Unread postby critor » 29 Aug 2023, 16:50
In fact, what I call the Boot2 partition contains :
- the Boot1.5
- the Boot2
- nLoader
So if you use a Boot2 partition image of the calculator currently running nLoader, you'll have the right Boot1.5 coming with it.
The Boot2 flash combo is
doc
enter
2
You have to :
  • put the calculator in deep sleep mode with a long press on the restart button on the back (~2 secs)
  • press and hold the 3 keys
  • without releasing any of these keys, turn on the calculator
Level up: 54.8%
Unread postby maxflutehd » 29 Aug 2023, 17:00
So, can I use polydump for that? Or should I use nsNandMgr?
For the rest, thank you! I got into the flash mode. I can send the file with the Serial settings I found somewhere here and xModem with extraputty, right?
maxflutehd
Unread postby critor » 29 Aug 2023, 17:03
I'm not sure about polydumper in this case (altered partition table).
You'd better use BtMg :
archives_voir.php?id=10080
Level up: 54.8%
Unread postby maxflutehd » 29 Aug 2023, 17:56
Could you kindly provide me the steps to dump the whole boot2?
I'm doing: open BtMg->2 for Boot2-> 1 for Dump and then it only lets me dump the images for boot1.5 and nLdr individually.
Or should I use make_for_emulator from your github?
maxflutehd
Unread postby critor » 29 Aug 2023, 18:36
Ah, yes you're right.
I think nsMandMgr doesn't behave the same way, and will let you get a full image of the Boot2 partition.
Level up: 54.8%
Unread postby maxflutehd » 29 Aug 2023, 20:43
Thank you! It worked! But now I get a red screen on bootup. I deleted the OS with nLoader but now I still cant install an older version because of minver. Do you have any idea how I could get a compatible version on there now?
maxflutehd
Unread postby critor » 29 Aug 2023, 21:15
I wasn't sure it would work. I didn't remember if nLoader was ignoring the minver field or not, and apparently it doesn't.
Let's sum up things for this calculator :
  • too recent versions get rejected by nLoader with a red screen
  • older versions get rejected by the Boot2
I am very sorry, but if this didn't work, then I can currently see no way of bypassing the minver field in your case.
You can put back your TI-Nspire CX to normal by reflashing any clean CX Boot2 image in your Boot2 partition with the same combo :
archives_list.php?order=datemaj&multi_chaine_search=boot2
Level up: 54.8%
Unread postby maxflutehd » 30 Aug 2023, 11:11
Might there be a way to flash xControl to Boot2, to reset the minver?
I'm sure open for experimentation:)
maxflutehd
Unread postby tiagouwu » 14 Sep 2023, 05:20
Hi, if i have a "y" hardware version, what should I do? Should I try this ? I want to transform my cx into a cx CAS
tiagouwu
Level up: 93%
Unread postby critor » 14 Sep 2023, 12:37
Yes, nLoader is compatible with the Y hardware revision.
Level up: 54.8%
2602 utilisateurs:
>2581 invités
>14 membres
