[removed]
C, C++, ASM...
Re: I found an exploit in boot1.5 4.4.0.8!
Unread postby parrotgeek1 » 19 Jan 2018, 18:42
Lionel Debroux wrote:With reliable code execution, you can change the contents of the virtual memory translation table to map the boot1, if it's not mapped at the suitable place (0 or A4000000, back in the day) when the boot1.5 executes.
That is the problem. Nothing is mapped there.
How do I map it? I looked at some code in ControlX to map the second 32MB of RAM, but I don't understand how it works.
parrotgeek1Programmeur
Level up: 88.2%
Unread postby critor » 19 Jan 2018, 18:44
Polydumper includes some asm code to map Boot1 at 0x00100000 :
archives_voir.php?id=3829
asm("ldr r1,=0x00000C12");
asm("mrc p15,0,r0,c2,c0,0");
asm("str r1,[r0,#4]");
asm("ldr r0,=0x00100000");
asm("mcr p15,0,r0,c8,c7,1");
Level up: 53.7%
Images: 17170
Unread postby parrotgeek1 » 19 Jan 2018, 18:58
critor wrote:Polydumper includes some asm code to map Boot1 at 0x00100000 :
Warning at PC=111E43A0: Unknown coprocessor instruction MCR EE080F37
Level up: 88.2%
Unread postby critor » 19 Jan 2018, 19:12
The real hardware won't bother. ;)
Level up: 53.7%
Images: 17170
Unread postby parrotgeek1 » 19 Jan 2018, 19:24
critor wrote:The real hardware won't bother. ;)
something else is wrong
Error at PC=00020000: Bad PC: 00020000
   Backtrace:
Frame     PrvFrame Self     Return   Start
11229444: 00000000 00000000 1132CCC0 00008800
debug> c
Reset
Boot Loader Stage 1 (3.00.99)
etc
It didn't actually map the boot1 to 0x00000000 anyway ("d 100" just shows zeros)
I changed it to ldr r0,=0x00000000, which should work...right?
Level up: 88.2%
Unread postby critor » 19 Jan 2018, 19:28
Yes the code was mapping to 0x00100000 .
Level up: 53.7%
Images: 17170
Unread postby parrotgeek1 » 19 Jan 2018, 19:30
critor wrote:Yes the code was mapping to 0x00100000 .
"I changed it to ldr r0,=0x00000000, which should work...right?"
it didn't work when it was 0x00100000 either, though.
Can you just PM me?
Level up: 88.2%
Unread postby critor » 19 Jan 2018, 19:39
I don't think it'll work on nspire_emu anyway - something is not implemented if I remember well. Boot1 dumpers don't work on nspire_emu for example.
Maybe it'll work on firebird, but I'm not sure.
It should work on a real calculator.
Level up: 53.7%
Images: 17170
Unread postby parrotgeek1 » 19 Jan 2018, 19:44
critor wrote:I don't think it'll work on nspire_emu anyway - something is not implemented if I remember well. Boot1 dumpers don't work on nspire_emu for example.
I need a method that works on nspire_emu or firebird because my CX was stolen last year (remember?)
Boot1.5 successfully *unmaps* the boot1 from 0x00000000, so there has to be a way to put it back again.
Level up: 88.2%
Unread postby critor » 19 Jan 2018, 19:49
I know. :(
I perfectly understand that's it's going to be hard (and hazardous) to develop a boot loader without an emulator.
To begin with, are you using nspire_emu or firebird ?
Level up: 53.7%
Images: 17170
3243 utilisateurs:
>3199 invités
>36 membres
