Niveau 19: CU (Créateur Universel)- Posts: 42530
- Images: 17406
oh, thank you very much.
Can I ask if ndless is permanently installed after the cas mod and if the exam (press-to-test) mode is still available?
Thanks
effeffe
Thanks
effeffe
effeffe
effeffe
- GitHub: effeffe
Ndless will be automatically installed after each calculator reboot, unless you remove its files.
The exam mode still works.
- Images: 17406
Hey everyone,
I used this guide to modify my Nspire CX to have a CAS operating system. The OS version I installed was 4.5.0.1180.
Now I'm trying to return it back to CX, so I flashed the Non CAS image in Btmg and installed the latest version of CX OS: 4.5.1.
However, after the initial loading screen of the calculator, it shows a full red screen of death.
I know that v4.5.1 is not supported by nLoader yet, but I wanna make the latest version of OS work in my CX because I don't have any incentive to change it to CAS OS anymore. How can I do that?
felixlee0530
Niveau 5: MO (Membre Overclocké)- Posts: 19
- Class: IB Mathematics HL
Indeed, OS 4.5.1 is not known to nLoader yet, and nLoader refuses to boot any OS it doesn't know about.
To run OS 4.5.1, you'll need to remove/bypass nLoader.
Removing nLoader is very easy.
With BtMg, just overwrite the nLoader or Boot1.5 image in the Boot2 partition, with an official Boot2 image.
Here is CX Boot2 4.4.0.8 for example :
archives_voir.php?id=1362033
- Images: 17406
critor wrote:Indeed, OS 4.5.1 is not known to nLoader yet, and nLoader refuses to boot any OS it doesn't know about.
I know what you're talking about now.
However, I'm meeting a huge problem right now.. If I try to boot to the OS, the GDC will show a red screen, and if I try to install an OS within the supported version (e.g. CX 4.5.0.1180), the computer link software would say that I cannot install version lower than the current version (4.5.1)..
I'm dead.. what should I do? I need to boot properly to a certain OS to do this..
felixlee0530
Ok.
I'm not sure to understand, as I didn't update my nLoader calculator to 4.5.1.
If you're stuck on the red screen, then how could you try sending an older version ?
- Images: 17406
critor wrote:Ok.
I went into maintenance mode and deleted my OS, and it showed me an info to install an OS.
But I'm actually stuck because neither I can install 4.5.0.1180 OS (due to downgrade protection) nor I can boot to an os properly because of the red screen??
felixlee0530
Thanks.
Hm, I thought nLoader was disabling the downgrade protection...
Ok, assuming you performed the installation how-to accurately, let's try bypassing nLoader :
What do you get on the screen ?
- hold
- without releasing the keys, press and release the reset button on the back
- if the calculator didn't turn back on automatically, still without releasing the 3 keys, type
, 2 times if necessary
- Images: 17406
critor wrote:Thanks.
- hold
It's supposed to disable the downgrade protection but it doesn't reset BootD itself so if you EVER boot unpatched boot2 via esc+menu+- you are stuck
parrotgeek1Programmeur
Users browsing this forum: ClaudeBot [spider], sqliuchang and 9 guests
