[FR/EN][TUTO] Downgrade OS 3.6
Re: [FR/EN][TUTO] Downgrade OS 3.6
Unread postby Adriweb » 09 Jan 2015, 03:50
Si c'est une question, ça ne devrait pas poser problème tant que l'OS est en 3.9(.0) et que c'est une CX CAS.
Si c'est une affirmation, alors tant mieux :)
Par ailleurs, tu viens probablement de révéler l'existence de telles révisions matérielles :)
La calculatrice a été achetée quand ? Et quels sont les 5 caractères avant le "P" ?
Unread postby adjeuxis » 09 Jan 2015, 11:52
elle a ete achete il ya un mois et c'est p_0614p de version 3.9.0.463
adjeuxis
Level up: 24%
Class: 1er s
Unread postby critor » 09 Jan 2015, 12:01
Donc, oui.
Unread postby adjeuxis » 09 Jan 2015, 12:06
merci beaucoup je vais installer directement ndless et pour nlauncher c pour quand??
adjeuxis
Level up: 24%
Class: 1er s
Unread postby critor » 09 Jan 2015, 12:20
Je l'ignore - aucune nouvelle.
Unread postby GGuerreiro » 25 Mar 2015, 03:02
Hello
Excuse my English.
I followed the tuto but when I go to put a previous OS to 3.0. gives the file is corrupted. I can only install the 3.6.0.550. And I have for example 1.7.
I tried all versions available here on the site less than version 3.0 and no offers.
How can I switch to another version in addition to the 3.6?
My machine is an TI-NSPIRE CAS :48tinscas:
GGuerreiro
Level up: 80%
Unread postby critor » 25 Mar 2015, 07:08
You need to install the older OS version after removing OS 3.6 through the maintenance menu.
If you failed at triggering the maintenance menu only once and let OS 3.6 reboot completely, you need to perform the whole tutorial again, as OS 3.6 does reenable the downgrade protection each time it boots.
Unread postby GGuerreiro » 25 Mar 2015, 13:34
Thanks for the reply.
But I do not failed, I made the tutorial, correct, and removed the OS 3.6 for maintenance menu.
When asked to install a new OS and the software TiNpire computer link, sending a new OS and always gives "corrupted file"
Only accepts the version 3.6 file
GGuerreiro
Level up: 80%
Unread postby critor » 25 Mar 2015, 16:14
If you get "corrupted file", it's that you still have Boot2 3.0.1 or newer.
Unread postby Syrusse » 26 Jun 2018, 16:38
critor wrote:If you get "corrupted file", it's that you still have Boot2 3.0.1 or newer.
Un petit déterrage, ce que tu dis est vrai, mais il est important de préciser qu'il faut reflash le boot2 et mettre une ancienne version avec le même outil que t'as créé (ou présent :p ) parce qu'en suivant ton tuto, on ne peut PAS mettre une rom inférieur à la 3.1 (qui installe un boot2 récent) voila, voila c'est tout ce que j'avais à dire, maintenant j'ai un ancien OS et je suis content :3
Syrusse
Level up: 13.6%
Class: TS
Previous
2916 utilisateurs:
>2900 invités
>8 membres
