mViewer GX2, nouvelle solution conversion PDF pour HP Prime
Re: mViewer GX2, nouvelle solution conversion PDF pour HP Pr
Super travail
Donald Knuth a écrit:Beware of bugs in the above code; I have only proved it correct, not tried it.
AlexRider38Généreux
Niveau 13: CU (Calculateur Universel)- Messages: 650
- Images: 0
- Genre:
Hello. How do I transfer the generated files to the calculator ? I do not know where to place them . I upgraded my HP calculator and Conectivity Kit.
José Miguel Dos Santos
Niveau 9: IC (Compteur Infatigable)- Messages: 2
- Genre:
bonjour
Amis mon HP Prime n'ouvre le fichier PDF Abrabe ce graphique quelqu'un me aider?
sfabiano
Niveau 0: MI (Membre Inactif)- Messages: 1
- Genre:
José Miguel Dos Santos a écrit:Hello. How do I transfer the generated files to the calculator ? I do not know where to place them . I upgraded my HP calculator and Conectivity Kit.
The HP Prime doesn't support folders, so there is no location to choose.
If you've got the latest Connectivity Kit it's very simple.
As explained in the readme file, just :
- extract the downloaded zip content to a folder on your computer (available on Windows through a right-click on the downloaded file)
- drag & drop all HP-Prime files from that folder to your calculator line in the Connectivity Kit window
Niveau 19: CU (Créateur Universel)- Messages: 41578
- Images: 15112
- Genre:
- Twitter/X: critor2000
Bonjour, comme je peux voire quelle version del FW ha la HP Prime ? Merci d'avance. Salutation
Roberto74Premium
Niveau 5: MO (Membre Overclocké)- Messages: 2
- Genre:
- Classe: no
….donation Fait !!
Je un dernier question: Je fait la conversion pour HP prime G2 (dernier FW: mis a jour maintenant) mais quand j'essaie a ouvrir le ficher sur HP je vois que la premiere page de le document (9 page en total) . Aussi si je ouvre le ficher il ja 9 image.
Que peux etre ? Merci beaucop
….donation Fait !!
Roberto74Premium
- Genre:
- Classe: no
Bonjour.
Il suffit de taper
Pour changer de page si je me souviens bien, il y a entre autres
Il suffit de taper
helppour consulter l'ensemble des contrôles.
+et
- Images: 15112
- Genre:
Wow, this really works nice! One question though - Is it possible to change the default zoom level so its a bit zoomed out when scrolling through pages?
wisefox
Niveau 5: MO (Membre Overclocké)- Messages: 1
- Genre:
18 messages
• Page 2 sur 2 • 1, 2
Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 13 invités
