À quand KhiCas pour TI-83 Premium CE / Edition Python ?
Re: À quand KhiCas pour TI-83 Premium CE / Edition Python ?
Unread postby Adriweb » 24 Jan 2023, 20:34
(Ok apparently it was just due to an old CEmu version, it's fine now)
Level up: 82.1%
Unread postby parisse » 24 Jan 2023, 20:34
Ok, now it does not reboot with the latest nightly build.
Level up: 95%
Unread postby parisse » 24 Jan 2023, 21:50
Everything is working now. I have a better understanding on app splitting. One question: what is the maximum size for a splitted app? Is it limited to half the free flash size?
Level up: 95%
Unread postby commandblockguy » 25 Jan 2023, 00:27
With the way that the installer currently works, yes, it won't be possible to install an app that's larger than about half the amount of free archive, since the app is allocated before the variables containing its data are deleted. If your app is large enough that that becomes an issue, I could probably use a more complicated installer that works a page at a time.
commandblockguyPremium
Level up: 46.7%
GitHub: commandblockguy
Unread postby parisse » 25 Jan 2023, 08:46
This will indeed be an issue. The smallest size of a KhiCAS port is the Casio FXCG50 port in 1 file, it is 2M large and I had a hard work by hand to make a light version discarding some parts of giac (like geometry). I expect a future ez80 port to be a little bit smaller than a sh4 port, but fitting in less than 1.5M would be a big challenge.
Level up: 95%
Unread postby parisse » 31 Jan 2023, 09:38
I have a somewhat better understanding on how things work, here is a summary, please correct me if I'm wrong.
  • SDK doc: https://ce-programming.github.io/toolchain/index.html
  • Makefile options https://ce-programming.github.io/toolch ... tions.html
  • memory layout: https://ce-programming.github.io/toolch ... c/faq.html
  • Default parameters are in CEdev/meta (and app_tools if present)
    In makefile.mk:
    BSSHEAP_LOW ?= D052C6
    BSSHEAP_HIGH ?= D13FD8
    STACK_HIGH ?= D1A87E
    INIT_LOC ?= D1A87F
  • BSSHEAP corresponds to a safe memory area that TI seems to use for temporary buffers (https://wikiti.brandonw.net/index.php?t ... By_Address).
  • According to this documentation, for a normal program running from RAM, INIT_LOC starts a 64K area that is located at the begin of UserRAM and is used for code+data+ro_data. For a flash app, code and ro_data will be in flash. This means that we have 64K for data, and only 4K for stack. 4K of stack is not enough for an application like KhiCAS, and also probably not sufficient for micropython+shell/editor. Can we set STACK_HIGH to another value? I think the global area stack+data could be "reversed", I mean stack top at 0xD2A87F and data(+code+ro_data for RAM programs) at a new position: INIT_LOC=D1987E (maybe +1 or +2)
  • other potential free RAM areas
    1023 bytes: uint8_t[1023] os_RamCode (do not use if a flash write occurs)
    size_t os_MemChk(void **free) size and position of free ram area.
    Or we could create a VarApp in RAM with no real data inside and use this area for temporary storage.
  • more complex but interesting: at 0xD40000 we have Start of VRAM. 320x240x2 bytes = 153600 bytes. Half may be used in 8 bits palette mode (graphx) if direct rendering is used (no swapping). This might be used to increase heap size by replacing malloc/free with a custom malloc like kmalloc from gint (authored by Lephe, available for Casio calculators, it should be portable to the TI83)
Level up: 95%
Unread postby commandblockguy » 01 Feb 2023, 18:26
A few other things that are worth noting:
  • The default data section for apps is not stored in userMem and is substantially smaller than that of a regular program. I forget the exact amount but believe it's under 5 KB. BSS and the stack are still in the same place.
  • AppVars in RAM can move around, and I believe that the result of os_MemChk does as well, if variables or files are modified.
  • The stack can definitely be moved around if necessary, though I believe several OS routines have checks for stack overflow that assume that the stack is in the default position.
  • You could can statically allocate memory at userMem, but this requires you to call InsertMem and update asm_prgm_size, and it needs to happen in the crt script before dynamic libraries are loaded. I could probably add an option to app_tools to do this automatically and use userMem for the data section.
  • You could in theory back up the entire contents of RAM to flash each time the app is run and restore it afterwards (the OS has a mechanism for doing this), allowing you to use the memory basically however you want, but you wouldn't be able to use most TI-OS functions, so it would involve a substantial amount of reimplementing stuff.
In other news, I'm basically done with an installer that's capable of installing much larger apps. At this point it's mostly just figuring out how to integrate it into the build system.
Level up: 46.7%
Unread postby parisse » 01 Feb 2023, 19:37
commandblockguy wrote:The default data section for apps is not stored in userMem and is substantially smaller than that of a regular program. I forget the exact amount but believe it's under 5 KB. BSS and the stack are still in the same place.
On the monochrom Casio, giac data is about 1K (ro data is of course much larger, about 160K), it should fit without any change.
Then it's not an option, except for a temporary buffer (like for example allocating the structure for the complete catalog of khicas commands).
If the checks are "as usual", they will only check that the stack pointer is >= to the system stack low at D1A87E-4K, they won't check that it's <= to D1A87E. Therefore if the stack is moved somewhere above D1A87E, it should not be a real problem, is this correct?
You could statically allocate memory at userMem, but this requires you to call InsertMem and update asm_prgm_size, and it needs to happen in the crt script before dynamic libraries are loaded. I could probably add an option to app_tools to do this automatically and use userMem for the data section.
I don't need memory for the data section, I need memory for the stack. 16K would probably be sufficient, maybe 20K (20K is what we have on the Casio, but the 83 will probably require less with many data structs of size 3 instead of 4). If we have access to more memory (say another 16K), giac may store some fixed-size data that are normally heap-allocated, this spares memory and is faster.
Great news!
Thank you a lot!
Level up: 95%
Unread postby parisse » 06 Oct 2024, 19:06
Le portage de KhiCAS sur ti83 a bien avancé récemment. Il s'agit d'une version (très) allégée de KhiCAS, mais qui devrait contenir l'essentiel, au moins pour le lycée (factorisation, développement, limites, dérivées, intégrales, mais aussi programmation en syntaxe compatible Python avec debugger pas à pas).
S'il y a des personnes intéressées pour tester une version préliminaire, vous pouvez me contacter en privé. Attention, il reste encore surement pas mal de bugs (avec risque de crash/reset) et cela nécessite de vider complètement la mémoire d'archive de votre calculatrice, une fois KhiCAS installé il reste 131Ko sur une ce et il devrait rester 65Ko sur une ce python. Et il ne faut pas espérer de miracles, le processeur de la ti83 est bien plus lent que celui d'une Casio 90 ou d'une Numworks, un calcul dure souvent une dizaine de secondes, parfois plus...
Level up: 95%
Unread postby critor » 06 Oct 2024, 21:25
parisse wrote:Et il ne faut pas espérer de miracles, le processeur de la ti83 est bien plus lent que celui d'une Casio 90 ou d'une Numworks, un calcul dure souvent une dizaine de secondes, parfois plus...
Je n'ai pas remarqué de telle lenteur, mais je n'ai testé que quelques calculs n'allant pas chercher au-delà du niveau lycée.
Level up: 54.4%
Images: 17331
1921 utilisateurs:
>1901 invités
>14 membres
