Bugs and Request for SkinEditor of TIemu
Re: Bugs and Request for SkinEditor of TIemu
Unread postby compsystems » 28 Dec 2014, 05:23
I have optimized the keyboard map file ti89.map and ti92.map
welcome your comments
Model: TI89t
// English mapping
// TI89 (VTi-compatible)
// Functions
PCKEY_F1:TIKEY_F1
PCKEY_F2:TIKEY_F2
PCKEY_F3:TIKEY_F3
PCKEY_F4:TIKEY_F4
PCKEY_F5:TIKEY_F5
PCKEY_F6:TIKEY_F1,TIKEY_2ND
PCKEY_F7:TIKEY_F2,TIKEY_2ND
PCKEY_F8:TIKEY_F3,TIKEY_2ND
PCKEY_F9:TIKEY_APPS
//[F10]: Send
//[F11]: Debug
//[F12]: Rom
// Alphabetical
PCKEY_A:TIKEY_EQUALS,TIKEY_ALPHA
PCKEY_B:TIKEY_PALEFT,TIKEY_ALPHA
PCKEY_C:TIKEY_PARIGHT,TIKEY_ALPHA
PCKEY_D:TIKEY_COMMA,TIKEY_ALPHA
PCKEY_E:TIKEY_DIVIDE,TIKEY_ALPHA
PCKEY_F:TIKEY_PIPE,TIKEY_ALPHA
PCKEY_G:TIKEY_7,TIKEY_ALPHA
PCKEY_H:TIKEY_8,TIKEY_ALPHA
PCKEY_I:TIKEY_9,TIKEY_ALPHA
PCKEY_J:TIKEY_MULTIPLY,TIKEY_ALPHA
PCKEY_K:TIKEY_EE,TIKEY_ALPHA
PCKEY_L:TIKEY_4,TIKEY_ALPHA
PCKEY_M:TIKEY_5,TIKEY_ALPHA
PCKEY_N:TIKEY_6,TIKEY_ALPHA
PCKEY_O:TIKEY_MINUS,TIKEY_ALPHA
PCKEY_P:TIKEY_STORE,TIKEY_ALPHA
PCKEY_Q:TIKEY_1,TIKEY_ALPHA
PCKEY_R:TIKEY_2,TIKEY_ALPHA
PCKEY_S:TIKEY_3,TIKEY_ALPHA
PCKEY_T:TIKEY_T
PCKEY_U:TIKEY_PLUS,TIKEY_ALPHA
PCKEY_V:TIKEY_0,TIKEY_ALPHA
PCKEY_W:TIKEY_PERIOD,TIKEY_ALPHA
PCKEY_X:TIKEY_X
PCKEY_Y:TIKEY_Y
PCKEY_Z:TIKEY_Z
// [SPC]
PCKEY_SPACE:TIKEY_NEGATE,TIKEY_ALPHA
// Numerical Keyboard
PCKEY_0:TIKEY_0
PCKEY_1:TIKEY_1
PCKEY_2:TIKEY_2
PCKEY_3:TIKEY_3
PCKEY_4:TIKEY_4
PCKEY_5:TIKEY_5
PCKEY_6:TIKEY_6
PCKEY_7:TIKEY_7
PCKEY_8:TIKEY_8
PCKEY_9:TIKEY_9
PCKEY_NUMPAD0:TIKEY_0
PCKEY_NUMPAD1:TIKEY_1
PCKEY_NUMPAD2:TIKEY_2
PCKEY_NUMPAD3:TIKEY_3
PCKEY_NUMPAD4:TIKEY_4
PCKEY_NUMPAD5:TIKEY_5
PCKEY_NUMPAD6:TIKEY_6
PCKEY_NUMPAD7:TIKEY_7
PCKEY_NUMPAD8:TIKEY_8
PCKEY_NUMPAD9:TIKEY_9
// Cursor
PCKEY_UP:TIKEY_UP
// [v]
PCKEY_DOWN:TIKEY_DOWN
PCKEY_RIGHT:TIKEY_RIGHT
PCKEY_LEFT:TIKEY_LEFT
// Shift keys
// [Shift]: First shift
PCKEY_SHIFT_L:TIKEY_SHIFT
PCKEY_SHIFT_R:TIKEY_SHIFT
// [2nd]: Second shift // Alt PC
PCKEY_MENU:TIKEY_2ND
// [Diamond]: Third shift
PCKEY_CONTROL_L:TIKEY_DIAMOND
PCKEY_CONTROL_R:TIKEY_DIAMOND
// [Alpha]: Fourth shift
PCKEY_CAPITAL:TIKEY_ALPHA
//Explorer
// [Diamond]+[^]: Home page
//PCKEY_HOME:TIKEY_UP,TIKEY_DIAMOND
// [Diamond]+[Q]: HOME
PCKEY_HOME:TIKEY_HOME
// [2nd]+[^]: Back page
PCKEY_PRIOR:TIKEY_UP,TIKEY_2ND
// [2nd]+[v]: Next page
PCKEY_NEXT:TIKEY_DOWN,TIKEY_2ND
// [Diamont]+[v]: End page
PCKEY_END:TIKEY_DOWN,TIKEY_DIAMOND
// Operations
PCKEY_ADD:TIKEY_PLUS
PCKEY_MULTIPLY:TIKEY_MULTIPLY
PCKEY_DIVIDE:TIKEY_DIVIDE
PCKEY_SUBTRACT:TIKEY_MINUS
PCKEY_OEM_SCROLL:TIKEY_POWER
PCKEY_OEM_MINUS:TIKEY_NEGATE
// Others
// [ON]
PCKEY_OEM_3:TIKEY_ON
PCKEY_STARTKEY:TIKEY_ON
// [Enter1]
PCKEY_RETURN:TIKEY_ENTER1
//TIKEY_ENTER2
// [Esc]
PCKEY_ESCAPE:TIKEY_ESCAPE
// [Backspace <-]
PCKEY_BACK:TIKEY_BACKSPACE
//[2nd]+[BackSpace] "Insert"
PCKEY_INSERT:TIKEY_BACKSPACE,TIKEY_2ND
// [Clear]
PCKEY_DELETE:TIKEY_CLEAR
// [ -> ] "store"
PCKEY_TAB:TIKEY_STORE
PCKEY_OEM_PLUS:TIKEY_EQUALS
PCKEY_OEM_4:TIKEY_PALEFT
PCKEY_OEM_6:TIKEY_PARIGHT
PCKEY_OEM_1:TIKEY_9,TIKEY_2ND
PCKEY_OEM_7:TIKEY_1,TIKEY_2ND
PCKEY_OEM_5:TIKEY_2,TIKEY_2ND
PCKEY_OEM_COMMA:TIKEY_COMMA
PCKEY_OEM_PERIOD:TIKEY_PERIOD
PCKEY_DECIMAL:TIKEY_PERIOD
PCKEY_OEM_2:TIKEY_DIVIDE
PCKEY_OEM102:TIKEY_PIPE
//TIKEY_EE
//TIKEY_CATALOG
// Linux
PCKEY_SEPARATOR:TIKEY_ENTER1
Model: TI92
// English mapping
// TI92/VOYAGE200 (VTi-compatible)
// Functions
PCKEY_F1:TIKEY_F1
PCKEY_F2:TIKEY_F2
PCKEY_F3:TIKEY_F3
PCKEY_F4:TIKEY_F4
PCKEY_F5:TIKEY_F5
PCKEY_F6:TIKEY_F6
PCKEY_F7:TIKEY_F7
PCKEY_F8:TIKEY_F8
PCKEY_F9:TIKEY_APPS
//[F10]: Send
//[F11]: Debug
//[F12]: Rom
// Alphabetical Keyboard
PCKEY_A:TIKEY_A
PCKEY_B:TIKEY_B
PCKEY_C:TIKEY_C
PCKEY_D:TIKEY_D
PCKEY_E:TIKEY_E
PCKEY_F:TIKEY_F
PCKEY_G:TIKEY_G
PCKEY_H:TIKEY_H
PCKEY_I:TIKEY_I
PCKEY_J:TIKEY_J
PCKEY_K:TIKEY_K
PCKEY_L:TIKEY_L
PCKEY_M:TIKEY_M
PCKEY_N:TIKEY_N
PCKEY_O:TIKEY_O
PCKEY_P:TIKEY_P
PCKEY_Q:TIKEY_Q
PCKEY_R:TIKEY_R
PCKEY_S:TIKEY_S
PCKEY_T:TIKEY_T
PCKEY_U:TIKEY_U
PCKEY_V:TIKEY_V
PCKEY_W:TIKEY_W
PCKEY_X:TIKEY_X
PCKEY_Y:TIKEY_Y
PCKEY_Z:TIKEY_Z
// [SPC]
PCKEY_SPACE:TIKEY_SPACE
PCKEY_0:TIKEY_0
PCKEY_1:TIKEY_1
PCKEY_2:TIKEY_2
PCKEY_3:TIKEY_3
PCKEY_4:TIKEY_4
PCKEY_5:TIKEY_5
PCKEY_6:TIKEY_6
PCKEY_7:TIKEY_7
PCKEY_8:TIKEY_8
PCKEY_9:TIKEY_9
// Cursor
PCKEY_UP:TIKEY_UP
// [v]
// Shift keys
// [Hand]: Fourth shift
PCKEY_CAPITAL:TIKEY_HAND
//Explorer
PCKEY_HOME:TIKEY_Q,TIKEY_DIAMOND
// Operations
// Others
// [ON]
// [Enter1]
//TIKEY_ENTER2
// [Esc]
// [Backspace <-]
// [Clear]
// [ -> ] "store"
PCKEY_OEM_1:TIKEY_M,TIKEY_2ND
PCKEY_OEM_7:TIKEY_L,TIKEY_2ND
PCKEY_OEM_5:TIKEY_EQUALS,TIKEY_2ND
PCKEY_OEM102:TIKEY_K,TIKEY_2ND
//TIKEY_MODE
//TIKEY_SIN
//TIKEY_COS
//TIKEY_TAN
//TIKEY_THETA
// Linux
PCKEY_SEPARATOR:TIKEY_ENTER2
PD:
1: What is the keyword for the [Alt Gr]? PCKEY_?
2: Please include TiEmu keyboard support in Spanish ti89_spn.map & ti92_spn.map
compsystems
Level up: 41.8%
Unread postby compsystems » 19 Feb 2015, 19:45
TIEMU sometimes fails because the files are in a virtual folder.
In recent versions of Windows-os, can not change, rewrite files in the installation folder :(
for example TIEMU stored settings file on the path
C:\Program Files\TiEmu\share\tiemu\tiemu.ini
but windows does not allow store in the installation folder :(
C:\Users\username\AppData\Local\VirtualStore\Program Files\TiEmu\share\tiemu\tiemu.ini
the solution is to move these files elsewhere for windows version as
C:\Users\username\AppData\Local\TiEmu\share\tiemu\tiemu.ini
Any person, who tries to resurrect TiEmu. 0:] Or definitely bury.
compsystems
Level up: 41.8%
Unread postby compsystems » 21 Feb 2015, 00:00
Another problem encountered in TIEMU is when you hold a key with the selected pointer and then moves the pointer without releasing the left mouse button. The next key pressed unresponsive and sets the function of the previous key. :?
compsystems
Level up: 41.8%
Previous
Return to Actualités
3162 utilisateurs:
>3129 invités
>27 membres
