Sortie OS 3.20 Graph 90+E avec Python
Re: Sortie OS 3.20 Graph 90+E avec Python
I swapped resource data 3069 and 3070 order by exporting then deleting and importing the same but in oposite order and saved the dll while it still was in temp folder - I wonder if it will be enough to fool the update... however another problem is the emergency os update key combination does not seem to put my cg50 into update mode - has no affect whatsoever - can someone confirm the old key combo still works please? Also if someone know that the dll i modded above will be rubbish please let me know to spare me the trouble
amazonka
Niveau 0: MI (Membre Inactif)- Posts: 18
Yes, the "OS error" key combo is the same.
It's very tricky because of the timings :
- press and hold the restart button on the back
- without releasing it, press and hold the
F2
4
AC
keys - without releasing these 3 keys, release the restart button
- now only release the
F2
4
keys together - wait a second
- now finally release the
AC
key - press and hold the
9
key - wait a second
- release the
9
key
You should now get the OS ERROR screen. - release the
key
Niveau 19: CU (Créateur Universel)- Posts: 42392
- Images: 17088
Petit test de performances en calcul avec un algo de seuil par ici :
viewtopic.php?f=49&t=20341&p=234770#p234766
La Casio Graph 90+E est à peu près 3,5 fois plus lente que la NumWorks, ce qui n'est pas mal du tout quand on précise que c'est l'un des modèles les plus rapides.
- Images: 17088
3,5 ça reste impressionnant ! Heureusement que pour le cours de maths, l'impact sera minim.
majestyofgaiaVIP+
Niveau 7: EP (Espèce Protégée: geek)- Posts: 104
Thanks, critor. Managed to push my update. All went fine besides clear memory pop up but in exam mode program and python are still disabled. One thing I noticed is os version became 03.20.1202 instead of normal update giving 03.20.0202
amazonka
Thanks for the information.
About the end of the displayed version string :
MM.mm.ABCD (MM being the major, mm being the minor)
A: Zone (0=None, 1=Australia, 2=France, 3=North America, 4=China, 5=Singapour)
B: various math input/output features: 0 (n/a), 1 (slim), 2 (all), 3 (reduced), 7 (none)
C: build option: 0 (standard), 1 (development/special)
D: Hardware (0=SH3/SH7355, 1=SH4/SH7305, 2=SH4+color)
Since A=1, it seems you flashed the firmware image for Australia.
Either you missed a third firmware image in the .dll for France...
Either it's the same firmware for France and non-australian countries, with lots of hardware checks for the exam mode then.
It's this case you'll need to find and patch them.
- Images: 17088
Got you. Thanks. Judging by resources size there are just firmwares (Australian and not) plus a bootloader of much smaller size. Following the links you posted about patching firmware - do you know what decompilng software i can use instead of IDA FOR SH4 processor please?
amazonka
- Images: 17088
Le python est pas mal mais il y a des manques surtout pour la gestion graphisme qui n'existe pas
(là la numworks a sa place d'honneur
samourai3745Programmeur
Niveau 9: IC (Compteur Infatigable)- Posts: 75
- Images: 0
- Class: BTS Informatique de Gestion, BTS Formateur d'adultes
Oui, mieux vaut alors utiliser Khicas qui propose des instructions graphiques pixelisees (point, segment, polygone, arc/cercle).
Niveau 12: CP (Calculatrice sur Pattes)- Posts: 3795
Users browsing this forum: ClaudeBot [spider] and 23 guests
