Just check the Boot2 version in the line at the top of the screen when the calculator is booting.
Niveau 19: CU (Créateur Universel)- Posts: 42404
- Images: 17124
critor wrote:Just check the Boot2 version in the line at the top of the screen when the calculator is booting.
That was one of the things I took a picture of. It says Boot2 4.3.49.
Zeklandia
Niveau 0: MI (Membre Inactif)- Posts: 6
- GitHub: Zeklandia
Why 'CAS' cannot be saved?
I have to press the 'reset' after each reboot.
zaoqi
If it's what you're talking about, the CAS/non-CAS switch can be saved by holding
while pressing
in ControlX.
![[ctrl] :nsct:](./images/smilies/nspire/ns_ct.png)
![[8] :ns8:](./images/smilies/nspire/ns_8.png)
- Images: 17124
Does that Busybox/Linux support OTG?
zaoqi
Short Question: I want to install Linux on my TI-nspire cx CAS, have the 4.5.0 OS but a Boot1 4.0.1.43 so a Boot2 4.408 Version, what can i do to install nBoot... and later Linux?
PaulR282
Sorry, nBoot won't work with Boot1 4.0.1.
And as far as I know, nLoader, the only boot helper compatible with your Boot1 version, isn't tailored to launch Linux.
- Images: 17124
critor wrote:Sorry, nBoot won't work with Boot1 4.0.1.
Also, there is no driver for the LCD on CR4+
parrotgeek1Programmeur
Thanks for pointing this out, @parrotgeek1 .
- Images: 17124
Ok, thanks for the information, but is there a way to change the boot1 version? Like flashing the boot1 image?
PaulR282
