In my opinion, for rev<W you should keep nBoot+ControlX.
nLoader does only support a small subset of TI-Nspire CX production OSes and has no boot menu (thus no possibility to recover from a brick).
It's just that the exploit is inferior (Boot1.5 instead of Boot1), making the environment much more restrictive.
Also, I don't think you have to remove nBoot+ControlX.
Just don't alter the Diags partition, and put in the Boot2 partition :
- Boot1.5 4.4
- nLoader
And then tell ControlX to boot Boot2/Boot1.5 4.4.
If it doesn't work, you'll just have to tell ControlX to boot your ExtnD/Boot2 4.0.3.
- Boot1.5 4.4
- nLoader
Niveau 19: CU (Créateur Universel)- Posts: 42524
- Images: 17364
parrotgeek1Programmeur
parrotgeek1 wrote:1) Every calculator which supports OS 3.1/3.2/3.3 can just use nlaunchy if someone wants to run that version. Although why doesn't it support 4.4/4.5? Is it abandoned?
Anyone can release a newer version supporting them.
Excale never accepted to update nLaunchy correctly for OSes 3.6 and 3.9.
I finally did it for non-color models with nLaunch CXM.
I won't spend time on including 3.6/3.9 support in nLaunch CXM, because :
- CX users able to install Nlaunch* should just install nBoot+ControlX, which is far superior in many ways
- the Nlaunch* payload size is limited and we're already pretty close to the limit, adding new OSes will imply removing other OSes
- Images: 17364
parrotgeek1 wrote:critor wrote:- CX users able to install Nlaunch* should just install nBoot+ControlX, which is far superior in many ways
It doesn't have patches for boot2 3.1/3.2 so it's really hard to install old oses because of the missing manifest
It's quite easy in my option, either :
- put a Boot2 3.1 somewhere and run it when you want to install them
- use nSwitchOs, which can install any OS
But feel free to share manifest patches for Boot2 4.0.3/4.4, I'll update ControlX to make things even easier.
- Images: 17364
So, since I was away for a few days, what does nLoader do, basically? (and what's the difference compared to ControlX)
Mon profil TI-Planet | Devenez premium ! |
Modérateur de TI-Planet.org depuis décembre 2015, et membre de la communauté depuis Mai 2015. | Cliquez ci-dessus pour faire un don à TI-Planet.org via PayPal et devenir Donateur ou Premium (à partir de 3€) ! Vous aurez accès à des générations illimitées et prioritaires avec Mviewer GX Creator, ainsi qu'au forum secret ! ![]() ![]() |
GalacticPirateModo
Niveau 16: CC2 (Commandeur des Calculatrices)- Posts: 1156
- Images: 2
- Class: M2
@GalacticPirate nLoader is another boot loader like Nlaunch* and nBoot+ControlX.
It's inferior to nBoot+ControlX, not exploiting a Boot1 flaw but a Boot1.5 flaw. So the payload has more constraints, not only about size. It's much harder to code for it.
So far it only supports a small subset of Nspire OSes (3.6, 4.4 and 4.5). No Linux, no custom boot images, and no boot menu enabling you to recover from calculators semi-bricks.
Also, doesn't work on CM calculators so far, although it could. But since 4.x OSes can't run on CM calculators anyway...
But unlike nBoot+ControlX, it works on CX HW-W+ calculators assembled since october 2015 which are a majority.
In my opinion, if you've got a CX HW A-V, just keep nBoot+ControlX.
If you've got a CX HW-W+, then install nLoader.
- Images: 17364
critor wrote:no custom boot images
Actually it will load anything that is in TI-Certificate format (and has a base address of 11800000 because I am lazy). You just have to remove patchBoot2()
Also, the payload size is essentially unlimited. You're mistaken.
The only thing preventing NAND support from working is actually my inability to *find* NAND functions in boot1.5.
