Downgrade TI-83 Premium CE en 5.3.0 peu importe le Boot Code
Re: Downgrade TI-83 Premium CE en 5.3.0 peu importe le Boot
Unread postby Hamza.S » 28 Mar 2018, 12:42
Depuis quand TI donne des explications lorsqu'il décide de bloquer des choses ?
Unread postby edgar13 » 08 Jun 2019, 17:48
Ma calculatrice fait le programme mais l'OS reste version 5.3.5.0024! :~o :~o :#fou#: :#fou#:
edgar13Modo
Level up: 97.9%
Images: 24
Class: 2eme annee de medecine
YouTube: Non
Twitter: Non
Facebook: Non
GitHub: Non
Unread postby critor » 08 Jun 2019, 17:51
Il faut envoyer l'OS juste après avoir effectué la modification.
Level up: 54.8%
Unread postby edgar13 » 09 Jun 2019, 12:37
Merci!! :D
edgar13Modo
Level up: 97.9%
Images: 24
YouTube: Non
Twitter: Non
Facebook: Non
GitHub: Non
Unread postby TheOrangeCat » 22 Jul 2019, 13:22
Can you use the tool, for example, on BOOT code 5.3.6 on TI 83 Premium CE Python Edition? I'm planning on buying one (mainly because of faster flash).
TheOrangeCat
Unread postby critor » 22 Jul 2019, 13:24
The tool should work.
But OSes older than 5.3.6 compatibility is unknown.
Level up: 54.8%
Unread postby TheOrangeCat » 22 Jul 2019, 13:32
Thanks! To test the compatability when I buy the calc, I will dump it's ROM and try it in CEmu.
TheOrangeCat
Unread postby critor » 22 Jul 2019, 13:55
Versions 5.3.6+ work in CEmu.
But this doesn't prove that older versions won't have problems on the TI-83 Premium CE Edition Python.
For example, installing versions older than 5.1.5 on TI-83 Premium CE (or TI-84 Plus CE) with Boot Code 5.1.5+ is a first step into bricking them.
Level up: 54.8%
Unread postby TheOrangeCat » 23 Jul 2019, 09:20
It could brick it but won't reusing the tool fix it? I do remember that installing an OS too old does set it to a high value but can the tool be used again to to set it to a normal value? I mean, I don't need to use the exam mode and not that I will use the Asm84CEPrgm token so I will probably buy 83PCE Python Edition anyway.
TheOrangeCat
Unread postby critor » 23 Jul 2019, 10:56
If the new OS is working, yes you can reuse the tool.
But it's not been designed to deal with unexpected issues.
Level up: 54.8%
Users browsing this forum: ClaudeBot [spider], Google Adsense [Bot] and 1417 guests
7389 utilisateurs:
>7352 invités
>28 membres
