Patching 4.4.0.532 CAS to run on Non-CAS
C, C++, ASM...
Re: [ARM GURU NEEDED] Patching 4.4.0.532 CAS to run on Non-C
Unread postby parrotgeek1 » 02 Feb 2017, 22:25
critor wrote:Ah, interesting.
Could you check if your patches can be adapted for OSes 3.6-4.3 ?
They probably can, but can you ask excale to add 4.4 integrity check patch to nlaunchy?
I am only going to adapt the patches for these other OSes
3.6.0.550 classic CAS
3.6.0.550 CX (for running on CM, 3.9 does not work on 32mb RAM)
3.6.0.550 CX CAS (for running on CM, 3.9 does not work on 32mb RAM)
3.9.0.463 classic CAS
Because it is not necessary for anyone to use another older version if they can use 4.4.
My Projects:
nLoaderCAS Patcher for ControlXnLaunchy CXM fork (3.9 CAS on B&W) - News Article
Prototypes:
Upgrade EVT Nspire CAS+Fix keyboard on prototype TI-Nspire CAS Touchpad
- Highlights: Nspire CX Non-CAS OS 3.3, CX & CX CAS OS 4.4 & 4.5 special reformatting installers (both found by me on TI's site)
Discoveries:
Boot1.5 vuln (used in nLoader) • Nspire dev boardsPink CX
Je peux comprendre le français mais je ne peux pas le parler bien.
parrotgeek1Prog.
Level up: 65.1%
Class: university student
GitHub: parrotgeek1
Unread postby critor » 02 Feb 2017, 22:27
That's what I was thinking - an Nlaunchy update is going to be needed too.
critorAdmin.
Niveau 18: DC (Deus ex Calculatorum)
Level up: 93%
Images: 8451
Class: Lycée
Facebook: critor.ti
Unread postby parrotgeek1 » 02 Feb 2017, 22:33
critor wrote:That's what I was thinking - an Nlaunchy update is going to be needed too.
I am now working on patching boot2 4.0.3 to not check the model, so that you can directly install CAS version with official procedure and controlx!
Do you agree with my reasoning about not making patches for every version?
My Projects:
Prototypes:
Discoveries:
parrotgeek1Prog.
Level up: 65.1%
GitHub: parrotgeek1
Unread postby critor » 02 Feb 2017, 22:37
The problem is not only with the installation.
Boot2 does also check the CAS/non-CAS types each time it loads an OS, so on every reboot.
critorAdmin.
Level up: 93%
Images: 8451
Class: Lycée
Facebook: critor.ti
Unread postby parrotgeek1 » 02 Feb 2017, 22:44
critor wrote:The problem is not only with the installation.
I know. My ControlX would patch it every reboot.
You didn't answer my other question
My Projects:
Prototypes:
Discoveries:
parrotgeek1Prog.
Level up: 65.1%
GitHub: parrotgeek1
Unread postby critor » 02 Feb 2017, 22:51
Patching every 3.6+ version would be better - but it's your decision as you're the one working on them. :)
A 4.2 patch for example would still be interesting, as :
- OS 4.2 is much smaller than 4.4 and thus is using much less RAM
- Ndless 4.2 can be considered as perfectly stable, since it's been used for months
I don't have time to test/improve your 4.4 patches for now.
Are all of them absolutely needed or did you just patch every reference ?
Because the place in Boot2 4.0.3 in which ControlX is injecting the OS patcher together with its patches is quite small, just a little more than 900 bytes for all supported OS versions.
And the Ndless installers have to fit in this same place too...
critorAdmin.
Level up: 93%
Images: 8451
Class: Lycée
Facebook: critor.ti
Unread postby parrotgeek1 » 02 Feb 2017, 23:01
critor wrote:Patching every 3.6+ version would be better - but it's your decision as you're the one working on them. :)
Because the place in Boot2 4.0.3 in which ControlX is injecting the OS patcher is quite small, just a little more than 900 bytes.
They are all absolutely needed, but I don't think it's the best way to do the patches. It replaces the product ID, which means every calculator has the same blank serial number. I tried to find where it is actually comparing the value but I gave up. I will make a 4.2 version later today.
My Projects:
Prototypes:
Discoveries:
parrotgeek1Prog.
Level up: 65.1%
GitHub: parrotgeek1
Unread postby Bisam » 02 Feb 2017, 23:48
Cool !
I may finally update my calc to some OS newer than 3.2... and still have CAS on my non CAS. That's great news !!
I never tried to kiss a parrot, but a big hug should be enough :p
BisamAdmin.
Level up: 47.4%
Unread postby parrotgeek1 » 02 Feb 2017, 23:54
Bisam wrote:Cool !
My Projects:
Prototypes:
Discoveries:
parrotgeek1Prog.
Level up: 65.1%
GitHub: parrotgeek1
Unread postby parrotgeek1 » 03 Feb 2017, 03:16
Bisam wrote:Cool !
Use my beta nlaunchy! use my nlaunch.tns,and nlaunch.tco
https://github.com/parrotgeek1/nLaunchy
and put the 4.4.0.532 cas os as phoenix.tns
My Projects:
Prototypes:
Discoveries:
parrotgeek1Prog.
Level up: 65.1%
GitHub: parrotgeek1
123
Notre partenaire Jarrety
452 utilisateurs:
>429 invités
>18 membres
