- Code: Select all
cd ../micropython-1.12/nspire/
edit the paths in the mklib script and run it.
parisse wrote:It just means that the libmicropy.a is not compiled and installed on your system.
- Code: Select all
arm-none-eabi-ld: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(graphic.o): in function `sync_screen':
/home/ubuntu/Ndless/giac-1.7.0/micropython-1.12/numworks/graphic.c:32: multiple definition of `sync_screen'; k_csdk.o:/home/ubuntu/Ndless/giac_stable/giac-1.7.0/src/k_csdk.c:367: first defined here
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(parse.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(parse.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(parsenum.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(parsenum.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(runtime.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(runtime.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(stackctrl.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(stackctrl.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(map.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(map.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(obj.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(obj.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objbool.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objbool.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objboundmeth.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objboundmeth.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objcomplex.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objcomplex.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objdict.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objdict.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objexcept.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objexcept.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objfloat.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objfloat.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objfun.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objfun.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objgenerator.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objgenerator.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objgetitemiter.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objgetitemiter.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objint.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objint.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objint_mpz.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objint_mpz.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objlist.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objlist.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objmodule.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objmodule.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objpolyiter.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objpolyiter.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objnone.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objnone.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objslice.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objslice.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objstr.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objstr.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objstrunicode.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objstrunicode.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objtuple.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objtuple.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objtype.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objtype.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(opmethods.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(opmethods.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(sequence.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(sequence.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(binary.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(binary.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(builtinimport.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(builtinimport.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(modbuiltins.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(modbuiltins.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(modcollections.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(modcollections.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(modgc.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(modgc.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(modio.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(modio.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(modmath.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(modmath.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(modcmath.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(modcmath.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(modmicropython.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(modmicropython.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(modstruct.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(modstruct.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(modsys.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(modsys.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(moduerrno.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(moduerrno.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(vm.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(vm.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(bc.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(bc.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(smallint.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(smallint.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(moductypes.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(moductypes.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(modujson.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(modujson.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(modure.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(modure.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(moduzlib.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(moduzlib.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(moduheapq.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(moduheapq.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(moduhashlib.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(moduhashlib.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(modubinascii.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(modubinascii.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(modurandom.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(modurandom.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(modos.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(modos.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(gccollect.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(gccollect.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(modnsp.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(modnsp.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(input.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(input.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(file.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(file.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(graphic.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(graphic.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(main.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(main.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(mpstate.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(mpstate.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(nlr.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(nlr.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(nlrthumb.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(nlrthumb.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(malloc.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(malloc.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(gc.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(gc.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(qstr.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(qstr.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(vstr.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(vstr.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(mpprint.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(mpprint.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(unicode.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(unicode.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(mpz.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(mpz.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(lexer.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(lexer.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(compile.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(compile.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(emitcommon.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(emitcommon.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(emitbc.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(emitbc.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(emitnarm.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(emitnarm.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(formatfloat.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(formatfloat.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(parsenumbase.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(parsenumbase.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(emitglue.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(emitglue.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(runtime_utils.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(runtime_utils.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(nativeglue.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(nativeglue.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(argcheck.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(argcheck.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(warning.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(warning.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objarray.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objarray.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objattrtuple.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objattrtuple.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objcell.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objcell.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objclosure.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objclosure.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objdeque.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objdeque.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objenumerate.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objenumerate.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objfilter.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objfilter.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objmap.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objmap.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objobject.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objobject.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objproperty.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objproperty.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objnamedtuple.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objnamedtuple.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objrange.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objrange.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objreversed.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objreversed.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objset.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objset.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objsingleton.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objsingleton.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objstringio.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objstringio.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objzip.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(objzip.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(stream.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(stream.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(builtinevex.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(builtinevex.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(builtinhelp.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(builtinhelp.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(showbc.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(showbc.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(repl.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(repl.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(unix_mphal.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(unix_mphal.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(reader.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(reader.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(scope.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(scope.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(asmbase.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(asmbase.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(asmarm.o) uses VFP register arguments, ./luagiac.luax.elf does not
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(asmarm.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(init.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(init.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(clear.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(clear.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(get_str.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(get_str.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(neg.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(neg.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(set_dfl_prec.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(set_dfl_prec.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt2-add.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt2-add.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt3-add_ui.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt3-add_ui.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(aorsmul.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(aorsmul.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(aorsmul_i.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(aorsmul_i.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(and.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(and.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(bin_uiui.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(bin_uiui.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(cdiv_q.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(cdiv_q.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(cdiv_q_ui.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(cdiv_q_ui.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(cfdiv_q_2exp.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(cfdiv_q_2exp.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(cfdiv_r_2exp.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(cfdiv_r_2exp.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt4-clear.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt4-clear.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt6-cmp.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt6-cmp.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt8-cmp_si.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt8-cmp_si.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt9-cmp_ui.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt9-cmp_ui.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(cmpabs.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(cmpabs.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(cmpabs_ui.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(cmpabs_ui.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(com.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(com.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(divexact.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(divexact.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(dive_ui.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(dive_ui.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(divis.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(divis.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(divis_ui.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(divis_ui.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(export.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(export.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(fac_ui.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(fac_ui.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(oddfac_1.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(oddfac_1.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(prodlimbs.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(prodlimbs.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(fdiv_q_ui.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(fdiv_q_ui.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(fdiv_qr.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(fdiv_qr.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(fdiv_qr_ui.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(fdiv_qr_ui.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(fdiv_r.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(fdiv_r.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(fdiv_r_ui.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(fdiv_r_ui.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(fdiv_q.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(fdiv_q.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(fdiv_ui.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(fdiv_ui.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt12-fits_slong.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt12-fits_slong.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(gcd.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(gcd.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(gcd_ui.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(gcd_ui.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(gcdext.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(gcdext.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt17-get_d.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt17-get_d.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt18-get_d_2exp.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt18-get_d_2exp.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt19-get_si.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt19-get_si.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt20-get_str.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt20-get_str.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt21-get_ui.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt21-get_ui.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(hamdist.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(hamdist.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(import.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(import.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt22-init.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt22-init.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt23-init2.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt23-init2.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(invert.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(invert.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(ior.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(ior.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt26-iset.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt26-iset.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt28-iset_si.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt28-iset_si.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(jacobi.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(jacobi.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lcm.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lcm.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lcm_ui.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lcm_ui.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mod.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mod.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt31-mul.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt31-mul.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt32-mul_2exp.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt32-mul_2exp.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mul_si.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mul_si.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt33-mul_ui.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt33-mul_ui.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt36-out_str.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt36-out_str.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(perfpow.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(perfpow.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt37-pow_ui.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt37-pow_ui.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(powm.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(powm.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(powm_ui.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(powm_ui.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(pprime_p.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(pprime_p.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(realloc.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(realloc.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(realloc2.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(realloc2.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(scan0.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(scan0.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(scan1.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(scan1.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt39-set.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt39-set.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt40-set_d.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt40-set_d.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt42-set_si.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt42-set_si.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt43-set_str.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt43-set_str.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt44-set_ui.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt44-set_ui.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(sizeinbase.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(sizeinbase.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt46-sqrt.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt46-sqrt.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt47-sub.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt47-sub.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt48-sub_ui.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt48-sub_ui.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt49-swap.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt49-swap.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(tdiv_q.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(tdiv_q.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(tdiv_q_2exp.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(tdiv_q_2exp.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(tdiv_q_ui.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(tdiv_q_ui.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(tdiv_qr.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(tdiv_qr.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(tdiv_qr_ui.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(tdiv_qr_ui.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(tdiv_r.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(tdiv_r.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(tdiv_r_2exp.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(tdiv_r_2exp.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(tstbit.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(tstbit.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(ui_pow_ui.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(ui_pow_ui.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(xor.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(xor.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mp_bases.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mp_bases.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(add_n.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(add_n.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(sub_n.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(sub_n.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt78-com.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt78-com.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mul_1.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mul_1.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(addmul_1.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(addmul_1.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(submul_1.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(submul_1.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lshift.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lshift.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(rshift.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(rshift.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(dive_1.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(dive_1.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt79-divis.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt79-divis.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(divrem.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(divrem.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(divrem_1.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(divrem_1.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(divrem_2.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(divrem_2.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mod_1.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mod_1.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mode1o.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mode1o.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(pre_mod_1.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(pre_mod_1.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mod_1_1.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mod_1_1.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mod_1_2.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mod_1_2.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt82-mul.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt82-mul.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mul_n.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mul_n.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(sqr.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(sqr.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mul_basecase.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mul_basecase.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(sqr_basecase.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(sqr_basecase.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(nussbaumer_mul.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(nussbaumer_mul.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt86-sqrtrem.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt86-sqrtrem.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt88-get_str.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt88-get_str.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt89-set_str.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt89-set_str.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt91-scan1.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt91-scan1.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt92-popcount.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt92-popcount.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt93-hamdist.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt93-hamdist.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt95-perfsqr.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt95-perfsqr.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt96-perfpow.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt96-perfpow.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(gcd_1.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(gcd_1.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt97-gcd.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt97-gcd.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt98-gcdext.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt98-gcdext.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(gcd_subdiv_step.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(gcd_subdiv_step.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(gcdext_lehmer.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(gcdext_lehmer.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(div_q.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(div_q.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt99-tdiv_qr.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt99-tdiv_qr.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(jacbase.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(jacbase.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt100-jacobi.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt100-jacobi.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt101-get_d.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt101-get_d.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(matrix22_mul1_inverse_vector.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(matrix22_mul1_inverse_vector.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(hgcd_matrix.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(hgcd_matrix.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(hgcd2.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(hgcd2.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(hgcd.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(hgcd.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(hgcd2_jacobi.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(hgcd2_jacobi.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(hgcd_jacobi.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(hgcd_jacobi.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mullo_n.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mullo_n.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mullo_basecase.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mullo_basecase.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom22_mul.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom22_mul.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom32_mul.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom32_mul.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom42_mul.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom42_mul.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom33_mul.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom33_mul.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom43_mul.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom43_mul.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom53_mul.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom53_mul.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom63_mul.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom63_mul.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom44_mul.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom44_mul.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom6h_mul.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom6h_mul.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom6_sqr.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom6_sqr.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom8h_mul.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom8h_mul.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom8_sqr.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom8_sqr.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom_couple_handling.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom_couple_handling.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom2_sqr.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom2_sqr.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom3_sqr.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom3_sqr.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom4_sqr.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom4_sqr.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom_eval_dgr3_pm1.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom_eval_dgr3_pm1.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom_eval_dgr3_pm2.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom_eval_dgr3_pm2.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom_eval_pm1.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom_eval_pm1.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom_eval_pm2.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom_eval_pm2.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom_eval_pm2exp.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom_eval_pm2exp.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom_eval_pm2rexp.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom_eval_pm2rexp.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom_interpolate_5pts.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom_interpolate_5pts.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom_interpolate_6pts.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom_interpolate_6pts.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom_interpolate_7pts.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom_interpolate_7pts.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom_interpolate_8pts.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom_interpolate_8pts.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom_interpolate_12pts.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom_interpolate_12pts.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom_interpolate_16pts.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(toom_interpolate_16pts.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(binvert.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(binvert.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mulmod_bnm1.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mulmod_bnm1.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(sqrmod_bnm1.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(sqrmod_bnm1.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(div_qr_2n_pi1.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(div_qr_2n_pi1.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(sbpi1_div_q.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(sbpi1_div_q.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(sbpi1_div_qr.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(sbpi1_div_qr.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(sbpi1_divappr_q.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(sbpi1_divappr_q.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(dcpi1_div_q.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(dcpi1_div_q.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(dcpi1_div_qr.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(dcpi1_div_qr.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(dcpi1_divappr_q.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(dcpi1_divappr_q.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mu_div_qr.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mu_div_qr.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mu_divappr_q.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mu_divappr_q.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mu_div_q.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mu_div_q.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(bdiv_q_1.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(bdiv_q_1.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(sbpi1_bdiv_q.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(sbpi1_bdiv_q.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(sbpi1_bdiv_qr.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(sbpi1_bdiv_qr.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(dcpi1_bdiv_q.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(dcpi1_bdiv_q.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(dcpi1_bdiv_qr.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(dcpi1_bdiv_qr.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mu_bdiv_qr.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mu_bdiv_qr.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(brootinv.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(brootinv.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(bsqrtinv.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(bsqrtinv.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt103-divexact.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt103-divexact.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(bdiv_dbm1c.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(bdiv_dbm1c.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt104-powm.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt104-powm.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(powlo.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(powlo.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(trialdiv.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(trialdiv.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt105-remove.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lt105-remove.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(and_n.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(and_n.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(andn_n.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(andn_n.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(ior_n.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(ior_n.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(xor_n.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(xor_n.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(copyi.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(copyi.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(copyd.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(copyd.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(comb_tables.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(comb_tables.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(invert_limb.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(invert_limb.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(addlsh1_n.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(addlsh1_n.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(sublsh1_n.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(sublsh1_n.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(rsh1add_n.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(rsh1add_n.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(rsh1sub_n.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(rsh1sub_n.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(millerrabin.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(millerrabin.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(n_pow_ui.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(n_pow_ui.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(urandomm.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(urandomm.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mod_34lsub1.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mod_34lsub1.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(pre_divrem_1.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(pre_divrem_1.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mod_1_4.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mod_1_4.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mul_fft.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mul_fft.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(pow_1.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(pow_1.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(gcdext_1.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(gcdext_1.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(jacobi_2.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(jacobi_2.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(matrix22_mul.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(matrix22_mul.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(hgcd_step.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(hgcd_step.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(hgcd_reduce.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(hgcd_reduce.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(hgcd_appr.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(hgcd_appr.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(sqrlo.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(sqrlo.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(sqrlo_basecase.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(sqrlo_basecase.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(invertappr.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(invertappr.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(bdiv_q.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(bdiv_q.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(bdiv_qr.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(bdiv_qr.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(redc_1.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(redc_1.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(redc_n.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(redc_n.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(randclr.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(randclr.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(randdef.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(randdef.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(randmts.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(randmts.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(clrbit.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(clrbit.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(setbit.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(setbit.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lshiftc.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(lshiftc.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mu_bdiv_q.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(mu_bdiv_q.o)
arm-none-eabi-ld: error: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(randmt.o): conflicting CPU architectures 13/1
arm-none-eabi-ld: failed to merge target specific data of file /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libgmp.a(randmt.o)
arm-none-eabi-ld: /home/ubuntu/Ndless/ndless-sdk/toolchain/install/lib/libmicropy.a(graphic.o): in function `os_get_pixel':
/home/ubuntu/Ndless/giac-1.7.0/micropython-1.12/numworks/graphic.c:31: undefined reference to `numworks_get_pixel'
collect2: error: ld returned 1 exit status
make: *** [Makefile.nspire:50: luagiac.luax.elf] Error 1
Adriweb wrote:Well, it's trying some NumWorks things from what I read "Ndless/giac-1.7.0/micropython-1.12/numworks/graphic.c:31: undefined reference to `numworks_get_pixel'"
Did you properly choose the Nspire-specific makefile?
make -f Makefile.nspire
patisse wrote:For sync_screen, try to comment the function definition in graphic.c, it is defined twice.
For VFP, I have no idea.
void sync_screen();
parisse wrote:I'm not sure you understood what Adriweb said. It seems that you have installed libmicropy.a for the Numworks instead of the Nspire. Make sure you are in giac-1.7.0/micropython-1.12/nspire, run mklib and copy libmicropy.a. Then try again compiling in src.
/bin/cp luagiac.luax.tns khicas.tns /home/ubuntu/Ndless/ti/ndless
/bin/cp: cannot stat 'khicas.tns': No such file or directory
make: *** [Makefile.nspire:59: luagiac.luax.tns] Error 1
luna khicas.lua khicaslua.tns
make: luna: Command not found
make: *** [Makefile.nspire:66: khicaslua.tns] Error 127
parisse wrote:The directories /shared/... are paths on my own desktop, they are not relevant, you can replace with any valid path.
parisse wrote:I'm surprised you can compile luagiac but not khicas, perhaps try make khicas.tns.
make -f Makefile.nspire khicas.tns
make-prg khicas.tns.zehn khicas.tns
Failed to load 'khicas.tns.zehn'!
make: *** [Makefile.nspire:82: khicas.tns] Error 1
parisse wrote:luna is a separate executable, it is available here https://github.com/ndless-nspire/Luna
code]make-prg khicas.tns.zehn khicas.tns
khicas.tns: $(OBJS) giacnspire.o #missing.o
nspire-ld -o giac.elf giacnspire.o $(OBJS) $(LDFLAGS)
$(GENZEHN) --compress --input giac.elf --output khicas.tns.zehn --name "giac" --uses-lcd-blit true #--240x320-support true
