[FR] Guide du langage C sur ez80 (TI-83 PCE/ 84+CE)
Re: [FR] Langage C sur ez80 - Mémo, rappels & tutoriels
Message non lude Adriweb » 18 Mai 2017, 18:51
Ah, je vois... tu n'as pas suivi les consignes ;)
Dans ton Makefile, pour la toolchain sur ton ordi, il faut que tu listes quelles libs sont utilisées, pour que le reste soit automatique (le PB le fait par lui-même en regardant le code).
Exemple par ici : https://github.com/CE-Programming/toolc ... le#L20-L22
Code: Tout sélectionner
#Add shared library names to the L varible, for instance:
# L := graphx fileioc keypadc
L := graphx
Prochain niv.: 80.5%
Images: 1218
Twitter/X: adriweb
Message non lude MateoConLechuga » 30 Jan 2018, 02:22
If you are curious about C and want to try learning it, this update was made for you!
The toolchain has been completely revamped and now uses jacobly's fasmg-ez80 tools to perform the assembling and linking stages that were once handled by the old ZDS tools. What this means:
  • You no longer need to specify shared (L=) for libraries in the makefile, they are automatically detected and added.
  • You do not need to change the debug flag in the makefile, simply use 'make debug'
  • A better map file is produced, and in debug mode a debug file is produced for later source-level debugging in CEmu
  • The movement away from closed-source third-party tools has begun, to be replaced by FOSS, which will also make LLVM integration even easier in the future.
  • The library format is easier to use and adapt/add to.
  • A few library bugs have been fixed, such as gfx_FillTriangle().
You can also use the standard stdio.h commands for interfacing with files! This includes functions such as fopen(), fputs(), fread(), etc. This leverages the shared fileioc library to make porting applications even easier.
Download links are below, happy coding!
https://github.com/CE-Programming/toolc ... ses/latest
https://github.com/CE-Programming/libra ... ses/latest
Many thanks to jacobly who contributed a significant portion in making this possible.
MateoConLechugaVIP++
Prochain niv.: 60.5%
GitHub: mateoconlechuga
Message non lude edgar13 » 17 Nov 2019, 22:00
Très bon topic!
Je vais me mettre au C. (en plus ça ressemble à Java). :D
edgar13Modo
Prochain niv.: 97.4%
Images: 24
Classe: 1ere année de license maths-info
YouTube: Non
Twitter/X: Non
Facebook: Non
GitHub: Non
Message non lude Azerpogba » 18 Nov 2019, 18:20
Wistaro a écrit:
3.2 - Générer des sprites & des images
En cours de rédaction
Euhh es que cette partie arrivera un jour?? :mmm:
AzerpogbaAmbianceur
Prochain niv.: 60%
Images: 16
Classe: Etude sup
Message non lude Wistaro » 18 Nov 2019, 18:39
Bientôt :)
Nouveau sur le site, Anonymous ? Avant de poster sur le chat et sur le forum, n'oublie pas de lire les règles. En cas de problème, tu peux m'envoyer un message, je réponds rapidement.
Prochain niv.: 88.1%
Classe: Ingénieur en électronique
Twitter/X: Wistaro
Message non lude Azerpogba » 18 Nov 2019, 18:41
Wistaro a écrit:
Bientôt :)
Cool :) :D
AzerpogbaAmbianceur
Prochain niv.: 60%
Images: 16
Classe: Etude sup
Message non lude Wistaro » 18 Nov 2019, 18:43
Après faut aussi que j'update le tutoriel pour coller avec les dernières mises à jour de l'outil.
Twitter/X: Wistaro
Message non lude edgar13 » 18 Nov 2019, 21:08
Bientôt :)
Je l'attends avec impatience. :D
edgar13Modo
Images: 24
YouTube: Non
Twitter/X: Non
Facebook: Non
GitHub: Non
Re: [FR] Guide du langage C sur ez80 (TI-83 PCE/ 84+CE)
Message non lude edgar13 » 26 Mar 2021, 15:55
les documentations pour les bibliothèques avec un lien Github ne marchent plus.. :(
edgar13Modo
Images: 24
YouTube: Non
Twitter/X: Non
Facebook: Non
GitHub: Non
Message non lude Adriweb » 26 Mar 2021, 16:58
Tout est ici : https://ce-programming.github.io/toolchain/index.html
et le wiki pointe la au cas ou.
Images: 1218
Twitter/X: adriweb
PrécédenteSuivante
Retourner vers Langages alternatifs
Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 8 invités
Phi NumWorks jailbreak
123
952 utilisateurs:
>909 invités
>37 membres
