Unread postby critor » 03 Oct 2018, 10:43
Hi.
Just take a screwdriver and completely disconnect the battery for some seconds, and then try :nses: :nsme: :nsmo: again.
This should fix the clock screen booting issue. :)
Then rebuild your nLoader image by sending and carefully selecting the right files.
Images: 17371
Unread postby Bacca » 03 Oct 2018, 12:58
critor wrote:Hi.
Thanks! you're such a great help :D
I found that my mistake was during
D4) Using its integrated file browser, navigate to the chosen nLoader_(NON)CAS_OS.bin file and select it.
D5) Then navigate to the tinspirecx_boot2_4.4.0.8.img file and select it.
I thought it was a possibility that I accidentally clicked the wrong nLoader file and I was right :whistle:
Bacca
Level up: 33.3%
Unread postby critor » 03 Oct 2018, 13:23
Thanks for the information, you're welcome. :)
Images: 17371
Unread postby hichirakuboi » 08 Nov 2018, 19:41
bonjour je possède une ti nspire cx en 4.2 modele de série V d'après la dernière lettre du numéro de série , je voudrais savoir comment la passer en CAS ? merci
hichirakuboi
Unread postby Hamza.S » 08 Nov 2018, 19:43
En suivant le tutoriel viewtopic.php?f=57&t=18920#p206415 à la lettre
Unread postby hichirakuboi » 08 Nov 2018, 19:49
Donc nboot et controlx a eux seuls font passer ma cx en CAS ?
merci :)
hichirakuboi
Unread postby Hamza.S » 08 Nov 2018, 20:11
Euh il faut ndless avant tout
Unread postby Vuash » 15 Nov 2018, 16:25
Hi, i have an ti-nspire cx.
I made each step correctly to install the cas system in my non cas calculator.
When it finishes installing the OS (tinspirecxcas_4.5.0.1180) and boot, it get stuck in clock screen, with the mouse pointer.
What im supposed to do?
Thank you.
PS: When it starts, pop ups the message that the calculator was changed to enable cas system etc.
PS2: I tried :nses: :nsme: :nsmo: and it says no OS found. Then i could only install the Cx OS, after that it asked me to install OS Again, but this time i could only install the cx cas and after it freezed again on the clock screen.
How to fix it:
Hi, i fix it by removing pdf viewer from my ndless startup folder. Thank you for the tutorial, now it works perfectly! <3
Vuash
Gender: Female
Unread postby RatMan » 26 Nov 2018, 15:57
Vuash wrote:Hi, i have an ti-nspire cx.
Thank you.
How to fix it:
Im in The same situation....
Can you please help me?
Tks
PS
I dont have nedless startup folder or i cant found it...
EDIT:
At last i have solved in this way (i dont know if it is the right way... but as work for me)
1) Im going to Maintenance Board :nsdo: :nsen: :nsee:
2) i have choose Format all poin 4 of Maintenance screen
3) I have selected "1" and aftersystem reset i
4) have reset again with combiantion :nses: :nsme: :nsmo: i have try to install cx fw
5) at last after restart it asked me to install os cas again...
5) i have installed it and all now seem works fine...
now in :nsho: 5 - 4 info i read:
TI-Nspire CX CAS
Boot1: 4.0.1.43
boot2: 4.4.0.8
RatMan
Class: 1
Unread postby applepro » 24 Dec 2018, 19:35
Is it working for boot1 4.0.1.43?
applepro
5413 utilisateurs:
>5382 invités
>23 membres
