ICE Compiler
Re: ICE Compiler
Unread postby PT_ » 14 Oct 2017, 22:29
Several main bugs has been fixed, and tilemaps has been added, and much more, so just check it out!
http://htmlpreview.github.io/?https://g ... mands.html
https://github.com/PeterTillema/ICE/releases
40%
PT_Programmeur
Level up: 57.2%
Re: ICE Compiler
Unread postby PT_ » 01 Dec 2017, 23:01
I'm more than happy to finally officially announce ICE v2.0.0! It has been a long road to this version, because pretty much everything changed. I want to thank EVERYONE who has contributed to this long project, writing the documentation, and finding many bugs. I hope you all enjoy this new version, and if there's anything you want to be changed, feel free to poke or PM me! :D
Image ICE Compiler v2.0.0
Edit admin: Changelog from the file:
Version 2.0.0: December 1, 2017
☑ Added pointers + masking + address of variable
☑ Added file input/output
☑ Implemented more C functions
☑ Added several custom tokens
☑ Removed some custom tokens
☑ Open the editor if there's an error
☑ Added tilemaps
☑ Better documentation
☑ Negative numbers
☑ Binary, hexadecimal numbers
☑ Added string concatenation + substrings, length
☑ Added icon + description for Cesium
☑ Fixed many bugs
☑ Fixed all the errors in commands.html
40%
PT_Programmeur
Level up: 57.2%
Re: ICE Compiler
Unread postby Adriweb » 01 Dec 2017, 23:07
Nice job :)
I added the changelog to your post, from the file.
Level up: 80%
Images: 1133
Re: ICE Compiler
Unread postby PT_ » 05 Dec 2017, 00:01
Let me bump this issue, since adding floats is one of the first things on my to-do-list, but I've no idea how. Plz help me!!!!!!!!!!!!!!!!!! :)
https://github.com/PeterTillema/ICE/issues/34
40%
PT_Programmeur
Level up: 57.2%
Re: ICE Compiler
Unread postby critor » 19 Dec 2017, 19:06
I think I've got some problem with the included TWHG example, although it may not come from your code.
archives_voir.php?id=587211
With a TI-84 Plus CE-T L-0515A 5.3.0.0037, works perfectly. :)
With a TI-83 Premium CE L-0816E 5.3.0.0042, never works. :(
I'm getting either a freeze with a white screen, either an immediate reset.
It's the latest C libs, and the files were sent each time from the 84+CE to the 83PCE, so they're the same.
Level up: 53.6%
Images: 17124
Re: ICE Compiler
Unread postby PT_ » 19 Dec 2017, 19:28
Uh oh, that's very bad. I don't have a 83PCE (ROM) though, so I wonder what's going wrong. :(
40%
PT_Programmeur
Level up: 57.2%
Re: ICE Compiler
Unread postby TheMachine02 » 19 Dec 2017, 19:34
I can confirm the behaviour, at least on my emulator which is a ROM of 83PCE with OS 5.3. I am gonna investigate some more.
EDIT : okay, I have found the guilty code.
It is :
Copy(L1,sum(18,LEVELS),AMTBALLS*13)
Which compilated look like this :
D1AA50     DD6E89        ld l,(ix-$77)      ; most likely load LEVELS
D1AA53     E5            push hl
D1AA54     CD3CA9D1      call $D1A93C   ; sum(18,....)
D1AA58     C1            pop bc                  ; clean the stack
D1AA59     E5            push hl                 ; push first result, SOURCE_COPY
D1AA5A     DD27A4        ld hl,(ix-$5C)    ; load AMTBALLS
D1AA5D     E5            push hl
D1AA5E     D1            pop de
D1AA5F     29            add hl,hl
D1AA60     19            add hl,de
D1AA61     29            add hl,hl
D1AA62     29            add hl,hl
D1AA63     19            add hl,de               ; here we have the result * 13 this result should go to BC register for copy
D1AA64     E5            push hl                  ; push the result, okay why not
D1AA65     C1            pop bc                   ; copy it to bc, nice !
D1AA66     E1            pop hl                    ; pop the SOURCE_COPY
D1AA67     E5            push hl
D1AA68     C1            pop bc                   ; why :\
D1AA69     11F631D0      ld de,$D031F6 ; DEST_COPY
D1AA6D    EDB0          ldir
TheMachine02Modo
Level up: 30%
Class: Médecine
Re: ICE Compiler
Unread postby critor » 19 Dec 2017, 19:36
Wait, it seems to be random.
Just worked on my TI-83 Premium CE L-0816E several times in a row after adding useless AppVars.
I've then deleted some AppVars and same problem again.
Level up: 53.6%
Images: 17124
Re: ICE Compiler
Unread postby PT_ » 19 Dec 2017, 21:09
So it pushes HL while it shouldn't? Hmm, I can fix that. :P
40%
PT_Programmeur
Level up: 57.2%
Re: ICE Compiler
Unread postby TheMachine02 » 19 Dec 2017, 21:38
I rather say it does an extra push hl \ pop bc like it wanted to copy bc, but since bc is already copied it fail miserably and only do hl->bc with hl being the adress :p
TheMachine02Modo
Level up: 30%
Class: Médecine
1849 utilisateurs:
>1833 invités
>10 membres
