Unread postby parisse » 18 Feb 2022, 16:22
The new beta version of KhiCAS is now available in English for the FXCG50. Since I do not have a FXCG50, I do not know if it works really (I just checked on a Graph 90), let me know.
Calculator links: https://www-fourier.univ-grenoble-alpes.fr/~parisse/casio/khicas50.g3a and https://www-fourier.univ-grenoble-alpes.fr/~parisse/casio/khicas50.ac2
Emulator links: https://www-fourier.univ-grenoble-alpes.fr/~parisse/casio/emucas50.g3a and https://www-fourier.univ-grenoble-alpes.fr/~parisse/casio/khicas50.882
Level up: 93.3%
Unread postby celltx » 18 Feb 2022, 20:40
Thank you, Bernard. TheCG50 version works. Few minor issues:
1. In F4 functions catalog, I can't choose physics constants, units, geometry, or 3D (items 20-23 in the list)
2. in F6-1 Applications, the error messages are not translated to English
3. In the main window, the labels for F1-F6 keys are shorter that the screen size, so that "File" label is located in between F5 and F6 keys
Thank you again for your great work!
celltx
Niveau 3: MH (Membre Habitué)
Level up: 72%
Unread postby parisse » 18 Feb 2022, 21:42
Thanks for checking! Should be fixed now!
Level up: 93.3%
Unread postby celltx » 19 Feb 2022, 10:17
Thank you, Bernard. Indeed, works great.
There is one minor inconsistency in shortcuts in Function Catalog (F4). For example, Solve is called by Log button instead of Ln, Units is called by "," button instead of sqrt, etc.
Thank you again!
celltx
Level up: 72%
Unread postby ptijoz » 19 Feb 2022, 14:59
je suppose que ça ne concernera jamais la Casio 35+E II ?
ptijoz
Level up: 35.4%
Unread postby parisse » 19 Feb 2022, 16:48
C'est malheureusement impossible avec le materiel de la 35eii. Meme s'il reste encore un peu de flash, il n'y a pas de place en RAM pour recopier.
Level up: 93.3%
Unread postby parisse » 19 Feb 2022, 21:17
celltx wrote:Thank you, Bernard. Indeed, works great.
Yes, this is the mapping copied from the Numworks, I will update ASAP and I'll post here when it's done.
Level up: 93.3%
Unread postby parisse » 20 Feb 2022, 14:36
Now updated.
Level up: 93.3%
Unread postby celltx » 20 Feb 2022, 19:39
Thank you. Very quick!
Almost all shortcuts work. Only S<->D and + do not.
celltx
Level up: 72%
Unread postby parisse » 20 Feb 2022, 21:14
Indeed, fixed!
Level up: 93.3%
Users browsing this forum: ClaudeBot [spider] and 18 guests
1518 utilisateurs:
>1480 invités
>31 membres
