Unread postby critor » 26 Feb 2018, 00:02
@chaboy34 Which calculator model are you using by the way ? CX or CX CAS ?
Do you know its hardware revision ?
Thanks. :)
Level up: 53.2%
Images: 17086
Unread postby critor » 26 Feb 2018, 00:06
parrotgeek1 wrote:Maintenance method : (any supported OS version)
Wrong. You can't downgrade without resetting minos. (this will be fixed in beta 2)
I don't remember and don't have the time to test every case this evening.
With nLoader can we install and use slightly modified supported TI-Nspire OSes ? (wouldn't validate without a boot loader)
For example light TI-Nspire OSes (boot2.img / samples.zip files removed).
Level up: 53.2%
Images: 17086
Unread postby critor » 26 Feb 2018, 00:12
Added captures for the maintenance method.
Only missing captures for the nSwitchOS method.
Level up: 53.2%
Images: 17086
Unread postby parrotgeek1 » 26 Feb 2018, 00:35
parrotgeek1Programmeur
Level up: 88.2%
Unread postby parrotgeek1 » 26 Feb 2018, 00:38
Level up: 88.2%
Unread postby critor » 26 Feb 2018, 00:45
HW-AC, very interesting. :)
No problem installing Ndless ?
Because -> https://github.com/ndless-nspire/Ndless/issues/84
Level up: 53.2%
Images: 17086
Unread postby chaboy34 » 26 Feb 2018, 00:54
no ndless installed perfectly and says installed in the top left corner
chaboy34
Unread postby chaboy34 » 26 Feb 2018, 01:26
I installed the cas os successfully and everything seems to be working as expected!!
chaboy34
Unread postby Ti64CLi++ » 26 Feb 2018, 11:14
Quelques petites corrections, comme un votre en trop, en ended en trop dans l'affichage en français, etc :)
Unread postby Bisam » 26 Feb 2018, 11:20
Should I try to install this nLoader on my CX (non CAS, rev. D) in replacement for my current nBoot+CtrlX which refuses to install CAS 4.0+ Oses even with parrotgeek1 patches ?
I didn't see anything that could break my calc... but I'd like to be sure.
I would be so glad to finally install OS 4.4 or 4.5 !!
2127 utilisateurs:
>2073 invités
>45 membres
