Concours de rentrée 2020 - défi Python de Xuanwu
Re: Concours de rentrée 2020 - défi Python de Xuanwu
Unread postby critor » 20 Oct 2020, 09:47
So , what would you like ? :)
And what's your secret for achieving the best score ? ;)
Level up: 14.3%
Images: 10409
Class: Lycée
Facebook: critor.ti
Unread postby commandblockguy » 20 Oct 2020, 21:10
I'll take the Numworks calc (Sagittarius).
As for my strategy, I basically found a path through the maze by hand that had as few points as possible, without worrying about my score too much. I made sure to take a very shallow angle when exiting so that the path would be long enough to get the maximum score.
I then tested every single combination of angles and distances that would put me within some distance (if I remember correctly, about 1.5 tiles, though I changed it several times) of my original points, while still allowing me to get the maximum score. This was feasible because you get points off for each digit after the first decimal place, or before the units place, which means that there are only 100 angles and 100 distances to try for each point. The exception for this is the last point, which has to be more than 10 units away in order to meet the length requirement. This took a few hours to run in its entirety, and I was left with a few thousand paths. Prior to the scoring change, all of these paths would have left me with a score of 72, but after the scoring change it was now possible to get a fractional score.
A "heatmap" of all the paths I found. The color of each point represents the last "target" point it was able to get to, with purple being the final point, outside of the maze.
The fractional part of the score was determined based on the sine of the sum of the angles and distances, which means that the input to sin() could be no more precise than to the tenths place. For the range of numbers that this sum could possibly be without adding a full point to my score, the tenth whose sine is closest to -1 is 11.0, and sin(11) is = -0.999990207.
Unfortunately, none of the few thousand paths that I had found added up to 11.0. However, I realized that I was only calling a_droite() in my path, and that if I replaced a_droite(x) with a_gauche(-x), x would be subtracted from the sum rather than added to it, without actually changing the validity of the path. I tried out every combination of a_droite and a_gauche calls for each of my few thousand paths, and found one that added up to 11.0, giving me a score of 71.0000097934493.
Here's the code that I used to find this path.
You'll notice that this is still very slightly off from my actual score - I realized that I could slightly decrease sin(sum) by slightly decreasing sum, and that I could slightly decrease sum by subtracting a tiny amount from each distance and angle. Normally, this would cause my score to increase by several full points because of the decimal places after the tenths place, but because the score is rounded to 5 decimal places before the length of the number is calculated, if the difference is less than 0.000005, you aren't penalized. So, I subtracted 0.0000049999... from each distance, to get a sum of 10.99991, a sine of -0.99999060081, and a final score of 71.00000939918644. I believe that this is within a floating-point error of the ideal solution.
Here's the solution that I submitted, for reference.
I actually tested all of this on a computer, as I didn't have my EP with me. I ported polycalc to use cv2 for drawing stuff.
I also tried to submit a few, uh, let's call them
gimmicky
, solutions. My first instinct was to try an integer overflow, but to my disappointment, Python doesn't actually have those. The numbers, they just keep
going
After that, I tried subclassing the float class so that it would return an empty string. Technically, this wasn't modifying the internal state of laby.py :p. I could have also returned a custom string class with a modified __len__ method, but in CPython __len__ must return a positive integer, which also gets converted into a regular integer, not one that I could subclass. Interestingly, MicroPython allows you to return a negative length for __len__, so I could have probably gotten a score of negative infinity if the admins didn't shut that idea down :p.
Finally, I also found a solution that's far better than the others that I decided not to submit since I was already in first. Here's the link if you want to give it a try for yourself.
commandblockguyPremium
Level up: 6.7%
GitHub: commandblockguy
Unread postby critor » 20 Oct 2020, 23:44
Thanks for your reply and comprehensive details @commandblockguy. :)
Which NumWorks bag ?
130461304713048
Which NumWorks poster ?
1304013039130411304213034
And which Xcas goodies ?
T-shirt ? Hat ? Mousepad ? Sticker ?
Level up: 14.3%
Images: 10409
Class: Lycée
Facebook: critor.ti
Unread postby commandblockguy » 21 Oct 2020, 00:01
I'll take the third bag and the fourth poster, and a large shirt.
Level up: 6.7%
Unread postby TIny_Hacker » 21 Oct 2020, 00:48
Very nice @commandblockguy, I remember you bragging about it and that (non-submitted) score is INSANELY lower than the others! Now I feel so dumb not going that path...
TIny_Hacker
Level up: 64.1%
GitHub: TIny-Hacker
Unread postby critor » 21 Oct 2020, 07:51
Thanks @commandblockguy.
Also I forgot, which TI-Planet sticker ?
11614
Level up: 14.3%
Images: 10409
Class: Lycée
Facebook: critor.ti
Unread postby critor » 21 Oct 2020, 07:58
Also to everybody, please make a post your details/explanations/secrets. :)
Aussi à tous, svp faites un post avec vos détails / explications / secrets. :)
Level up: 14.3%
Images: 10409
Class: Lycée
Facebook: critor.ti
Unread postby Pavel » 21 Oct 2020, 10:38
critor wrote:Also to everybody, please make a post your details/explanations/secrets. :)
Voici une explication de mon approche pour trouver une solution à ce défi.
J'ai commencé par essayer de comprendre comment la consommation est calculée. Voici les parties du code Python montrant tous les composants des calculs de consommation:
def fix_angle(a):
  return a * 2 * asin(1) / pi
def a_gauche(a):
  global state
  state[7] += a
  state[5] += 5 + cout(a)
def avancer(l):
  global state
  state[7] += l
  state[5] += 8 + cout(l)
  while(l > 0):
    l -= .25
    state[6] += (state[6] < 200)
def aller_selon(f):
  global state
  state = [0, .5, 0, 0, .5, 0, 0, 0]
  f()
  state[5] += sin(fix_angle(state[7])) - state[6] // 2
  print('Consommation : ' + str(state[5]))
Apparemment, la consommation se compose des trois éléments suivants:
state[5] = consommation de base
state[6] = distance totale parcourue multipliée par quatre
state[7] = angle total + distance totale
Ensuite, j'ai testé la fonction 'cout()' qui est utilisée dans les calculs de consommation:
>>> from laby import *
>>> cout(5)
3
>>> cout(0.5)
3
>>> cout(0.05)
4
>>> cout(5e-3)
5
>>> cout(5e-4)
6
>>> cout(5e-5)
7
>>> cout(5e-6)
3
Il semble donc que la consommation puisse être minimisée en combinant les éléments suivants:
  • minimiser la quantité de manoeuvres
  • minimiser 'sin(state[7])'
  • maximiser la distance totale parcourue
  • ne pas utiliser plus d'un chiffre décimal après la virgule décimale
  • essayer d'exploiter le faible coût du 'cout(5e-6)'
Pour minimiser 'sin(state[7])', j'ai utilisé le code Python suivant pour créer un tableau montrant les valeurs de la fonction 'sin()' pour différents angles avec un seul chiffre décimal après la virgule décimale:
from math import pi, sin
l = []
for i in range(-10, 11):
  a = round(-pi/2 + 2 * pi * i, 1)
  l.append((a, sin(a)))
l.sort(key=lambda e: e[1])
for e in l:
  print('a = %5.1f -> sin(a) = %f' % e)
Voici le résultat:
a = -64.4 -> sin(a) = -0.999996
a = -26.7 -> sin(a) = -0.999994
a =  11.0 -> sin(a) = -0.999990
a =  48.7 -> sin(a) = -0.999986
a =  42.4 -> sin(a) = -0.999934
De petites valeurs de 'state[7]' sont donc nécessaires pour une faible consommation. Vu que 'state[7]' est la somme des angles et des distances et que les distances ne peuvent pas être négatives, alors les valeurs des angles passés à la fonction 'a_gauche()' doivent être négatives.
Une fois que tout ça est devenu plus ou moins clair, j'ai modifié le code laby.py pour en faire une version qui peut être contrôlée comme un jeu vidéo avec les touches haut/bas/gauche/droite sur le clavier:
https://gitea.planet-casio.com/Pavel/labygui
En utilisant cette approche, j'ai obtenu la solution suivante:
from laby import *
def chemin():
  for e in [(-6.6, 2.3), (-7.3, 6.3), (-5.2, 4.6), (-4.8, 4.1), (-7.3, 6.3), (-8.3, 3.8), (-5.1, 3.8), (-2.3, 4.3), (9.1, 13.3)]:
    a_gauche(e[0])
    avancer(e[1])
aller_selon(chemin)
La consommation correspondant à cette solution est de 71.0000097934493.
À ce stade, je n'ai toujours pas exploité le faible coût du 'cout(5e-6)'. J'ai donc essayé d'ajouter ou de soustraire 5e-6 des distances et des angles. La solution qui m'a donné le score le plus bas (71.00000939918644) était la suivante:
from laby import *
def chemin():
    a_gauche(e[0] - 5e-6)
    avancer(e[1] - 5e-6)
aller_selon(chemin)
Au moment où j'ai trouvé cette solution, elle était déjà soumise par commandblockguy et j'ai dû trouver la deuxième meilleure solution (71.00000939918645) en ajoutant de très petites valeurs aux angles et aux distances:
from laby import *
def chemin():
    a_gauche(e[0] - 5e-6 + 1e-13)
    avancer(e[1] - 5e-6 + 1e-13)
aller_selon(chemin)
PavelPremium
Level up: 46.9%
Unread postby cent20 » 21 Oct 2020, 10:50
Bravo pour ces explications d'une clarté lumineuse.
Je viens de comprendre que du coup, j'aurais pu fabriquer le score 71,00000939918646, oui enfin il fallait déjà arriver à faire l'intégralité du raisonnement pour cela.
Et merci pour le simulateur PC, une aide inestimable.
Enseignant de mathématiques et de spécialité NSI ( projets, tutos ...)
:favorite: NumWork, Python : démineur, snake, tétris
cent20VIP++
Level up: 87.1%
Images: 60
Twitter: nsi_xyz
Unread postby critor » 21 Oct 2020, 15:43
critor wrote:Thanks @commandblockguy.
11614
Ok, 1er autoccollant, merci. :)
@Pavel, merci pour ton explication et félicitations. Que nous prends-tu ? :bj:
  • 2 lots
    Capricorne ♑
    1
    calculatrice
    Casio Graph 90+E
    + 1
    pack de goodies
    Casio
    + 1
    goodie
    Xcas
    au choix + 1
    pack de goodies
    TI-Planet
    Planète Casio
  • 2 lots
    Bélier ♈
    1
    solution d'émulation
    Casio
    au choix + 1
    CD
    de vidéos
    Casio fx-CG20
    ou
    catalogue de produits
    Casio
    au choix + 1
    pack de goodies
    Casio
    + 1
    goodie
    Xcas
    au choix + 1
    pack de goodies
    TI-Planet
    Planète Casio
    CD
    de
    54
    vidéos pour plus de
    8h
    par , pour
    fx-CG20
    mais compatible
    Graph 90+E
    , pour
    Windows
    Mac
    Détail des
    solutions d'émulation
    Casio
    au choix :
    • clé
      USB 8 Go
      d'émulation permanente au choix, à jour avec 3 émulateurs pour
      Windows
      fx-92+ Spéciale Collège
      Graph 35+E II 3.30
      Graph 90+E 3.40
    • licence 3 ans utilisable pour l'installation de tout ou partie des logiciels d'émulation suivants :
    1161713022130231302513024
  • Lot
    Serpentaire ⛎
    1
    goodie
    HP
    au choix + 1
    goodie
    Xcas
    au choix + 1
    pack de goodies
    TI-Planète-Casio
    Poster
    HP
    : format
    59,2×40 cm²
    Clé
    USB HP
    16 Go
    de capacité nominale.
    1303811654116539656
  • 1 lot
    Sagittaire ♐
    1
    calculatrice
    NumWorks N0110
    + 1
    pack de goodies
    NumWorks
    + 1
    goodie
    Xcas
    au choix + 1
    pack de goodies
    TI-Planet
    Planète Casio
  • 2 lots
    Balance ♎
    1
    couvercle
    NumWorks
    + 1
    autocollant
    NumWorks
    + 1
    enveloppe
    NumWorks
    ou
    carte postale
    NumWorks
    ou
    carte de visite-énigme
    NumWorks
    au choix + 1
    pack de goodies
    NumWorks
    + 1
    goodie
    Xcas
    au choix + 1
    pack de goodies
    TI-Planet
    Planète Casio
    Couvercle
    NumWorks
    au nouveau format
    N0110
    protégeant mieux l'écran contre les rayures, mais restant parfaitement utilisable sur l'ancien modèle
    N0100
    11649130361303013026130271302813029
  • Lot
    Taureau ♉
    1
    calculatrice
    TI-Nspire CX II-T CAS
    + 1
    licence logiciel
    TI-Nspire CAS
    élève
    + 1
    pack de goodies
    TI
    + 1
    goodie
    Xcas
    au choix + 1
    pack de goodies
    TI-Planète-Casio
  • Lot
    Lion ♌
    1
    calculatrice
    TI-Nspire CX II-T
    + 1
    licence logiciel
    élève
    + 1
    pack de goodies
    TI
    + 1
    goodie
    Xcas
    au choix + 1
    pack de goodies
    TI-Planète-Casio
  • Lot
    Gémeaux ♊
    1
    calculatrice
    TI-83 Premium CE Edition Python
    + 1
    adaptateur
    USB
    + 1
    clavier
    USB
    dédié + 1
    pack de goodies
    TI
    + 1
    pack de goodies
    TI-Planète-Casio
    Détail des
    calculatrices
    au choix :
    • TI-Nspire CX II-T CAS
      sous blister version B
      sous blister version B avec autocollant sceau
    Détail des
    calculatrices
    au choix :
    • TI-83 Premium CE Edition Python
      sous blister version E
      sous blister version E avec autocollant masquant sceau
1162413045116231182811827113251272411324130601305912281
[info]Détail des packs de goodies communs accompagnants les lots :
  • 1
    manuel
    NumWorks
    au choix
    N0100
    ou
    N0110
  • 1
    cahier d'activités
    NumWorks SNT 2nde
  • 1
    sac
    NumWorks
    au choix
    N0100
    versions
    1.0-1.5
    N0100
    versions
    1.6+
    , ou
    N0110
  • 1
    cahier
    NumWorks
  • 1
    poster
    NumWorks
    au choix :
    • format
      A0
      (118,9×84,1 cm²)
      NumWorks N0100
      - roulé
    • format
      A2
      (42×59,4 cm²)
      • NumWorks N0100
        Eduscol / Ministère de l'Education Nationale
        - roulé - brillant
      • NumWorks N0100
        - roulé - mat
      • NumWorks N0100
        @Pims / @qabosse / @antalpilipili
        et ses collègues d'
        EPS
        - roulé
      • NumWorks N0100
        Xavier Andréani / TI-Planet
        - roulé - dédicacé
      • NumWorks N0110
        : Comprendre le monde devient un jeu - plié
  • 1
    stylo
    NumWorks
1303513031130461304713048130321306813037130401303913041130421303413033
  • 1
    stylo
    TI
    au choix
  • 1
    porte-documents
    TI
  • 1
    poster
    TI
    plié
    au choix :
    • format
      ANSI-D
      (55,9×86,4 cm²)
      TI-73 Explorer
    • format
      A1
      (59,4×84,1 cm²)
      TI-89 Titanium
    • format
      55,75×83,5 cm²
      TI-Nspire CX
      TI-Nspire CX CAS
  • 1
    clé
    USB
    TI
    au choix :
    • clé USB
      T3 France
      bleue -
      2 Go
    • clé USB
      TI-Primaire Plus
      4,01759 Go
      de capacité réelle
    • clé USB
      TI-Innovator Rover
      4,01813 Go
      de capacité réelle
    • clé USB
      TI-83 Premium CE
      avec lanière -
      4,01811 Go
      de capacité réelle
    • clé USB
      TI-83 Premium CE
      avec chaînette -
      4,01811 Go
      de capacité réelle
    • clé USB
      TI
      rouge -
      1 Mo
      (promotion
      TI-Primaire Plus
      défectueuse)
  • 1
    autocollant
    TI
    ou
    décalcomanie
    TI
    ou
    pochette
    CD
    TI
    ou
    lunettes
    TI
    au choix
  • 1
    cahier
    TI-83 Premium CE
    au choix
Aperçus de quelques
cahiers d'activités
TI-83 Premium CE Python
au choix:
11782130651306613067130641306313062130611304913050130431304411533130561307413085130861308713088130811308213073130831308413077130781308313084130721306913070
1
t-shirt
Xcas
ou
casquette
Xcas
ou
tapis de souris
Xcas
ou
autocollant
Xcas
  • 1
    autocollant
    TI-Planet
    au choix
  • 1
    autocollant
    Planète Casio
  • 1
    compte premium
    TI-Planet
1161411615
Level up: 14.3%
Images: 10409
Class: Lycée
Facebook: critor.ti
Users browsing this forum: No registered users and 11 guests
Social
592 utilisateurs:
>552 invités
>33 membres
