[FR] Langage C sur ez80 - Mémo, rappels & tutoriels
Assembleur, Axe, ICE, BBC Basic...
Re: [FR] Langage C sur ez80 - Mémo, rappels & tutoriels
Unread postby Wistaro » 27 Oct 2016, 11:52
MateoConLechuga wrote:Very nice work Wistaro! :D
So the toolchain has had quite a ton of updates, including RTC support, more OS integration, and many other neat things that you will definitely want to explore.
(hint: look at tice.h)
Perhaps the most important is the release of v3 of the fileio library, which now allows you to set, store, and recall variables used in BASIC programs, such as Ans, Matrices, Strings, Lists, and others with ease. Be sure to update as soon as you can, and enjoy! :D
Download toolchain: https://github.com/CE-Programming/toolc ... ses/latest
Download libraries: https://github.com/CE-Programming/libra ... ses/latest
Cool, very good work! :bj:
I'll add it asap in the "fileio" section (empty for the moment!), in the tutorial :)
And I'll certaintly translate this topic in english : viewtopic.php?f=12&t=18775&lang=en
if people want to help, it would be with pleasure (Adriweb, Mateo...)...
Nouveau sur le site,
Anonymous
? Avant de poster sur le chat et sur le forum, n'oublie pas de . En cas de problème, tu peux m'envoyer un message, je réponds rapidement.
WistaroModo.G
Level up: 62.3%
Class: Etudiant ingénieur (dernière année)
Unread postby Adriweb » 27 Oct 2016, 12:03
Cool :)
BTW, I added autotester files for all libs demos yesterday :)
See here, here, and here.
AdriwebAdmin.
Level up: 52.8%
Images: 1081
Class: (ingénieur)
Unread postby MateoConLechuga » 28 Dec 2016, 05:26
There is a new update to the toolchain and convpng that totally revamps and fixes compression since everyone seems to want it :P You can check out graphics demos 5 and 7 for useage, and the new header file "decompress.h".
For comparisons:
Input Image
ConvPNG outputs:
no compression = 52802 bytes
old compression = 29966 bytes
new compression = 20881 bytes
MateoConLechugaVIP++
Level up: 56.3%
Unread postby Wistaro » 28 Dec 2016, 10:36
MateoConLechuga wrote:There is a new update to the toolchain and convpng that totally revamps and fixes compression since everyone seems to want it :P You can check out graphics demos 5 and 7 for useage, and the new header file "decompress.h".
For comparisons:
Input Image
ConvPNG outputs:
Cool, nice !
Good work :bj:
I will update this tutorial asap
Anonymous
WistaroModo.G
Level up: 62.3%
Unread postby Adriweb » 28 Dec 2016, 12:18
Nice work, indeed :)
Any downside to always using the turbo decompress variant? I haven't looked in detail
AdriwebAdmin.
Level up: 52.8%
Images: 1081
Class: (ingénieur)
Unread postby Wistaro » 04 Jan 2017, 19:33
Mise à jour 3.2:
  • Ajout d'informations sur l'écran de la calculatrice
  • Ajout d'informations pour afficher une valeur sur l'écran graphique
  • Amélioration de la mise en page pour certains paramètres
  • Rajout dans la section "liens utiles" des programmes de démos
  • Rajout du lien vers l'IRC ez80-dev
(merci à Themachine02 pour certaines précisions)
Je n'ai pas encore parlé de la gestions des sprites avec la nouvelle méthode de compression, je le ferais après, je compte refaire une grosse section dessus.
Anonymous
WistaroModo.G
Level up: 62.3%
Unread postby Pyroo » 17 Jan 2017, 21:30
Existe t il un Topic identique pour la programmation en basic ?
Pyroo
Level up: 21.3%
Class: Lycée
Unread postby Hamza.S » 17 Jan 2017, 21:32
Hamza.SAdmin.
Level up: 9%
Unread postby Wistaro » 29 Jan 2017, 19:44
Mise à jour 4.0:
  • Refonte totale de la mise en page: ajout d'un sommaire, d'ancres, de titres, de sous-titres.
  • Ajout de fonctions propres à l'OS:
    • Voir/Modifier la date et l'heure
    • Afficher le niveau de batterie
    • Détecter la pression sur la touche ON
  • Ajout d'un paragraphe sur les pointeurs en C
  • Ajout d'infos sur le type
    gfx_image_t
    pour les sprites
  • Correction de liens cassés
  • Correction de coquilles/fautes d'orthographe
N'hésitez pas à signaler toute faute/incohérence :)
Anonymous
WistaroModo.G
Level up: 62.3%
Unread postby sautax » 29 Jan 2017, 19:49
Tu devrais écrire en gros, gras, rouge que éteindre la calculatrice via boot_turnOff() est une très mauvaise idée car le commentaire // n'est pas très visible .
Mes projets :
-Environnement numworks sur PC
-TILIB
-AGAME
sautaxProg.
Level up: 16.3%
Class: Terminale S-SI
YouTube: sautax
12
Notre partenaire Jarrety
470 utilisateurs:
>441 invités
>23 membres
