Unread postby parisse » 01 Sep 2014, 08:50
Sorry, I'm not comfortable enough with bison and flex to change the parser and recognize more implicit multiplications. I'm not a fan of implicit multiplication anyway, I added it for simple cases easy to handle with bison/flex like a number times something. Now, if someone knows how to handle more complicate situations, he is welcome to modify the parser and send me something working!
Level up: 95.7%
Unread postby Levak » 01 Sep 2014, 10:50
parisse wrote:I added it for simple cases easy to handle with bison/flex like a number times something.
since e^x expands to exp(x), I would do :
expr "(" args ")" expr => mult(func($1, $2), $3)
expr "(" args ")" => func($1, $2)
Other example :
https://github.com/miromannino/MExpr/bl ... ser.y#L199
ImageTNOC [topic][DL]
nClock [topic][DL]
HideManager [topic][DL]
ZLock [topic][DL]
Theme Editor [topic][DL]
Mes programmes
LevakAdmin
Level up: 98.9%
Images: 22
Class: BAC+5: Epita (ING3)
Unread postby parisse » 02 Sep 2014, 10:15
Perhaps. The parser file from giac is input_parser.yy, feel free to make changes there. Unfortunately, it's a more complicated parser than for a math evaluator, it also handles the programming language. I don't want to make changes myself because I'm almost certain it would break something.
Level up: 95.7%
Unread postby stevenmbiz » 13 Sep 2014, 07:13
Another integration by parts as shown above, the last part of the answer should be +1/4*asin(x) instead of -1/4*acos(x), right?
stevenmbiz
Level up: 66.7%
Unread postby Bisam » 13 Sep 2014, 09:43
The answer is correct too, as acos(x)+asin(x)=pi/2 for all x in [-1,1], and two primitive functions of a given function may differ by a constant.
Unread postby stevenmbiz » 13 Sep 2014, 18:32
make sense, thank you.
stevenmbiz
Level up: 66.7%
Unread postby parisse » 24 Sep 2014, 11:22
Mise a jour avec quelques corrections de bugs, par ex.
simplify(exp(2*i*pi/7)+exp(4*i*pi/7)+exp(8*i*pi/7))
http://www-fourier.ujf-grenoble.fr/~parisse/calc/khicas.zip
Level up: 95.7%
Unread postby Bisam » 14 Nov 2014, 00:54
@parisse : J'ai réutilisé Khicas aujourd'hui pour tester le solveur d'équa diff... et j'ai noté des erreurs flagrantes !
En fait, le solveur oublie des constantes d'intégration ou bien oublie de changer leur nom au fur et à mesure que de nouvelles constantes apparaissent, même dans des cas très simples.
Par exemple :
  • desolve(y''=y',x,y) renvoie c_0 e^x au lieu de c_0 e^x + c_1
  • desolve(y''=0,x,y) renvoie x c_0 + c_0 au lieu de x c_0 + c_1
  • desolve(y'''=0,x,y) renvoie (x^2 c_0 + 2x c_0 + c_0)/2 au lieu de (x^2 c_0 + 2x c_1 + c_2)/2
  • desolve(y'''-3y'+2y=0,x,y) renvoie c_0 e^x au lieu de (x c_0 +c_1) e^x + c_2 e^(-2*x)
On voit apparaître également très souvent des "Error : Bad Argument Value", par exemple avec desolve(y''+y=0,x,y), l'erreur complète dans ce cas étant "Unable to divide, perhaps due to rounding error"
Enfin, dans des cas que je n'ai pas réussi à reproduire, j'ai obtenu une transformée inverse de Laplace... mais non calculée.
Bref, la fonction "desolve" semble avoir de gros ennuis...
Unread postby Adriweb » 14 Nov 2014, 01:54
Bisam wrote:Bref, la fonction "desolve" semble avoir de gros ennuis...
En fin de compte, si la plupart des erreurs viennent d'un problème de notation des constantes, il est possible que la correction de ce bug là suffise pour beaucoup de choses...
Enfin bref, attendons l'avis de l'expert :P
Edit : d'apres le source, ca serait la fonction diffeq_constante qui serait toujours appelée avec 0 en paramètre... ? Autrement dit, parameters.size() qui renverrait toujours 0). Toujours est-il que ca marche sur xcas en ligne, par exemple, donc... étrange.
Unread postby Lionel Debroux » 14 Nov 2014, 07:49
Autre question, qui n'a rien à voir: comment obtenir avec KhiCAS, et même Xcas desktop, la factorisation symbolique selon b du polynôme
b^3 - 2 * d1 * b^2 + (d1^2+d2) * b + d3 - d1*d2
sachant que d1, d2 et d3 sont des éléments de R+.
Users browsing this forum: ClaudeBot [spider] and 98 guests
2349 utilisateurs:
>2334 invités
>7 membres
