- Images: 17406
critor wrote:Yes, it is.
thanks
applepro
Niveau 0: MI (Membre Inactif)- Posts: 17
Can I somewhere find the source code from the TI-Nspire CX CAS 4.5.0.1180 OS?
Shirotaku
Niveau 4: MC (Membre Confirmé)- Posts: 25
No, it's not open-source (contrary to the NumWorks OS, for instance)
- Images: 1211
- Twitter: adriweb
Adriweb wrote:No, it's not open-source (contrary to the NumWorks OS, for instance)
That's what I thought to myself. Thank you for the information!
Shirotaku
can I Intall it on N-0518AD?
juan4597
Shirotaku wrote:I can confirm, that this method is working on the newest hardware revision (AD)!
Yes, it works with hardware revision AD
Shirotaku
Thanks.
So nLoader works with all hardware revisions A to AD.
- Images: 17406
Hello all,
Apologies if this has been asked before, but will this tutorial successfully flash a TI-nspire CX with CAS? Here are my calculator details:
Hardware Revision N-0818AE
Boot1 Code Version: 4.0.1.43
Boot2 Code Version: 4.4.0.8
Thank you!
Thank you!
Bounty10
- Class: TI-nspire CX
same problem as others. attempted to install CAS on my CX, but it's stuck at this screen
tried following directions you've given to others but i can't seem to access the maintenance menu at all, my calculator just restarts and it's back to the loading screen with the x.
i either made a large error in the installation or my calculator is faulty. any ideas?
ezpv2
