ICE Compiler
Re: ICE Compiler
Postby GalacticPirate » 15 Nov 2016, 16:45
Ti64CLi++ wrote:Nice PT_
Good chance for suit ;)
Euh, c'est anglais centre phrase ? Ça veut dire quoi ? :P
GalacticPirateModo
Level up: 1.3%
Class: M2
Re: ICE Compiler
Postby Lionel Debroux » 16 Nov 2016, 10:14
Je pense qu'il a voulu signifier "bonne chance pour la suite"...
"good luck going forward", "good luck for the next steps", "keep going on", "keep doing good work" seraient plus ou moins approchants et plus corrects.
Re: ICE Compiler
Postby Ti64CLi++ » 16 Nov 2016, 18:08
Oui, désolé pour mon anglais.
Je voulais bien dire bonne chance pour la suite:
Donc good luck going forward
Re: ICE Compiler
Postby PT_ » 16 Nov 2016, 22:13
Yay, time for another update!
I've fixed some bugs, added a little bit auto-optimization, such that if you use only once Input, it won't be in the program data but in the program itself, which saves 10 bytes. This happens too for Pause, which saves either 5 or 6 bytes (if the pause time is constant 6 bytes, otherwise 5). This is rather a small update, the next one would be v2.0 with some very nice features incoming :D
Also, I've changed the type hook, to avoid conflicts with PHASM, ICE now uses the GetKey hook, and not the GetCSC hook, because PHASM already uses that. The most important update is, that I've fixed the closing parenthesis bug. When you use for example "For(A,1,2)" it will generate an error, because of the ")". I've now changed the structure a little bit, and I hope it works now. Maybe there are some more changes, I'm not sure of ;) The Commands list is a bit updated, I've added the default value for colors/clipping. I'm not sure I've already added this in the previous version, but you can now use mean(), which calculates the mean of 2 expressions.
Have fun with it :)
Download:
archives_voir.php?id=587211
Source:
https://github.com/PeterTillema/ICE - licensed under GPL v3 :)
40%
PT_Programmeur
Level up: 57.2%
Re: ICE Compiler
Postby grosged » 17 Nov 2016, 15:16
Hey PT_ :)
I've just taken a look at your source on github, then I forked it in order to suggest little optimisations ;)
At the moment, I'm studying the file functions.asm : I think the insert routines could be faster but...the manner I think of would require disabling interruptions. As these insert routines are there for compiling only, what d'you think of it?
grosgedVIP++
Images: 92
Re: ICE Compiler
Postby PT_ » 17 Nov 2016, 22:27
grosged wrote:Hey PT_ :)
No problem, do what you want ;)
40%
PT_Programmeur
Level up: 57.2%
Re: ICE Compiler
Postby Flip » 24 Nov 2016, 11:09
Hello, I wanted to say that its impossible to make backups in the ICE compiled C programs, so It could be interesting to make a new kind of commands like "createappvar(" (just for example). It could be much more easy than type an hexadecimal ASM code to save highscores :) . Also, I've seen bug: the code below doesn't work (the sprites a totally random when displayed)
:det(0
:Goto SPRITE
:Lbl 01
:"main program code"
:Lbl SPRITE
:DefineSprite(1,XX,XX,"XXXXXXXXXXXX..."
:Goto 01
Is it normal ?
Universalis, un de mes meilleurs programmes TI 83 PCE
Avancement du projet Color Switch:
100%
feature en cours:
embellissement du gameplay
N'hésitez pas à télécharger, ça fait toujours plaisir ;) : archives_voir.php?id=873936
FlipProgrammeur
Level up: 81.9%
Class: PCSI 1ere année
Facebook: profile.php?id=100010687478140
Re: ICE Compiler
Postby PT_ » 24 Nov 2016, 13:23
External variable storage is something for ICE v2.0 which I'm currently working on ;)
And yes, that is normal. DefineSprite( is used during compiling, but you can't find it anywhere in the output program. Also, the Goto's and Lbl's are compiled just like how they are stored in the source. It's not true that whenever it hits a Goto, it searches the corresponding label, and start compiling from there. Conclusion is that you should use DefineSprite( at the totally beginning of your code, before displaying any sprite, otherwise it wouldn't work indeed. :)
40%
PT_Programmeur
Level up: 57.2%
Re: ICE Compiler
Postby Flip » 24 Nov 2016, 16:13
Thank you PT_ , I'm waiting for the next release, then :D
100%
feature en cours:
FlipProgrammeur
Level up: 81.9%
Re: ICE Compiler
Postby sautax » 24 Nov 2016, 19:46
There is a bug in your new version 1.2.4 with ram cleared ....
i go back to the 1.2.3
Mes projets :
-Environnement numworks sur PC
-TILIB
-AGAME
sautaxProgrammeur
Level up: 21.6%
Class: Terminale S-SI
YouTube: sautax
2409 utilisateurs:
>2382 invités
>20 membres
