Thank you for noticing. I've edited the post.
Niveau 19: CU (Créateur Universel)- Posts: 42404
- Images: 17124
I just noticed that, supposedly, only 965 people have downloaded nBoot, but 1216 people have downloaded controlx. How does that make sense?!
parrotgeek1Programmeur
ControlX was updated several times.
Unlike nBoot.
Unlike nBoot.
- Images: 17124
Attached is an early beta build of ControlX 4.5.1.
Supposed now to fully support Boot2 4.4.0.8 in addition to Boot2 4.0.3.49. Borrows some values from parrotgeek1's nLoader.
Thus you should now be getting Ndless auto-install and all needed OS patches whether booting on Boot2 4.0.3.49 or 4.4.0.8.
For now, only for testing on emulators, that's why I'm posting it here instead of updating the file linked in the 1st post.
No reason to update if you already have a working nBoot+ControlX setup.
Especially since both Boot2 4.0.3.49 and 4.4.0.8 are perfectly compatible with CX revisions A-V.
In the best case, you won't be getting anything more/better.
Just made it because it's possible/interesting.
- Images: 17124
critor wrote:Attached is an early beta build of ControlX 4.5.1.
Nice method of combining the 2 ndless loaders. I didn't think of that.
FYI, here is how to find the prestage in any boot2:
Open the boot2 in IDA
Edit idafindfunctions.py to have "ea = 0x11800000"
run idafindfunctions.py in IDA
Open the "names view" and sort it alphabetically
Search for "aBoot2LoadingCo"
For EACH of those results (there should be 2, one with _0), click on it and type X. You will see an address where "Loading complete"...etc" is loaded into a register, followed by a call to an identical subroutine in both instances. The address with the string load instruction is where the prestage should be copied.
Example:
- Code: Select all
RAM:1187D300 LDR R0, =aBoot2LoadingCo ; "\r\nBOOT2: loading complete (%d ticks),"...
RAM:1187D304 BL sub_118D08E4
P.S. I have a CX now!
Very interesting, thank you for your comprehensive post.
By the way, any way to launch nLoader images from ControlX ? (another useless thing, but again it's still better to support as many things as possible
"ldr ptr,=0x111C0000" after extracting the image to the provided address doesn't seem to be enough, but maybe I made something wrong.
- Images: 17124
critor wrote:"ldr ptr,=0x111C0000" after extracting the image to the provided address doesn't seem to be enough, but maybe I made something wrong.
Probably; I have no idea why that wouldn't work.
parrotgeek1 wrote:critor wrote:[/i][/list]
- CAS OS 4.5 on a non-CAS model, grab the cas_patch_4.5.0.1180.tns over there : https://github.com/deadmeatpt/TI-Nspire ... atchfinder
- CAS OS 4.4 on a non-CAS model, grab the cas_patcher_4.4.0.532.tns over there : https://github.com/parrotgeek1/TI-Nspir ... atchfinder
- CAS OS 3.9.1 on a non-CAS model, grab the cas_patcher_3.9.1.38.tns over there : https://github.com/parrotgeek1/TI-Nspir ... atchfinder
- non-CAS OS 3.9.1 on a CAS model, grab the noncas_patcher_3.9.1.38.tns over there : https://github.com/parrotgeek1/TI-Nspir ... atchfinder
The 3.9.1 patcher didn't work and was deleted.
Also, deadmeatpt's 4.5 patcher has a lot of bugs. Use the one in my repo instead
Finally you launched a official 4.5 patch
heimdall
Niveau 0: MI (Membre Inactif)- Posts: 19
- GitHub: deadmeatpt
Salut,
j'ai récemment installé controlx et il marche parfaitement, cependant, quand je tente de lancer linux (la version dont le lien est proposé dans le tuto) un mot de passe et un login me sont demandés. Est-ce normal ? Comment accéder au "bureau" linux ?
Merci d'avance
Merci d'avance
Universalis, un de mes meilleurs programmes TI 83 PCE
Avancement du projet Color Switch:
feature en cours:
embellissement du gameplay
N'hésitez pas à télécharger, ça fait toujours plaisir
FlipProgrammeur
Niveau 10: GR (Guide de Référence)- Posts: 77
- Images: 0
- Class: PCSI 1ere année
- Facebook: profile.php?id=100010687478140
La version liée n'a pas été compilée avec un gestionnaire de fenêtres.
Le login c'est "root" et il n'y a pas de mot de passe sur ce compte.
- Images: 17124
