When I open manuf.img it says "Image rejected as determined unsafe if flashed on this model" please help
obster3
What's your calculator datecode and revision ?
The information is available on the back, at the right of the serial number :
- Images: 17406
obster3
Thanks.
Indeed, revision AD it more recent than revision V.
Which means the nBoot exploit won't work.
- Images: 17406
Thanks for information. Is there any way I can install Cas Os to my Nspire CX or should I spend all my money on new calculator. Thanks for the reply man I really spend around an hour for nothing.
obster3
The other way is with nLoader :
viewtopic.php?f=57&t=21094
- Images: 17406
hellooo, i recently updated my calculator to the os 4.5.3.14, i installed control x + nboot, but ndless doesn't install when the calculator finish booting, i tried wiping the ext and diag partition, reinstalled the os, and still couldn't make ndless automatically install when restart. any help please so i can fix this issue
nicopro300
Niveau 1: MD (Membre Débutant)- Posts: 3
Do you have a ndless folder on the calculator ?
What's it content ?
You may share a screen capture or picture.
What's it content ?
- Images: 17406
i have control x installed and wont load ndless on boot, i believe control x has it own way to load ndless, but here are the pictures, my calculator is revision D
nicopro300
critor wrote:The other way is with nLoader :
Hi is possible recover boot1, I have the big problem with not working calculator. Thanks so much.
ironblack15Premium
Niveau 2: MI2 (Membre Initié)- Posts: 5
