Unread postby parrotgeek1 » 07 Feb 2018, 22:09
critor wrote:Note that ControlX is currently built for Boot1 3.0.0.99, and is not compatible with Boot1 3.0.0.DEVBUILD.
It's probably not complicated to adapt it, but I have no working TI-Nspire Color prototype to test it. :(
void (*puts)(const char *str) = (void*) 0x394; //ok
void (*load_start_boot2)() = (void*)0x1e04; //ok
void (*memset)(void* dest, int val, int size) = (void*) 0x10320;//ok
int (*read_nand)(void* dest, uint32_t size, uint32_t nand_offset, int progress_start, int progress_end, void* progress_cb) = (void*) 0xb314; //ok
int (*nand_erase_range)(uint32_t start, uint32_t end) = (void*)0xB2CC; //ok
int (*write_nand)(void* data, uint32_t size, uint32_t nand_offset) = (void*) 0xb614;//ok
void (*itoa)(uint32_t n, char* s, int radix) = (void*) 0x60; //ok
int (*is_any_key_pressed)()= (void*)0x19b24;//ok
int (*is_rc_pressed)(int row, int col) = (void*) 0x19980; //  ok
void *progress_callback = (void*) 0xA6C;//ok
void (*reset)()= (void*)0; // ok
Works fine on emulator
parrotgeek1Programmeur
Level up: 88.2%
Unread postby critor » 07 Feb 2018, 22:34
Oh, thank you.
Now I just need to find a working TI-Nspire Color. :P
Unread postby pattex16 » 19 Feb 2018, 08:35
People!!
Is there anyway to make nBoot work with Boo1-> 4.0.XX ???
Yesterday i've tried to dual boot linux with Nspire Os but couldnt get nBoot working.
Is the development still going on?
OR
would there be a way to downgrade the Boot1 version to 3.0.XX ????
pattex16
Level up: 60%
Class: 11th grade
Unread postby critor » 19 Feb 2018, 10:57
ControlX is still in development. But it's based on nBoot, which was released anonymously, and so we don't know if the development is going on for Boot1 4.0.
The SPI flaw using in Boot1 3.0.0.99 has been fixed in Boot1 4.0. That's why nBoot doesn't work anymore. But there might still be some other flaws...
If your goal is to have a reboot-proof Ndless setup, or to be able to launch any Nspire OS, you should consider the more recent nanoLoader, based on an inferior Boot1.5 exploit. Note it hasn't been released yet, so that's why it's not yet mentioned in the nBoot+Controlx tutorial, and doesn't have its own tutorial for now.
viewtopic.php?f=20&t=20938
https://github.com/parrotgeek1/TI-Nspir ... .5_exploit
But note that unlike previous ControlX and Nlaunch* boot loaders, it doesn't deal with Linux at all.
Unread postby parrotgeek1 » 19 Feb 2018, 11:10
Level up: 88.2%
Unread postby pattex16 » 19 Feb 2018, 11:28
I think i might am going to test it on an emulator for now, but it would be great to have a full linux installed on an nspire
Looking forward for updates
pattex16
Level up: 60%
Class: 11th grade
Unread postby critor » 19 Feb 2018, 11:56
parrotgeek1 wrote:DO NOT LINK TO THIS REPOSITORY
the current code in master branch would brick real hardware
Then could you provide us the right link ?
Would also be useful for me, since my local clone is probably outdated.
Unread postby pattex16 » 19 Feb 2018, 14:00
Yes, that would be awesome!
pattex16
Level up: 60%
Class: 11th grade
Unread postby parrotgeek1 » 19 Feb 2018, 20:30
Level up: 88.2%
Unread postby parrotgeek1 » 25 Feb 2018, 20:32
Level up: 88.2%
3449 utilisateurs:
>3437 invités
>4 membres
