[removed]
C, C++, ASM...
Re: Patching 4.4.0.532 CAS to run on Non-CAS
Unread postby Lionel Debroux » 03 Feb 2017, 16:50
Up to OS 3.6, such trick didn't seem to cause any problem.
Maybe it didn't at some point later, but I remember from the OSLauncher era that it definitely did on OS 1.7.2741.
Unread postby critor » 03 Feb 2017, 17:01
Ah... no sorry in fact it doesn't work here.
Although the OS seems to work, trying to calculate anything just reboots the calculator. :P
Either I made a mistake...
Either there is another CAS/non-CAS protection...
Either it's because I have the non-CAS resource files installed, but in that case it's something relatively new - added since OS 3.6.
Having patches for 3.9-4.3 OSes would surely help to understand.
Check with your patched Nlaunchy if you can really calculate things.
Level up: 53.3%
Images: 17088
Unread postby parrotgeek1 » 03 Feb 2017, 18:53
parrotgeek1Programmeur
Level up: 88.2%
Unread postby critor » 03 Feb 2017, 19:27
parrotgeek1 wrote:There is another protection. EIGHT others. All checks of 900a002c in subtly different ways so you CAN'T patch them with one patch. There's a different one for the scratchpad vs saved documents!
Ah, great... :P
I was testing in the scratchpad.
But I've just checked and calculations are also crashing in real documents.
8 protections... so TI really doesn't want CAS on non-CAS.
Maybe there will be fewer protections in versions 4.3-3.6.
Level up: 53.3%
Images: 17088
Unread postby parrotgeek1 » 03 Feb 2017, 19:52
Level up: 88.2%
Unread postby parrotgeek1 » 03 Feb 2017, 22:16
Level up: 88.2%
Unread postby Bisam » 03 Feb 2017, 22:49
Are you sure all these are protections ?
The OS might also check if CAS is present when using CAS functions which also can work on non-CAS.
When trying that, it returns a generic message instead of using the CAS version of the function.
Unread postby parrotgeek1 » 03 Feb 2017, 23:18
Level up: 88.2%
Unread postby critor » 03 Feb 2017, 23:24
parrotgeek1 wrote:update: a very skilled programmer on twitter is helping me automatically find and patch these
Great ! :bj:
An anonymous programmer. ;)
Did you check if there are also hundreds of protections to patch in older OS 3.6-4.3 ?
Level up: 53.3%
Images: 17088
Unread postby parrotgeek1 » 04 Feb 2017, 00:06
Level up: 88.2%
1218 utilisateurs:
>1174 invités
>37 membres
