[Tutorial] Installer TILP sur Mac OS X
Message non lude Adriweb » 26 Sep 2015, 20:14
Here are a few commands (to type in the Terminal, in this order), for Mac OS X (a recent version is recommended), which should simplify the prerequisites setup, and download and launch tilp's install script. Some may ask for your password, that's expected.
NB: You'll have to copy/paste all of each line's content, don't ignore the italics/grey part etc.
  1. install dev tools if needed. This will install Xcode if you don't have it - and it's big, yeah... (instead, you may want to try a 'brew install gcc' right before step 4)
    xcode-select --install
  2. install brew if needed
    which -s brew || ruby -e "$( curl -fsSL 'https://raw.githubusercontent.com/Homebrew/install/master/install' )"
  3. install dependencies (this will take several minutes)
    brew install gettext libarchive autoconf automake libtool glib lzlib libusb gtk+ libglade sdl bison flex texinfo libiconv intltool
  4. manually linking certain things
    brew link -f gettext libarchive
    It's possible that libarchive may not be force-linked anymore, in which case do what brew suggests for the pkg-config-path (by appending).
  5. Download the install script (this is all in one line)
    curl -sSL "https://raw.githubusercontent.com/debrouxl/tilp_and_gfm/master/tilp/trunk/build/scripts/install_tilp.sh" > ~/install_tilp.sh
  6. install script launch, just after deleting tilp's default install directory (just in case). You may need to press Enter at some point
    sudo /bin/bash -c '(rm -Rf ~/lpg/tilp; sh ~/install_tilp.sh)'
There you go, the tilp command should then be available...
If you have this error: "checking for XML::Parser... configure: error: XML::Parser perl module is required for intltool".
Try this: sudo perl -e shell -MCPAN and then in the shell that pops up, install XML::Parser. Once done, Ctrl-D (to quit the shell), then relaunch sudo ~/install_tilp.sh.
I've tested that successfully on two clean machines :)
Voici quelques commandes (à taper dans le Terminal, dans l'ordre), pour Mac OS X (version d'OS récente recommandée), qui devrait simplifier la mise en place des prérequis, puis télécharger & et lancer l'installation de tilp. Certaines demanderont le mot de passe, c'est normal.
NB: il faut copier/coller l'ensemble de chaque partie "code" des lignes suivantes, n'ignorez pas les bouts en italique/gris ou autre, il faut tout prendre.
  1. pour installer les outils de dev si besoin. Installera Xcode si vous ne l'avez pas - c'est gros, oui... (à la place, vous pouvez peut-être tenter un 'brew install gcc' avant l'étape 4)
  2. pour installer brew si besoin
  3. installation des dépendances. Ceci va prendre plusieurs minutes.
  4. link manuel de certaines choses
    Il est possible que libarchive ne veuille plus se force-linker, du coup faites ce que brew suggère pour le pkg-config-path (en append).
  5. téléchargement du script d'install (ceci est une seule ligne)
  6. lancement du script, juste après suppression du dossier par défaut de tilp (au cas où). Il va falloir appuyer sur Entrer lors du début du script d'install.
Voilà, la commande tilp devrait alors être disponible...
Si vous avez cette erreur: "checking for XML::Parser... configure: error: XML::Parser perl module is required for intltool".
Tentez ceci: sudo perl -e shell -MCPAN et dans le shell qui suit, install XML::Parser. Une fois fini, Ctrl-D (pour quitter ce shell), puis relancez sudo ~/install_tilp.sh.
J'ai pu tester ceci avec succès sur une machine clean :)
Prochain niv.: 80.1%
Images: 1216
Twitter/X: adriweb
Re: [Tutorial] Installer TILP sur Mac OS X
Message non lude GalacticPirate » 26 Sep 2015, 21:16
Merci encore Adriweb pour ton aide ;) !
Par contre, tu pourrais rajouter ça en edit ?
NB : L'installations de packages Homebrew va entraîner le remplissage du dossier /usr/local. Cela a causé un bug d'installation lors des mises à jour Mavericks et Yosemite, et sûrement El Capitan. Le problème est que l'installer va croire que /usr/local est presque vide, mais si vous avez des packages MacTeX, Homebrew, ou Ruby, ce dossier pèsera plusieurs Go et rallongera l'installation d'une durée comprise entre deux et quatorze heures, tandis que la barre de chargement indiquera "il reste deux minutes". Si vous comptez faire une des MAJ citées ci-dessus prochainement, il va falloir déplacer les fichiers avant l'install en tapant sudo mv /usr/local ~/local dans le Terminal, puis taper sudo mv ~/local /usr dans le Terminal après l'install pour récupérer vos fichiers ;)
GalacticPirateModo
Prochain niv.: 1.3%
Classe: L3 Informatique
GitHub: GalacticPirate-Prog
Message non lude Adriweb » 26 Sep 2015, 21:20
On n'y peut pas grand chose, malheureusement, pour compiler les choses soit-même.
Mais donc oui, on pourrait faire un .zip avec toutes les lib et binaires précompilés, et avec un script qui extrait tout au bon endroit, ça éviterait toutes les étapes de brew + de compilation...
Images: 1216
Twitter/X: adriweb
Message non lude GalacticPirate » 26 Sep 2015, 21:43
Bah en fait, ça tient en deux lignes de code ( :troll: ), que j'ai ajouté dans le NB en haut. Il suffit de faire sudo mv /usr/local ~/local avant et sudo mv ~/local /usr après l'installation :p
GalacticPirateModo
Prochain niv.: 1.3%
Message non lude Adriweb » 27 Sep 2015, 18:56
Ce qui ne marchera vraisemblablement pas sur El Capitan vu tout ce qu'ils ont changé niveau sécurité/permissions :P
(Mais ptet qu'ils ont aussi corrigé le bug initialement)
Images: 1216
Twitter/X: adriweb
Message non lude GalacticPirate » 20 Aoû 2016, 16:28
Ok, j'ai patché la ligne 498, comment je recompile ? :p
GalacticPirateModo
Prochain niv.: 1.3%
Message non lude Adriweb » 20 Aoû 2016, 16:29
Refais la dernière étape du tutorial (en adaptant les chemins si tu les avais changé)
Images: 1216
Twitter/X: adriweb
Message non lude GalacticPirate » 20 Aoû 2016, 16:30
J'ai essayé, mais mon patch disparaît, et le bug est donc toujours présent...
GalacticPirateModo
Prochain niv.: 1.3%
Message non lude Adriweb » 20 Aoû 2016, 16:42
Euh, oui, pardon, j'ai dit des conneries.
Va dans le dossier ~/lpg/tilp/tilibs/libticables/trunk/src, et tape make. (Puis possiblement make install)
Images: 1216
Twitter/X: adriweb
Message non lude GalacticPirate » 20 Aoû 2016, 16:53
make install me renvoie des erreurs et make n'a aucun effet même si le patch est toujours là...
GalacticPirateModo
Prochain niv.: 1.3%
Suivante
Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 4 invités
Phi NumWorks jailbreak
123
1095 utilisateurs:
>1084 invités
>6 membres
