Le Python et la Nspire enfin réunis grâce à "Micro Python" !
Re: Le Python et la Nspire enfin réunis grâce à "Micro Pytho
Message non lude Adriweb » 03 Sep 2014, 16:46
Thanks Vogtinator :D
In the attachment you provided, do you think it is stable enough to be the main download (I'd update the archive, then) ?
(The current archive download si the version without native code emission, just the first one I did my timings with)
Also, an idea : lots of people won't know that it's possible to modify the file exts association file - Could micropython automatically append the correct line to associate itself with .py files if it's not already the case (or if the file doesn't exist at all) ?
AdriwebAdmin.
Prochain niv.: 49.4%
Images: 1079
Classe: (ingénieur)
Message non lude Vogtinator » 03 Sep 2014, 17:11
It's not stable at all, some testing would be good, to find out why it crashes sometimes.
Also, an idea : lots of people won't know that it's possible to modify the file exts association file - Could micropython automatically append the correct line to associate itself with .py files if it's not already the case (or if the file doesn't exist at all)?
That's already the case, even with the version you benchmarked :P
VogtinatorPremium
Prochain niv.: 33.6%
Message non lude Adriweb » 03 Sep 2014, 17:17
Oh, I must have done something wrong when I tested, then, ok :D
And ok, I'll just mention the dev. version but not update the main download :)
(Edit : done - see description. Edit2 : also updated the news about that)
AdriwebAdmin.
Images: 1079
Classe: (ingénieur)
Message non lude Hayleia » 03 Sep 2014, 21:00
Excellent projet et excellente news :D
Je signale juste deux fautes que j'ai trouvées en passant ;)
Lionel Debroux a écrit:
Compte tenu de tout ceci, il est assez naturel de vouloir [essayer de] porter d’autres langages de script comme le Javascript, Perl, PHP, Python, Ruby… sur calculatrice - d'une part
parce que l'on peut le faire
, et d'autre part car une partie des utilisateurs de calculatrices qui deviendront développeurs professionnels un jour peuvent avoir envie d'
appendre
des langages populaires en premier :)
Ansi, nous (admins de TI-Planet) avons initié le projet de port d'un interpréteur Python pour la TI-Nspire. Le Python est clairement le choix le plus populaire parmi les 5 listés plus haut, et il est devenu le langage le plus populaire à des
fins éducatifs
d'après un récent sondage :
Therefore, we (TI-Planet staff) sparked the port of some Python flavor to the Nspire. Python is clearly the most popular choice among the 5 ones listed above, and it has become the most popular language for learning purposes, according to a recent survey:
http://www.pcworld.com/article/2451880/ ... guage.html .
Pokemon Topaze
(Axe) discussion and download links here
HayleiaDonat.
Prochain niv.: 10.2%
Genre: Non spécifié
Classe: Templar
Message non lude technolapin » 03 Sep 2014, 21:05
Bon, tout ça c'est bien beau, mais on fait comment pour faire des scripts de plus d'une ligne avec cette console? :troll:
Votez Kasane Teto 2017
technolapin
Prochain niv.: 97.2%
Images: 25
Classe: Chui en vacance ducon
Message non lude Adriweb » 03 Sep 2014, 21:06
Tu peux aller à la ligne sans problème :)
AdriwebAdmin.
Images: 1079
Classe: (ingénieur)
Message non lude Bisam » 03 Sep 2014, 21:28
Thank you for adding these missing characters, Vogtinator !
You forgot to tell about ! which can be added too by pressing :nssh: :nspp:
Now (or maybe I did something wrong before that...) scripts execute and wait for a key pressed at the end so that you can see something !
Students can create their scripts oncalc with nTxt and execute them with MicroPython... that's just perfect.
Maybe 2 features could be added :
- an easy "quit" by pressing a key (e.g. "ESC" or "ON")
- ability of executing a chosen file while being in Micropython (using a menu, like nTxt does, for example)
That would the BEST !
BisamAdmin.
Prochain niv.: 46%
Classe: Prof de Math en Maths Spé PSI
Message non lude technolapin » 04 Sep 2014, 05:59
Quelle touche? Et surtout, il faut retaper le programme quand on veux l’exécuter?!
technolapin
Images: 25
Message non lude Levak » 04 Sep 2014, 06:52
Quelle touche?
C'est le même comportement que sur PC si je ne m'abuse :
- L'ouverture d'un scope se fait par les ( et :
- Une ligne vide correspond à la fermeture d'un scope IIRC.
Tant que t'es dans un scope, tu n'exécutes pas le programme et le readline attends tes entrées.
Je suppose que oui. Sinon, comme bisam l'a dit : nTxt est ton ami.
ImageTNOC [topic][DL]
nClock [topic][DL]
HideManager [topic][DL]
ZLock [topic][DL]
Theme Editor [topic][DL]
Mes programmes
LevakAdmin.
Prochain niv.: 91.4%
Images: 22
Classe: BAC+5: Epita (ING3)
En ligne
Message non lude parisse » 04 Sep 2014, 12:16
How can we leave the interpreter? Enter on a void line does not work with the readline-enabled version.
Prochain niv.: 52.1%
Genre: Non spécifié
PrécédenteSuivante
Retourner vers News TI-Nspire
Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 4 invités
Campagne de dons
Pour nous aider à financer nos déplacements sur les salons/congrès qui vous donnent du contenu exclusif
Vous aurez droit aux avantages VIP et des goodies !
22.5%
Avantages VIP et goodies pour les donateurs !
Notre partenaire Jarrety
436 utilisateurs:
>407 invités
>23 membres
