by cent20 » 28 Feb 2020, 09:54
Après intégration des diverses améliorations de Bisam et Critor (les plus faciles à comprendre), le script mis à jour est désormais (
https://workshop.numworks.com/python/cent20/demine) :
- Code: Select all
#v1.1 28/02/2020
from ion import keydown
from kandinsky import *
from random import randint
from time import sleep
# cut
co=color
a,r,t,l,k,s=set_pixel,fill_rect,draw_string,range,keydown,sleep
# couleurs
f,h,n = 255,127,0
c=[co(f,f,f), co(45,125,210), co(151,204,4), co(238,185,2), co(244,93,1), co(215,65,167), co(n,n,n), co(n,n,n), co(n,n,n),
co(h,h,h),co(192,192,192),co(96,96,96),co(253,236,185)]
nb0,nb1=19,0
# init
x0,y0,x1,y1=6,5,7,5
m = []
def deminage():
global nb0,nb1
t(str(nb1),12,2,c[2]);
if nb1+nb0>=150:t("Gagné ! ",120,2)
def decouvre(x,y):
i=1
while i>0:
chiffre(x,y)
for p in l(max(0,x-1),min(15,x+2)):
for q in l(max(0,y-1),min(10,y+2)):
if m[p][q]>=100:chiffre(p,q)
elif m[p][q]==0:m[p][q]+=1
i=0
for p in l(15):
for q in l(10):
if m[p][q]%100==1:i=1;x=p;y=q;p=14;q=9
def terrain():
r(8,21,300,200,c[9])
for y in l(21,243,20):
for x in l(8,309):
a(x,y,c[10])
for x in l(8,320,20):
for y in l(21,222):
a(x,y,c[10])
def chiffre(x,y):
global nb1
cl(x,y)
nb1+=(m[x][y]%100!=42)
v=m[x][y]//100
m[x][y] = 100*v + 42
if v: t(str(v),13+20*(x),23+20*(y),c[v],c[0])
deminage()
def minage(b=nb0,g=0):
if g:start()
t(" "*28,12,2)
t("/"+str(150-nb0),42,2,c[1]);
t("Demineur",120,2)
t("mines:"+str(nb0),220,2,c[5])
terrain();m.clear();
for x in range(15):m.append([0 for y in range(10)])
nb1=0
while b>0:
x, y = randint(0,14),randint(0,9)
if m[x][y]!=999:
m[x][y]=999;b-=1
if m[p][q]!=999:m[p][q]+=100
deminage();s(0.5)
def start():
t("Demineur",120,42,c[4])
t("par cent20",110,62,c[1])
t("https://nsi.xyz/demine",42,82,c[6])
t("[OK] [Clear] [+] [-] [EXE]",32,122,c[2])
s(4)
def explose():
t("perdu ! ",120,2)
for x in l(15):
for y in l(10):
if m[x][y]==999:mine(x,y)
def marche(x,y):
if m[x][y]>=999:explose()
elif m[x][y]>=100:chiffre(x,y)
else:decouvre(x,y)
def survol():
global x0,y0,x1,y1
gps(x1,y1)
if x1!=x0 or y1!=y0:
gps(x0,y0, 0 if m[x0][y0]%100 == 42 else 9)
x0, y0 = x1,y1
def gps(x,y,i=6):
r(9+20*x,22+20*y,19,2,c[i]);r(26+20*x,22+20*y,2,19,c[i]);r(9+20*x,22+20*y,2,19,c[i]);r(9+20*x,39+20*y,19,2,c[i])
def drone():
global nb0,x0,y0,x1,y1
while not k(5):
if k(0) or k(3) or k(1) or k(2):
x1,y1=min(max(x0-k(0)+k(3),0),14),min(max(y0-k(1)+k(2),0),9)
survol();s(0.120)
if k(4):marche(x0,y0)
if k(17) or k(16):drapeau(x0,y0)
if k(52):nb0=19;minage(nb0)
if keydown(45) or keydown(46):nb0=min(max(nb0+3*(k(45)-k(46)),11),42);minage(nb0)
print("A bientot !")
def drapeau(x,y):
r(17+20*x,26+20*y,3,9,c[12]);r(17+20*x,36+20*y,3,3,c[12])
def mine(x,y):
cl(x,y);r(12+20*x,36+20*y,13,4,c[9]);r(14+20*x,34+20*y,9,2,c[11]);r(17+20*x,32+20*y,3,2,c[5])
def cl(x,y):
r(9+20*x,22+20*y,19,19,c[0])
minage(g=1);drone()
En poussant beaucoup plus loin, en supprimant l'écran d'accueil, en supprimant le codage des couleurs dans un tableau, en fusionnant toutes les fonctions appelées une unique fois (au détriment de la lisibilité du code) on arrive à ceci
https://workshop.numworks.com/python/cent20/demine2- Code: Select all
#v1.1lite 28/02/2020
# couleurs
def c(i):
f,h,n = 255,127,0
l=(f<<16|f<<8|f, 45<<16|125<<8|210, 151<<16|204<<8|4, 238<<16|185<<8|2, 244<<16|93<<8|1, 215<<16|65<<8|167, n<<16|n<<8|n, n<<16|n<<8|n, n<<16|n<<8|n,h<<16|h<<8|h,192<<16|192<<8|192,96<<16|96<<8|96,253<<16|236<<8|185)
return (l[i]>>16,(l[i]>>8)&((1<<8)-1),l[i]&((1<<8)-1))
nb0,nb1=19,0
# init
x0,y0,x1,y1=6,5,7,5
m = []
def deminage():
global nb0,nb1
draw_string(str(nb1),12,2,c(2));
if nb1+nb0>=150:draw_string("Gagné ! ",120,2)
def decouvre(x,y):
i=1
while i>0:
chiffre(x,y)
for p in range(x-(x>0),x+(x<14)+1):
for q in range(y-(y>0),y+(y<9)+1):
else:m[p][q]+=m[p][q]==0;
i=0
for p in range(15):
for q in range(10):
def chiffre(x,y):
global nb1
fill_rect(9+20*x,22+20*y,19,19,c(0))
v=m[x][y]//100
if v: draw_string(str(v),13+20*(x),23+20*(y),c(v),c(0))
deminage()
def minage(b=nb0):
draw_string(" "*28,12,2)
draw_string("/"+str(150-nb0),42,2,c(1));
draw_string("Demineur",120,2)
draw_string("mines:"+str(nb0),220,2,c(5))
fill_rect(8,21,300,200,c(9))
for y in range(21,243,20):fill_rect(8,y,302,1,c(10))
for x in range(8,320,20):fill_rect(x,21,1,202,c(10))
m.clear();
nb1=0
while b:
if m[x][y]!=999:
m[x][y]=999;b-=1
m[p][q]+=(m[p][q]!=999) and 100
deminage();sleep(0.5)
def marche(x,y):
if m[x][y]>=999:
draw_string("perdu ! ",120,2)
for x in range(15):
for y in range(10):
if m[x][y]==999:
fill_rect(9+20*x,22+20*y,19,19,c(0));fill_rect(12+20*x,36+20*y,13,4,c(9));fill_rect(14+20*x,34+20*y,9,2,c(11));fill_rect(17+20*x,32+20*y,3,2,c(5))
else:decouvre(x,y)
def survol():
global x0,y0,x1,y1
gps(x1,y1)
x0, y0 = x1,y1
def gps(x,y,i=6):
fill_rect(9+20*x,22+20*y,19,2,c(i));fill_rect(26+20*x,22+20*y,2,19,c(i));fill_rect(9+20*x,22+20*y,2,19,c(i));fill_rect(9+20*x,39+20*y,19,2,c(i))
def drone():
while not keydown(5):
if keydown(0) or keydown(3) or keydown(1) or keydown(2):
x1,y1=min(max(x0-keydown(0)+keydown(3),0),14),min(max(y0-keydown(1)+keydown(2),0),9)
survol();sleep(0.120)
if keydown(4):marche(x0,y0)
if keydown(17):fill_rect(17+20*x0,26+20*y0,3,9,c(12));fill_rect(17+20*x0,36+20*y0,3,3,c(12))
if keydown(52):nb0=19;minage(nb0)
if keydown(45) or keydown(46):nb0=min(max(nb0+3*(keydown(45)-keydown(46)),11),42);minage(nb0)
minage()
survol()
drone()
Et cette version tourne sur une NumWorks stock, c'est à dire animé par l'OS Epsilon et son tas python ridicule de 16ko.
Comme précisé dans le chat de TI-Planet, espérons que ce recodage ne servira pas de justification à l'équipe des dev de NumWorks de ne rien faire concernant ces 16ko.
Les utilisateurs de l'OS stock de la NumWorks peuvent louer le travail remarquable de recodage de ce script, et je me joint à eux car d'une part je n'y croyais pas, et d'autre part je trouve ces astuces (notamment celle sur le codage des couleurs) impressionnantes.
L'analyse de l'utilisation en mémoire python d'une matrice de 150 cases (6ko) calculée précédemment par Critor est effrayante, sidérante, déconcertante.
Des problèmes demeurent :
- la version "lite" utilise au maximum les 16ko disponibles, et il ne reste donc plus aucune place pour des dev ultérieurs, comme par exemple une vrai gestion de la victoire / défaite, car pour l'instant il est possible de continuer à jouer quand on a perdu / gagné.
- le code de la version lite est pédagogiquement moins pertinent pour un utilisateur débutant en python (mais un délice pour un codeur avancé), sans compter que l'on a du renoncer au format PEP8 depuis longtemps
Abstraction
Il est possible de faire un démineur autrement, de stocker les positions dans une unique liste de 11-42 cases, donc cela consommerait uniquement entre 64+11*(8+28)=460 octets et 64+42*(8+28)=1576 octets mais il faudrait coder des fonctions qui déterminent en temps réel (et pas au début du programme) le nombre de bombes dans l'environnement proche en parcourant à chaque fois cette liste de 11 à 42 cases. C'est cette méthode que j'utilisais dans mon antique démineur sur Casion 9960GT, mais cela passait par l'utilisation d'une autre liste de case à traiter, liste dont la taille est difficilement estimable à l'avance (notamment s'il y a peu de bombes).
En résumé
un grand bravo à Critor et Bisam, de sincères remerciement pour leur aide précieuse, le reste dépendra du NumWorks.
