linalg.eig(a)
def linspace(a,b,c):
return array(linalg.linspace(a,b,c))
def arange(a,b,c=1):
return array(linalg.arange(a,b,c))
def reshape(a,n,m):
if type(a)==array:
return array(linalg.matrix(n,m,a.a))
return linalg.matrix(n,m,a)
#platforms:
#0: TI-Nspire Ndless
#1: NumWorks
#2: G90+E / G35+E II
#3: G35+E/USB / G75/85/95
#4: TI-83PCE/84+CE
#5: CAS / HP Prime
#6: KhiCAS / Graph 90+E
#7: KhiCAS / Graph 35+E II
#8: HP Prime
def get_pf():
c256 = True
try:
if chr(256)==chr(0):
if "HP" in version():
return 5
else:
return 6 + (not white)
except:
c256 = False
try:
import sys
try:
if sys.platform=='nspire':
return 0
if sys.platform.startswith('TI-Python') or sys.platform=='Atmel SAMD21':
return 4
except:
return 3
except:
pass
if not c256:
return 2
try:
import kandinsky
return 1
except:
try:
import hpprime
return 8
except:
pass
return -1
pf=get_pf()
def get_pf_infos(pf):
#NumWorks big: 12.5x30
#NumWorks small: 16x42
#HP Prime medium: 14x39 11.5x39
#HP Prime small: 18.5x45 15.5x45
#HP Prime big: 11x35 9x35
l_vlines = (29,12,07,09,11,14,09,07,12)
l_vcols = (53,30,21,32,32,39,30,19,39)
b_vcr = 0b100011001
if pf >= 0:
return l_vlines[pf], l_vcols[pf], b_vcr // 2**pf % 2
else:
return max(l_vlines), max(l_vcols), 1
pf_vlines, pf_vcols, pf_vcr = get_pf_infos(pf)
def sgn(x):
return (x > 0) - (x < 0)
def fi_same_exp(fi1, fi2):
while fi1[1] > fi2[1]:
fi1[1] -= 1
fi1[0] *= 10
while fi2[1] > fi1[1]:
fi2[1] -= 1
fi2[0] *= 10
def fi_simpl(fi0):
while fi0[0] and not (fi0[0] % 10):
fi0[0] = fi0[0] // 10
fi0[1] += 1
return fi0
def fi_add(fi1, fi2):
return [fi1[0] + fi2[0], fi1[1]]
def fi_sub(fi1, fi2):
return [fi1[0] - fi2[0], fi1[1]]
def fi_mul(fi1, fi2):
return [fi1[0] * fi2[0], fi1[1] + fi2[1]]
def fi_div(fi1, fi2, n=0):
fi_simpl(fi2)
while len(str(fi1[0])) < n:
fi1[0] *= 10
fi1[1] -= 1
s = sgn(fi1[0]) * sgn(fi2[0])
return [abs(fi1[0]) // abs(fi2[0]) * s, fi1[1] - fi2[1]]
def fi_pi(n):
fi4 = [4, 0]
return fi_mul(fi4, fi_sub(fi_mul(fi4, fi_atgi([5, 0], n)),fi_atgi([239, 0], n)))
def fi_atgi(fi0, n):
fi1 = [1, 0]
fir = fi_div(fi1, fi0, n)
f , fie, fik, fix, fi0 = True, fi1, [3, 0], fir, fi_mul(fi0, fi0)
while fie[0]:
fix = fi_div(fix, fi0)
fie = fi_div(fix, fik)
if f:
fir = fi_sub(fir, fie)
else:
fir = fi_add(fir, fie)
fik[0] += 2
f = not f
return fir
def fi_str(fi0, n=0):
fi0, s, sr = list(fi_simpl(fi0)), "", sgn(fi0[0])
fi0[0] = abs(fi0[0])
while fi0[1] > 0 or len(str(fi0[0])) < n:
fi0[0] *= 10
fi0[1] -= 1
while fi0[0] or fi0[1] <= 0:
fi0[1] += 1
s = str(fi0[0] % 10) + s
if fi0[1] == 0: s = "." + s
if sr < 0:
s = "-" + s
return s
def printautocr(s):
if pf_vcr:
print(s)
else:
while len(s):
print(s[:pf_vcols])
s = s[pf_vcols:]
def demo(n=pf_vlines*pf_vcols - 3):
xdigits, s = 2, fi_str(fi_pi(n), n)
s = s[:-xdigits] + "(" + s[-xdigits:] + ")"
printautocr(s)
execute_from_lexer(LEX_SRC_STR, line, MP_PARSE_FILE_INPUT, true)
Users browsing this forum: ClaudeBot [spider] and 128 guests
