critor wrote:C'est un graphe, certes, mais pas les mêmes règles.
Cest la "meme"logique oui, pas les mêmes règles, et pas le même langage.
On est bien d'accord
#cas
from math import pi, cos, sin, floor
import sys
# RNG
rnd_seed = int(sys.argv[1]) if len(sys.argv) > 1 else 0xc0ffee
web_dim = int(sys.argv[2]) if len(sys.argv) > 2 else 36
web_density = float(sys.argv[3]) if len(sys.argv) > 3 else .05
pits_density = float(sys.argv[4]) if len(sys.argv) > 4 else .1
bats_density = float(sys.argv[5]) if len(sys.argv) > 5 else .15
def rnd():
global rnd_seed
rnd_max = 0x7fff
rnd_seed = (rnd_seed * 214013 + 2531011) % 4294967296
return ((rnd_seed // (2*rnd_max + 1)) & rnd_max)
def random():
return rnd() / 0x7fff
def randint(a,b):
return rnd() % (b-a+1) + a
def choice(l):
return l[randint(0, len(l)-1)]
screen_h = 240
m_p, m_l, m_k, m_b, m_d, m_a, m_m = 1, 4, 16, 64, 256, 1024, 4096
def insertinto(l1, l2):
for v in l1:
if v not in l2:
l2.append(v)
return l2
def removefrom(l1, l2):
for v in l1:
try:
l2.remove(v)
except:
pass
return l2
def connectPlatforms(s1, s2):
global web
web[s1][s2], web[s2][s1] = 1, 1
def get_reachable_platforms_from_platforms(l, safe):
lv = []
for s in l:
for i in range(dimweb):
if web[s][i]:
if i not in lv and (not(safe) or not (platforms[i] & m_p)):
lv.append(i)
return lv
def cango(s1, s2, safe):
lvo1, lvi1, lvo2, lvi2, t_inter, k = [], [s1], [], [s2], 0, 0
while not (t_inter) and len(lvi1) and len(lvi2):
lvo1, lvo2 = insertinto(lvo1, lvi1), insertinto(lvo2, lvi2)
for v in lvo1:
if v in lvo2:
return k
lvi1, lvi2 = get_reachable_platforms_from_platforms(lvo1, safe), get_reachable_platforms_from_platforms(lvo2, safe)
lvi1, lvi2 = removefrom(lvo1, lvi1), removefrom(lvo2, lvi2)
k += 1
return 0
def my_bitor(a, b):
return ~(~a & ~b)
def init_web(d, p_p, p_b):
global web, platforms, mwspr, mhspr, zoom, mwc, screen_w, screen_h
yweb, l0 = screen_h / 2, list(range(dimweb))
l0.remove(0)
web, platforms, conn, dconn, i_k = [], [0 for k in range(dimweb)], [0], list(range(1, dimweb)), choice(l0)
for j in range(dimweb):
web.append([0 for k in range(dimweb)])
while len(dconn):
s = dconn[randint(0, len(dconn) - 1)]
connectPlatforms(conn[randint(0, len(conn) - 1)], s)
dconn.remove(s)
conn.append(s)
for j in range(dimweb-1):
for i in range(j + 1, dimweb):
if floor(d + random()):
connectPlatforms(i, j)
i_d = choice(l0)
platforms[i_d] = my_bitor(platforms[i_d], m_d)
l1 = list(l0)
for v in get_reachable_platforms_from_platforms([0], 0):
l1.remove(v)
if not(len(l1)):
l1 = l0
l2 = list(l1)
for v in get_reachable_platforms_from_platforms(get_reachable_platforms_from_platforms([0], 0), 0):
try:
l2.remove(v)
except:
pass
if not(len(l2)):
l2 = l1
i_l = choice(l2)
platforms[i_l] = my_bitor(platforms[i_l], m_l)
platforms[i_k] = my_bitor(platforms[i_k], m_k)
for i in l1:
if i != i_k and i != i_d and floor(p_p*dimweb/len(l1) + random()):
if cango(0, i_k, 1) and cango(0, i_d, 1):
platforms[i] = my_bitor(platforms[i], m_p)
if floor(p_b*dimweb/len(l1) + random()):
platforms[i] = my_bitor(platforms[i], m_b)
def parcourir_selon(ia):
global dimweb, platforms, web_dim, web_density, pits_density, bats_density
dimweb = web_dim
maxcoups = dimweb**2 * 2
init_web(web_density, pits_density, bats_density)
s0, s1, s2, s3, s4, s5, s6, s7 = 0, 0, m_a, 0, 1, -1, 0, 0
pfs0, pfs5 = platforms[s0], 0
while s4 > 0 and (not (s2 & (2 * m_k)) or not (pfs0 & m_d)):
if s5 < 0:
s5 = 0
else:
try:
k, k2 = ia(s0, voisines, dimweb, s1, s2)
if pfs5 & (2 * m_b):
while s0 == s5:
s0 = randint(0, dimweb - 1)
pfs0, pfs5 = my_bitor(platforms[s0], m_b), pfs5 & ~(3 * m_b) & ~m_m
else:
if k2:
if s2 & m_a:
v = platforms[k]
if v & m_l:
v, s2 = v & ~m_l, my_bitor(s2, 2 * m_l)
platforms[k] = my_bitor(v, 2 * m_l)
s2 = s2 & ~m_a
s2 = my_bitor(s2, 2 * m_a)
else:
if k in voisines:
s0 = k
if pfs5 & m_b:
pfs5 = my_bitor(pfs5, 2 * m_b)
pfs0, pfs5 = platforms[s0], pfs5 & ~m_m
s3 += 1
if s3 >= maxcoups:
s4 = 0
if pfs0 & m_k:
pfs0 = pfs0 & ~m_k
s2 = my_bitor(s2, 2 * m_k)
if pfs0 & my_bitor(m_p, m_l):
s4 = 0
pfs0 = my_bitor(pfs0, 2 * m_m)
platforms[s5] = pfs5
except Exception as t_excpt:
s4 = -1
print(t_excpt)
pfs0 = my_bitor(pfs0, m_m)
s1, voisines = pfs0, get_reachable_platforms_from_platforms([s0], 0)
platforms[s0] = pfs0
for v in voisines:
t = my_bitor(m_p, m_l)
t = platforms[v] & my_bitor(t, m_k)
s1 = my_bitor(s1, t)
for v in get_reachable_platforms_from_platforms(voisines, 0):
t = platforms[v] & m_l
s, sold = my_bitor(s1, s2), my_bitor(s6, s7)
s5, s6, s7, pfs5 = s0, s1, s2, pfs0
r = s4 > 0 and s3 < maxcoups
if r:
print("win " + str(s3), file=sys.stderr)
else:
if pfs0 & m_l:
print("leviathan", file=sys.stderr)
elif pfs0 & m_p:
print("well", file=sys.stderr)
elif s3 >= maxcoups:
print("lowpower", file=sys.stderr)
elif s4 < 0:
print("exception", file=sys.stderr)
return r, s2, s3
#! /usr/bin/bash
if [[ ! "$2" ]]; then
echo "usage: $0 <nb of simulations> <l?.py file num>" >&2
exit 1
fi
base_file="l""$2"
script_file="$base_file"".py"
infos_file="$base_file"".txt"
timestamp="$(date +"%s")"
# First seed for the tests
base_seed="$2"
# Web size for the tests
web_size=36
# Web density for the tests
web_density=.05
# Pits density for the tests
pits_density=.1
# Bats density for the tests
bats_density=.15
# Number of tests
test_count="$1"
# Total time spent escaping
escape_time=0
# Number of successful escapes, falls in wells, leviathan mishaps, exceptions
escapes=0
well=0
leviathan=0
exception=0
lowpower=0
RANDOM=$base_seed
# Upper bound is the number of tests
for i in $(seq 1 $test_count); do
percent=$(echo "scale=2; $i*100/$test_count" | bc)
# echo -ne "\rseed: $i/$test_count ($percent%)..." >&2
result=$(python3 "$script_file" $RANDOM $web_size $web_density $pits_density $bats_density 2>&1 >/dev/null)
case "$result" in
"win "*)
escape_time=$(($escape_time+${result#* }))
escapes=$(($escapes+1));;
"well")
well=$(($well+1));;
"leviathan")
leviathan=$(($leviathan+1));;
"lowpower")
lowpower=$(($lowpower+1));;
"exception")
exception=$(($exception+1));;
esac
cat <<EOF > "$infos_file"
$timestamp #date
$test_count #total simulations
$i #simulations
$base_seed #seed
$web_size #web size
$web_density #web density
$pits_density #pits density
$bats_density #bats density
$escapes #successes
$escape_time #successes total steps
$leviathan #fails by Leviathan
$well #fails by well
$lowpower #fails by low power
$exception #fails by exception
EOF
done
printf "\r%40s\r" "" >&2
Type | Déplacement normal | Déplacement si clé trouvée après porte | Déplacement en cas de danger | Déplacement en cas de blocage | Condition de tir | Succès | |
Exemple fourni | aléatoire | corniche voisine au hasard | jamais | ≈7,3% | |||
critor's IA level 1 "l'attaquante" | réactive | corniche voisine au hasard | corniche voisine au hasard quand Léviathan détecté 2 fois de suite | ≈8,5% | |||
critor's IA level 2 "la peureuse" | réactive | corniche voisine au hasard | corniche précédente si puits ou Léviathan détecté | corniche voisine au hasard quand Léviathan détecté 2 fois de suite | ≈22,9% |
critor wrote:@Pavel Voici le web.py modifié que l'on utilise actuellement pour l'évaluation.
Pavel wrote:critor wrote:@Pavel Voici le web.py modifié que l'on utilise actuellement pour l'évaluation.
Merci pour les scripts! C'est très clair pour moi maintenant.
Users browsing this forum: ClaudeBot [spider], Google Adsense [Bot] and 326 guests
