mViewerGx & PDF HP Prime
• Page 3 of 3 • 1, 2, 3
Niveau 17: GM (Grand Maître des calculatrices)- Posts: 4513
- Images: 18
Re: mViewerGx & PDF HP Prime
Oui j'ai essayé plusieurs fois mais aucun programme avec la commande LOCAL ne marche
Jigsaw72BPremium
Niveau 3: MH (Membre Habitué)- Posts: 9
- Class: BTS Electrotechnique
- Images: 18
J'ai la version 2.1.14181 qui date du 16/10/2018
Jigsaw72BPremium
I've passed for the same problem...
Updated firmware - ok;
Updated HP connectivity kit -ok;
Reset the calculator - ok;
nothing solved my problem, but i've readed on HP forums one user talking about the same problem, he told in virtual HP prime the pdf Works perfectly and the fisical HP don't, he looked to configuration for both and see the difference, the digit grouping, need to be in this way to work (123,456.78) the calculator worked correctly again.
I've tested on mine HP prime and... works like magic! hahaha
So i can't imagine why the digit grouping affects the calculator this way.
Original link:
https://h30487.www3.hp.com/t5/Outros-pr ... d-p/647893
in the last two replys by Rogério Polo and Tocchetto (HP forum users) we can find the answer.
Original link:
Rafael_Reis
Niveau 5: MO (Membre Overclocké)- Posts: 2
Thank you very much @Rafael_Reis for your valuable information.
Now, we're going to investigate why.
Niveau 19: CU (Créateur Universel)- Posts: 42439
- Images: 17238
No problem my friend, I just wanted to help the community, after you carry out the investigations of the problem, could post here in this topic.
Rafael_Reis
Ok.
When digit grouping is set to an option with "," instead of "." as the decimal separator, it's not just about numbers, the consequences are much wider.
Program/app scripts also have to use ";" instead of "," as arguments separator in functions.
Meaning most programs/apps available online are going to fail miserably on HP Prime calculators using this setup.
- Images: 17238
- Images: 17238
