fonctions de sprite gcc4ti
Re: fonctions de sprite gcc4ti
Unread postby Michael0x18 » 24 Feb 2021, 01:40
Interesting. I tried the second one, and it works. A bit earlier, I figured out that since the 68K uses big endian, we can't do 1<<offset; it needs to be 1<<(size-offset).
Thank you yet again! I think I'm going to use the new one because it seems to be a little faster.
Michael0x18
Niveau 3: MH (Membre Habitué)
Level up: 36%
Unread postby Lionel Debroux » 24 Feb 2021, 08:30
Oh yeah, I missed that too. You could also shift right a 0x8000 value for a short, 0x80 for a byte.
The byte-sized version should indeed be marginally faster if the compiler produces a btst instruction, but not that much.
If the pixel test function is used at few call sites (say, less than 5), you should consider declaring it "inline", so as to avoid the overhead of passing arguments into the appropriate registers (or worse, on the stack, if you didn't use the -mregparm=5 compiler flag), calling into a subroutine, returning from that subroutine, and possibly adjusting the stack pointer at some point if the default stack-based calling convention is being used.
In ExtGraph, pixel operations are macros because it yields much, much better speed optimization, and sometimes size optimization as well.
Unread postby Michael0x18 » 24 Feb 2021, 17:01
True. It's called eight times within the same function. I'll declare it inline/convert it to a macro and see.
Michael0x18
Level up: 36%
Unread postby Lionel Debroux » 24 Feb 2021, 17:55
An inline function buys you type checking and other niceties that macros can't bring, so you should keep using a function :)
Unread postby Michael0x18 » 24 Feb 2021, 18:07
Okay. Got it. (And thank you yet again!)
Michael0x18
Level up: 36%
Previous
Return to Programmation
Users browsing this forum: ClaudeBot [spider] and 31 guests
1929 utilisateurs:
>1902 invités
>20 membres
