Screen Issues and more-linux Ti Nspire CX revision Y
Re: Screen Issues and more-linux Ti Nspire CX revision Y
Unread postby Vogtinator » 27 Nov 2021, 16:46
unfortunetly I forgot to bring my wireless keyboard so I could type "|" in the command.
Or just press :nssh: + :nspp: on the builtin keyboard.
VogtinatorPremium
Level up: 1.6%
Unread postby SuperXX » 03 Dec 2021, 18:58
Vogtinator wrote:Hm, none of those show any error messages, but also no success messages, like USB device announcements. So I assume that neither mouse nor USB drive were detected at all?
The best way to view dmesg without a serial console or file transfer is to run dmesg | less and taking pictures of each page. IIRC the pipe is :nssh: + :nspp: .
I´ve discovered what made the mouse to cause trouble with the CXII, it was always the USB Y splitter. Yesterday, when I was trying to run dmesg | less and connect the hub as I would connect, I realized that nothing that I plugged was working anymore and after some testing with my computer and smartphone, I realised that the Y splitter ended up being dead. After searching in my home, I found a USB A 3.0 to USB A 3.0 cable and tried to connect to one of the 3 ports on the hub, from my Power Wall Adapter. And it worked. Everything is working. The LED´s on the mouse can be modified as I do on my PC by pressing the top buttons, which wasn´t possible before. So, the best way to power a hub ends up being this. And we conclude that this was only a lack of power issue.
Now I can use dillo!!!!!!!!!! :)
Next step. Getting Internet working. I´ll come back if I have problems with that.
SuperXX
Level up: 43.8%
Previous
Users browsing this forum: ClaudeBot [spider] and 11 guests
1887 utilisateurs:
>1826 invités
>54 membres
