Unread postby critor » 06 May 2018, 13:03
Shirotaku wrote:The OS doesn't completely remove itself.
What do you mean ?
Unread postby Shirotaku » 06 May 2018, 13:06
Shirotaku wrote:At least I can't install any OS lower than 4.5
I mean that I can't downgrade the OS. So the OS should be installed at least partially, or am I wrong?
Looks to me like the OS gets corrupted on first start.
Shirotaku
Unread postby Ed_Eng87 » 08 May 2018, 23:31
Hi guys, I am new here.
Just wondering about this.
After Upgrading to CX CAS from CX NON CAS.
How to completely resert everything back to normal? I have 4.4 version AB hardware.
Btw, if you upgrade your calc from non cas to cas does the product id change aswell?
Or is it the same product ID regardless which OS you are running?
Thanks
Ed_Eng87
Unread postby parrotgeek1 » 09 May 2018, 00:53
Ed_Eng87 wrote:Hi guys, I am new here.
Thanks
The product ID changes, but that's actually a bug; ideally it would stay the same. It will in the next version, which has an ETA of, uh, whenever I'm not busy with college.
parrotgeek1Programmeur
Level up: 88.2%
Unread postby Ed_Eng87 » 11 May 2018, 00:21
Ok, so thats a bummer :( I have some apps and if my ID changes chances are that the apps wont work.
From which step to follow to reset the calc back to default 4.4.0 NON CAS OS version without that warning at boot?
Ed_Eng87
Unread postby parrotgeek1 » 11 May 2018, 08:32
Ed_Eng87 wrote:Ok, so thats a bummer :( I have some apps and if my ID changes chances are that the apps wont work.
Step D, except with NONCAS_OS file
Can you PM me a link to the apps? I can try to see if I could patch them to work anyway. If I do, please don't post them anywhere (it's piracy)
Level up: 88.2%
Unread postby parrotgeek1 » 12 May 2018, 02:55
critor wrote:My guess is that you didn't select the right file at step D5.
It could be fixed easily by resuming at step D and being more careful.
But you need an OS for this, and apparently in your case when you send the non-CAS OS 4.5 it does remove itself on its first boot.
I don't know why, such behaviour hasn't been reported in this topic.
Maybe the boot2 partition is so corrupted that the boot2 updater fails, thus making the OS fail the "discrepancy check" and reboot.
Level up: 88.2%
Unread postby parrotgeek1 » 12 May 2018, 03:20
The downgrade protection works even with no OS at all
Level up: 88.2%
Unread postby Shirotaku » 12 May 2018, 20:33
Alright thank you for the info.
Ti-Cares is going to replace my Ti-Nspire :D
Shirotaku
Unread postby parrotgeek1 » 13 May 2018, 00:02
cool. How did you get them to do that? They normally don't replace calculators that have been modified. Still don't know what happened to yours because this tutorial has worked perfectly for a lot of people
Level up: 88.2%
2820 utilisateurs:
>2786 invités
>16 membres
>18 robots
