Are Calc-To-Calc Connections Possible Using Ndless?
C, C++, ASM...
Re: Are Calc-To-Calc Connections Possible Using Ndless?
Unread postby catastropher » 31 Dec 2017, 01:19
Thanks, I was able to start a service. I just can't seem to write data back to the calc. I'm using libticalcs to send/receive the data from the PC side. I opened a connection to service 32767, and am able to send data to the PC. When I send something from the PC to the calc, it sends successfully and I get an ACK packet, but attempting to do an TI_NN_Read() on the calc side just times out. Does anyone know if there's anything special you need to do to make this work?
Turns out interrupts weren't enabled, despite using TCT_Local_Control_Interrupts(). I had to clear bit 7 of cpsr to enable them, but it worked! Now I need to find a way to disable the clock cursor that appears (why is this even a thing? xD)
catastropherProgrammeur
Niveau 3: MH (Membre Habitué)
Level up: 68%
Unread postby catastropher » 26 Jan 2018, 23:39
Hey guys! Does anyone know if it's possible to disable the cursor clock that appears when interrupts are enabled? I have to have them enabled for the USB code to work and I'm running in 8-bit color mode (the OS expects 16 it seems) and it causes a crash when the cursor gets moved off-screen. Thanks!
Level up: 68%
Unread postby Vogtinator » 27 Jan 2018, 08:10
catastropher wrote:Hey guys! Does anyone know if it's possible to disable the cursor clock that appears when interrupts are enabled? I have to have them enabled for the USB code to work and I'm running in 8-bit color mode (the OS expects 16 it seems) and it causes a crash when the cursor gets moved off-screen. Thanks!
How do you set the LCD mode? If you use lcd_blit or overwrite SCREEN_BASE_ADDRESS, the OS should not be able to draw on the screen anymore.
VogtinatorPremium
Level up: 1.6%
Unread postby Mumflr Fumperdink » 22 Aug 2019, 20:35
Hey, I know it's been a while since this forum was active, but I was wondering about calc-to-calc navnet. I managed to get it working when the calculators are connected but it looks like the os overrides reads from the other calc even if there is a ndless program running. Any help?
Mumflr Fumperdink
Level up: 80%
Unread postby Mumflr Fumperdink » 11 Jun 2020, 19:41
Can you send a very simple navnet program to talk between two calculators? Mine do not seem to work.
Mumflr Fumperdink
Level up: 80%
Previous
5339 utilisateurs:
>5307 invités
>26 membres
