Accélère aussi la Flash de ton ancienne TI-83 Premium CE
• Page 3 of 3 • 1, 2, 3
Re: Accélère aussi la Flash de ton ancienne TI-83 Premium CE
Les effets sont marqués sur tiwiki
rien de bon pour des grosses valeurs non plus...
- Images: 1131
- Twitter: adriweb
Attention, Advanced Wait State Changer ne semble plus fonctionner sur les CE (révision <M) munies de versions récentes de l'OS et donc de Cesium.
Testé sur 2 83PCE différentes, avec les OS 5.6.1, 5.7.2 et 5.8.1.
Je ne constate plus aucune différence entre les réglages 4 (par défaut) et 1, sur un temps de tracé de fonction pourtant conséquent (environ 50 secondes).
Après, est-ce que ça vient des dernières versions de l'OS, de Cesium ou encore des bibliothèques C, mystère...
Niveau 19: CU (Créateur Universel)- Posts: 42389
- Images: 17088
Not sure if this is what you did but if you run prgmADVSPEED through Cesium, Cesium will reset the wait states back to 4 when you quit. I recommend running the program using ASMHOOK.
I've done some more thorough testing and found some strange results I'm stunned I never noticed before.
I updated my revision pre-A to OS 5.8.1 then ran ASMHOOK using Cesium. Then I ran prgmADVSPEED from the program menu.
If I set the wait states to 1 then quit the program, then immediately re-open the program, I can see the wait states are still at 1. I can also visually verify the calculator is faster so I know prgmADVSPEED and its subprograms are working.
However, I discovered instances where the calculator will reset the wait states back to 4 on its own. For example, if you quit the graph screen by pressing [clear], the wait states get reset back to 4. However, if you quit the graph screen by pressing [2nd] then [mode], the wait states don't get reset. I also saw this behavior on the [mode] menu, and the about screen.
I verified this behavior on OS 5.8.1, 5.4.1, 5.3.0, and 5.0.0 which means this behavior has always been present, I just never noticed it. Please let me know if you did different steps and still got your wait states reset back to 4!
thelastmillennialProgrammeur
Niveau 8: ER (Espèce Rare: nerd)- Posts: 43
- YouTube: TheLastMillennial
Thanks for your prompt reply.
I used ADVSPEED through Cesium.
Maybe last time I used ASMHOOK.
- Images: 17088
Users browsing this forum: ClaudeBot [spider] and 107 guests
