You can remove/rename/move the ndless_resources file. The "Ndless installed!" message won't be shown anymore. But of course, Ndless programs will stop working.
The other way would be to hex-edit the string in the ndless_resources.tns file.
If I remember well it's using 2 bytes per character for this string.
- Images: 17088
I just tried to rename and remove the file and nothing happens, do I have to reset the calculator?
r14santos
Yes.
But before, why did you install nLoader, and which OS version are you using ?
You can check with
![[4] :ns4:](./images/smilies/nspire/ns_4.png)
You can check with
![[home] :nsho:](./images/smilies/nspire/ns_ho.png)
![[5] :ns5:](./images/smilies/nspire/ns_5.png)
- Images: 17088
I installed nLoader because my hardware revision is AC, I just followed the tutorial. I'm using version 4.5.0.1180.
r14santos
Yes, but what was the goal ?
Adding CAS features on a non-CAS TI-Nspire CX ?
I think you can reset your calculator.
- Images: 17088
r14santos wrote:Hi,
Hope you can help me with something I haven't understood. I just followed the tutorial to upgrade my Nspire CX and everything is working as it should. However, I'd like to remove the "Ndless installed!" message when I'm not using it, it's just annoying. I've read that if I ran the ndless_resources file the app should be uninstalled/deactivated but when I do it absolutely nothing happens. Is this normal?
And also, is it safe to delete all files that were created/dowload during the installation from the calculator?
Thanks!
I've got a custom Ndless build that doesn't show the "Ndless activated!" sign. Would you like to get it? archives_voir.php?id=1679458
Thank you critor for your easy tutorial and parrotgeek1 for having built Nloader (even if I don't like the message warning about the modified calculator, because I'm not using it for cheating
Phorphora
Niveau 3: MH (Membre Habitué)- Posts: 6
Phorphora wrote:Thank you critor for your easy tutorial and parrotgeek1 for having built Nloader (even if I don't like the message warning about the modified calculator, because I'm not using it for cheating).
You're welcome. I had to put that warning in there without a way to disable it because otherwise the cheaters would just disable it... I tried to make it not too annoying.
parrotgeek1Programmeur
Phorphora wrote:It took 3 hours to one of my friends to recompile the source code (I wasn't able to do that), so I expect only a few people can and would do it themselves.
You didn't need to do that, as critor hinted a few posts ago.
Spent a few days here and on Reddit reading up on this tutorial. HW Revision "Y" seems stable so far. Thanks again!
Diz
I think it's been reported to work perfectly up to hardware revision AC.
Not sure about AD (manufacturing did start around January 2018), and no news since then.
- Images: 17088
