Update fx-9860GII to 2.09 for Netherlands HAVO VWO 2018+
Unread postby critor » 11 Feb 2017, 14:01
Hi dutch reader(s) ! :)
To use your Casio fx-9860GII for the HAVO or VWO exams, you have :
  • either to put it into exam mode if it's running OS version 2.07 or higher
  • or to reset its memory
Starting from 2018 for the HAVO and then 2019 for the VWO, the exam mode and thus OS 2.07+ become mandatory.
But don't be eagle to junk your old fx-9860GII, or to buy a brand new one ! :#non#:
You may be able to update it, and this isn't going to cost you anything ! :)
So you may keep your old one or buy a used one for cheap. ;)
You first have to determine your calculator hardware version and thus the used CPU type : either SH3 or SH4.
There are 2 very easy ways for this :
  • Look at the label below the screen. It'll be showing :
    • USB POWER GRAPHIC 2 for an SH4 calculator
    • USB POWER GRAPHIC for an SH3 calculator
  • Check the full OS version string in the SYSTEM application :
    • type
      MENU
      , then go into the SYSTEM application
    • type
      F4
      to get the system version
      You should have the full version string displayed in the XX.XX.XXXX format, with a digit in place of each X character.
    • Look at the last digit, thus the 8th one with this format. It will be :
      • 1 for an SH4 calculator
      • 0 for an SH3 calculator
SH3 calculators cannot be updated with the exam mode. :'(
But for SH4 calculators, just download and install the fx-9860GII 2.09 OS update. :bj:
Links :
Users browsing this forum: No registered users and 105 guests
2017 utilisateurs:
>2007 invités
>3 membres
