I found a vulnerability in boot1.5 4.4.0.8!
C, C++, ASM...
Re: I found an exploit in boot1.5 4.4.0.8!
Unread postby critor » 21 Jan 2018, 20:49
Seems to be a mapping problem, yes.
In the nBoot/ControlX context, adding a breakpoint on the Boot1 read_nand() syscall works perfectly :
Breakpoint at 0x10000034
>k 0000b164 +x
>k
0000b164   x
10000034   x
>c
Breakpoint at 0x0000b164
Level up: 5.8%
Images: 9464
Class: Lycée
Facebook: critor.ti
Unread postby critor » 21 Jan 2018, 22:21
Ok, managed to get it.
And yes, read_nand is crashing :
0000b168: e24dd014   sub   sp,sp,00000014
0000b16c: e1a04002   mov   r4,r2
0000b170: e5dd2038   ldrb   r2,[sp + 038]
0000b174: e1a07000   mov   r7,r0
0000b178: e3a00004   mov   r0,00000004
0000b17c: e1a06001   mov   r6,r1
0000b180: e1a09003   mov   r9,r3
0000b184: e58d2004   str   r2,[sp + 004]
0000b188: e59da03c   ldr   r10,[sp + 03c]
0000b18c: ebfff596   bl   000087ec
Warning (000107b8): Data abort: address=0ffffff8 status=05 instruction at 000107b8
Level up: 5.8%
Images: 9464
Class: Lycée
Facebook: critor.ti
Unread postby critor » 21 Jan 2018, 23:23
Not sure if it could be possible to reinit the NAND.
Here are some Boot1 3.0.0.99 NAND-related syscalls :
k 988 +x //setup_clocks_nand
k 6660 +x //nand_read_header
k 7178 +x //read_nand_header
k 87BC +x //nand_partition_size
k 87EC +x //nand_partition_start
k 8818 +x //nand_add_partition
k 8B64 +x //get_nand_drv / get_nand_driver
k 8B70 +x //deinit_delete_nand_driver
k 8B7C +x //initNAND / create_initialize_nand_driver
k 8BAC +x //nand_driver_initialize
k 8C9C +x //nand_drv_handler / nand_driver
k 9054 +x //ioc_nand_erase / nand_erase_range
k 9098 +x //write_nand
k 90E0 +x //ioc_nand_read / read_nand
k 9138 +x //nand_print_bad_block_list
k 91C0 +x //nand_install_debug_print_function
k 91E8 +x //nand_is_block_bad
k 9214 +x //nand_erase_block_if_good
k 924C +x //nand_write_page
k 928C +x //nand_get_block_start
k 92CC +x //nand_name / nand_get_chip_name
k 92F8 +x //nand_get_number_of_blocks
k 9324 +x //nand_get_pages_per_block
k 9350 +x //nand_get_spare_bytes_per_page
k 937C +x //nand_block_size / nand_get_pagesize
k 93B0 +x //nand_get_block_size
k 93C8 +x //nand_read_page / nand_read_page
k 94D0 +x //nand_erase_block
k 9DB4 +x //nand_print_badblocks
k 9E48 +x //nand_wait_ready
k 9E60 +x //nand_set_page
k 9F2C +x //nand_read_word
k A05C +x //nand_writable_stuff_handler
k A76C +x //nand_set_cycles
k B11C +x //_nand_erase_range
k B164 +x //nand_read / _read_nand
k B464 +x //write_nand / _write_nand
k B610 +x //nand_page_size
k B628 +x //get_nand_spare_bytes
k B670 +x //nand_size
k D350 +x //nand_writable_stuff
k 19748 +x //print_nand_id / print_nand_fash_id
k 199F8 +x //nand_read_first_page
k 1CB1C +x //nand_partitiontable_ptrs
k A4000898 +x //nand_partitiontable_classic
k A40008C0 +x //nand_partitiontable_cx
k A40008E8 +x //nand_drv
k A40008F4 +x //maybe_nand_initialized
k A4000934 +x //nand_struct
k A4000948 +x //nand_page_log2
k A400094C +x //_nand_spare_bytes
k A4000950 +x //_nand_page_count
k A4001E28 +x //nand_initialized
k A4001FC8 +x //nand_page_log2_0
k A4001FCC +x //nand_spare_bytes
k A4001FD0 +x //nand_page_count
The Boot1 seems to call in order :
- create_nand_driver
- get_nand_driver
(parameters unknown, if any)
- init_nand_driver
void (*create_nand_driver)()=(void*) 0x8b7c;
void (*get_nand_driver)()=(void*) 0x8c9c;
void (*init_nand_driver)()=(void*) 0x8bac;
Level up: 5.8%
Images: 9464
Class: Lycée
Facebook: critor.ti
Unread postby critor » 22 Jan 2018, 00:05
More precisely :
Boot Loader Stage 1 (3.00.99)
Build: 2010/9/9, 17:29:13
Copyright (c) 2006-2010 Texas Instruments Incorporated
Using production keys
Last boot progress: 65
Available system memory: 33196
D350 // nand_writable_stuff
Checking for NAND:
8B7C // initNAND / create_initialize_nand_driver
8C9C // nand_drv_handler / nand_driver
A76C // nand_set_cycles
8BAC // nand_driver_initialize
9E48 // nand_wait_ready
8B64 // get_nand_drv / get_nand_driver
91C0 // nand_install_debug_print_function
19748 // print_nand_id / print_nand_flash_id
NAND Flash ID:
92CC // nand_name / nand_get_chip_name
Generic 1 GBit (0xA1)
Level up: 5.8%
Images: 9464
Class: Lycée
Facebook: critor.ti
Unread postby parrotgeek1 » 22 Jan 2018, 00:10
Try to find them inside boot1.5 4.4.0.8, then maybe you can call *that* read_nand
(It would be advisable to copy the first 0x1F04 bytes of boot1.5 back, to undo the corruption)
My Projects:
nLoaderCAS Patcher for ControlXnLaunchy CXM fork (3.9 CAS on B&W) - News ArticleTI-82 Advanced App Installer
Prototypes:
Upgrade EVT Nspire CAS+Fix keyboard on prototype TI-Nspire CAS Touchpad
- Highlights: Nspire CX Non-CAS OS 3.3, CX & CX CAS OS 4.4 & 4.5 special reformatting installers (both found by me on TI's site)
Discoveries:
Boot1.5 vulnerability (used in nLoader) • Nspire dev boardsPink CX
Je peux comprendre le français mais je ne peux pas le parler bien.
parrotgeek1Programmeur
Level up: 73.3%
Twitter: parrotgeek1
GitHub: parrotgeek1
Unread postby critor » 22 Jan 2018, 18:55
Could you check how to add a correct size to your 0x8000 HHackers!, so that BtMg is going to flash your image correctly ?
Another possibility is to package your image with a Boot1.5 image instead of a Boot2 image, much smaller. Boot1.5 also has the nand_read/write syscalls.
Like ControlX, your code could then look in the Boot2/Diags/ExtnD partitions for an appropriate Boot2 image to load the OS, and patch it the way it wants.
Are you sure that the installed Boot1.5 read/write_nand syscalls don't work in the context of your exploit ?
(are corrupted, or use variables which have been corrupted)
Level up: 5.8%
Images: 9464
Class: Lycée
Facebook: critor.ti
Unread postby parrotgeek1 » 22 Jan 2018, 23:01
critor wrote:Could you check how to add a correct size to your 0x8000 HHackers!, so that BtMg is going to flash your image correctly ?
If I do that, the exploit doesn't work
My Projects:
Prototypes:
Discoveries:
Level up: 73.3%
GitHub: parrotgeek1
Unread postby parrotgeek1 » 23 Jan 2018, 03:33
There is a strange problem with the exploit on boot1 4.0.1. It restarts the exploit, and then claims "wrong boot2 version". The same file works on 3.0.0.99. It works, strangely, if you run boot1 4.0.1 but DO NOT pick HW-W in firebird (but with corrupted graphics).
EXPLOIT: Created by parrotgeek1. Compiled: Jan 22 2018 12:41:51
CAS OS mode
Wrong boot2 version
Can anyone help me debug this?
My Projects:
Prototypes:
Discoveries:
Level up: 73.3%
GitHub: parrotgeek1
Unread postby critor » 23 Jan 2018, 10:16
A more complete bootlog would help.
I don't even know in which context you're getting this
(Boot1 since you're mentioning it ? Boot1.5 ?...)
As far as I know Boot1 4.0.1 still boots old 3.x Boot2 images, so I never saw it complaining about a wrong boot2 version.
And unless I made an error, no "...Wrong..." string is visible in Boot1 4.0.1 or in decompressed Boot1.5 4.4.
Level up: 5.8%
Images: 9464
Class: Lycée
Facebook: critor.ti
Unread postby parrotgeek1 » 23 Jan 2018, 10:45
critor wrote:A more complete bootlog would help.
All of that output is generated by "nanoloader" in my repo, not by boot1/1.5.
On boot1 3.0.0.99 it works fine.
On boot1 4.0.1 it doesn't. After the first line of output, it jumps BACK to 111e0000, starts over, and then thinks that the patched boot2 included in the exploit is not 4.0.3 (it is; this exact image works fine on 3.0.0.99).
The first line of output is only supposed to appear once.
My Projects:
Prototypes:
Discoveries:
Level up: 73.3%
GitHub: parrotgeek1
L'OS 5.5 de la TI-83 Premium CE / 84 Plus CE supprime l'assembleur - la plupart des jeux et certains programme ne fonctionneront plus
637 utilisateurs:
>627 invités
>4 membres
