parrotgeek1Programmeur
Captures now added for the BtMg install OS method.
Still missing for the Maintenance and nSwitchOS methods.
Niveau 19: CU (Créateur Universel)- Posts: 42383
- Images: 17086
parrotgeek1 wrote:Maintenance method : (any supported OS version)
Wrong. You can't downgrade without resetting minos. (this will be fixed in beta 2)
Sorry, I didn't test this. (and still didn't test Boot2 4.4 outside of the emulator by the way - maybe tonight or tomorrow)
I was sure it would work, like it does we ControlX, since we have many Boot2 patches. Sorry.
- Images: 17086
parrotgeek1 wrote:parrotgeek1 wrote:critor wrote:parrotgeek1 wrote:Someone I know is trying to follow this tutorial and at step C, when he opens the boot2 file, it says document format not supported, even if he opens btmg and closes it again. Ndless is installed.
Then thank you for having the tutorial tested.
Strange. Maybe BtMg isn't in the /ndless/ folder ?
It wasn't. it was in a folder called CAS. good catch!
He's still having this problem. Os 4.5
Hm... Maybe :
- remove the /ndless/ndless.cfg file
- then relaunch and requit BtMg from the /ndless folder
- then open any .img image
- Images: 17086
Hi, I'm the one having issues with this. I'm on step C and when I try to do C5) (On the calculator, open the transferred tinspirecx_boot2_4.4.0.8.img file - this should automatically launch BtMg.) it says this document format is not supported
could you please help
chaboy34
Niveau 0: MI (Membre Inactif)- Posts: 6
critor wrote:parrotgeek1 wrote:parrotgeek1 wrote:critor wrote:parrotgeek1 wrote:Someone I know is trying to follow this tutorial and at step C, when he opens the boot2 file, it says document format not supported, even if he opens btmg and closes it again. Ndless is installed.
Hm... Maybe :All my tests on emulator are with OS 4.5, and I've had no such problem. Is Ndless still installed ?
Ndless is still installed
chaboy34 wrote:Hi, I'm the one having issues with this. I'm on step C and when I try to do C5) (On the calculator, open the transferred tinspirecx_boot2_4.4.0.8.img file - this should automatically launch BtMg.) it says this document format is not supported
Try deleting the file ndless.cfg, restarting, reopening the ndless installer, then opening and closing btmg
By the way @chaboy34, thank you for helping us improving this tutorial.
- Images: 17086
