Patch boot2 1.0.526 to work on CAS+ EVT!
C, C++, ASM...
Re: Patch boot2 1.0.526 to work on CAS+ EVT!
Unread postby critor » 09 May 2017, 21:03
Do you have one ?
And what's the problem with 0D ?
Level up: 53.4%
Images: 17088
Unread postby parrotgeek1 » 09 May 2017, 21:09
critor wrote:Do you have one ?
No
I tested it by patching the viewscreen check in boot1 1.0.491 (it's the function called before it prints "ViewScreen Adapter") to return 1
Having the product ID be 0D means that it can not boot CAS+ boot2 or diags. (It checks the signatures also)
So is there any kind of exploit of old boot1?
parrotgeek1Programmeur
Level up: 88.2%
Unread postby critor » 09 May 2017, 21:22
TI-Nspire Lab Cradle Boot2/OS also share the 0D id.
But they probably use different signing keys...
Level up: 53.4%
Images: 17088
Unread postby parrotgeek1 » 09 May 2017, 21:23
critor wrote:Lab Cradle Boot2/OS also share the 0D id.
it's not even OMAP, so useless to try
Level up: 88.2%
Unread postby critor » 09 May 2017, 21:29
Note that the missing J7/J010 connectors could be JTAG...
368 367
Level up: 53.4%
Images: 17088
Unread postby parrotgeek1 » 09 May 2017, 21:45
critor wrote:Note that the missing J7/J010 connectors could be JTAG...
368 367
I think connecting the NAND to something like this could be a lot easier than jtag
but this is kind of expensive
http://www.ebay.com/itm/FlashcatUSB-Pro ... Sw44BYJVrC
supports specifically nandXXXXw3a and also samsung 1 gbit, micron, winbond..
so EVERY nspire nand! could be so helpful to unbrick
or this gpio nand
https://www.kernel.org/doc/Documentatio ... l-nand.txt
could connect nand to gpio pins of raspberry pi
Level up: 88.2%
Unread postby critor » 14 May 2017, 18:35
I've newsed about this, today :
viewtopic.php?p=216746#p216746
I've also posted about it on cnCalc, but nobody seemed to care.
Anyway, for some reason I don't know about, cnCalc current activity is nothing like what it used to be 2-3 years ago...
Level up: 53.4%
Images: 17088
Unread postby parrotgeek1 » 14 May 2017, 19:28
critor wrote:Anyway, for some reason I don't know about, cnCalc current activity is nothing like what it used to be 2-3 years ago...
Neither is the activity on cemetech or omnimaga. People just don't program calculators anymore I guess.
Level up: 88.2%
Unread postby critor » 14 May 2017, 19:51
Cemetech and CodeWalrus aren't very productive this year, compared to last year.
But the problem is the same : it's a main admin which became suddenly less active/productive this year.
And as a consequence, the members become less active/productive, and fewer new members are attracted.
On cnCalc, the activity decrease suddenly happened around 2 years ago.
Omnimaga is long dead, because of the stupid behaviour the admin team had with many productive members in 2013-2014, proving its communication and interaction skills to be very low.
Just check the graph :
After trying to improve things for months without any persistent results, almost the whole Omnimaga community did leave to create and move to CodeWalrus.
[EDIT Admin]: split topic to here: viewtopic.php?f=33&t=19997
Level up: 53.4%
Images: 17088
Unread postby parrotgeek1 » 17 May 2017, 19:55
critor wrote:DVT 1.0.526 Boot1/Boot2 images :
archives_voir.php?id=944764
archives_voir.php?id=944773
You may have fun diffing them with the PVT ones. ;)
Very few differences!
➜ nspire_emu_070 xxd tinspirecasp_boot1_1.0.526_dev.tns > xxd526dev.txt
➜ nspire_emu_070 xxd tinspirecas__boot1_1.0.526.tns > xxd526prd.txt
➜ nspire_emu_070 diff xxd526prd.txt xxd526dev.txt
10946,10947c10946,10947
< 0002ac10: 3030 362f 382f 3131 2c20 363a 3235 3a31 006/8/11, 6:25:1
< 0002ac20: 380d 0a00 436f 7079 7269 6768 7420 2863 8...Copyright (c
> 0002ac10: 3030 362f 382f 3131 2c20 363a 3138 3a33 006/8/11, 6:18:3
> 0002ac20: 330d 0a00 436f 7079 7269 6768 7420 2863 3...Copyright (c
10950,10951c10950,10951
< 0002ac50: 7261 7465 640d 0a00 5573 696e 6720 7072 rated...Using pr
< 0002ac60: 6f64 7563 7469 6f6e 206b 6579 730d 0a00 oduction keys...
> 0002ac50: 7261 7465 640d 0a00 5573 696e 6720 6465 rated...Using de
> 0002ac60: 7665 6c6f 7065 7220 6b65 7973 0d0a 0000 veloper keys....
12514,12522c12514,12522
< 00030e10: 3081 8902 8181 00e6 dbcf f8c4 d7bb cd2d 0..............-
< 00030e20: c121 29ea bcb0 b4c6 de6c fc5d 11fe 8829 .!)......l.]...)
< 00030e30: b682 f1fa 99ea 5876 225a 60b2 e743 65d8 ......Xv"Z`..Ce.
< 00030e40: 14e2 1187 d5e5 b336 8717 7645 d625 9c34 .......6..vE.%.4
< 00030e50: 5f94 7bd2 8bd6 8f42 6f09 44b0 dddf 49bd _.{....Bo.D...I.
< 00030e60: 234e 612c 2196 eafa 2a78 9f9a 87c4 d705 #Na,!...*x......
< 00030e70: 5c38 1abc b963 619a 62ca 51ba 00fa 37f9 \8...ca.b.Q...7.
< 00030e80: 2f08 f5a5 2384 df06 eeec 4479 625b cab0 /...#.....Dyb[..
< 00030e90: 883e 6c0d a9a3 fd02 0301 0001 2073 0002 .>l......... s..
> 00030e10: 3081 8902 8181 00ce e676 22c4 ae3f 24d1 0........v"..?$.
> 00030e20: 2473 61e4 5590 33af eac3 2790 a355 2ee9 $sa.U.3...'..U..
> 00030e30: 728b b149 d635 fce4 7bfd 9d61 6046 3881 r..I.5..{..a`F8.
> 00030e40: 43ba 34ae 94ee b00a bc9b 4155 2762 e9ed C.4.......AU'b..
> 00030e50: 0201 927a 71ea 7a8d 6020 558f b5f8 2a28 ...zq.z.` U...*(
> 00030e60: bc2d 3c92 dd25 7a59 9a02 eaf5 8717 4044 .-<..%zY......@D
> 00030e70: 476c c6ff e7c0 e364 a92b 9063 8871 2d74 Gl.....d.+.c.q-t
> 00030e80: 68be 0ce0 ce97 c4e4 a30c c837 d13d e550 h..........7.=.P
> 00030e90: a7b7 0aac 4c07 8f02 0301 0001 2073 0002 ....L....... s..
Level up: 88.2%
1923 utilisateurs:
>1903 invités
>14 membres
